10-29-2010, 04:32 AM | #121 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
Ok, so I ordered the right HR dig unit... Thanks for helping me choose the right one. When you guys say you have to "flip the transmission, do mean in the same way as described in the "must do mods" section where guys describe ways of getting rid of torque twist. Taking the trans apart and rebuilding it backwards and having the motor on the other side of the truck. How does flipping the trans make the dig work or not? Maybe I'm missing something... Guess I'll see when the unit arrives with it's "detailed instructions" lol Last edited by madkawi650; 10-29-2010 at 04:34 AM. |
11-22-2010, 05:23 AM | #122 |
If this HR unit came with instructions it would be very helpfull.. However. I can not use my HR cover ring. the mounting screws are too close to the casing and wont go in. I said the heck with it and threw it in the tool box and continued. Fuddled my way through it till It was working. I played around with the my DX3.0 and set the 2P 3rd channel to give me 4wd and 2wd with rear lock. Im impressed for the price, but it has trouble locking the rear.. It disengages perfectly every time, but take some rolling back and forth to get the rear to lock most time. If I add more travel buy adjusting EPA's It helps but them even after engagement, the servo sits there and hums. I have to adjust back a bit to make it relax. Maybe more spring on the push rod instead of the 1/4" piece of fuel tube I'm using. How is everyone elses HR Dig working ? |
11-22-2010, 10:27 AM | #123 |
Newbie Join Date: Jul 2010 Location: liverpool . uk
vie got one and it works great really smooth. not had any problems apart from i got the lcg gear box as well and it doesn't have much wheel speed [bummer] but other than that its great. |
11-22-2010, 03:04 PM | #124 |
Mine worked great. I tore it apart every couple of months or so to check the gears, clean everything and put fresh lube on everything. I only have two real complaints about this dig: 1- You have to plan ahead, if you find yourself need a dig immediately and it isn't already engaged you're screwed. 2- Sometimes it gets bound up when you have a lot of stress on the rear wheels and the only way to get the truck into 4WD is to use reverse. |
12-05-2010, 08:01 PM | #125 | |
Newbie Join Date: Nov 2009 Location: san antonio
02-08-2011, 03:05 AM | #126 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
if there are no instruction is it easy to install
02-08-2011, 09:02 PM | #127 |
Newbie Join Date: Dec 2010 Location: sacramento
how durable is this unit?
05-08-2015, 11:29 AM | #128 |
Rock Stacker Join Date: Oct 2012 Location: GREEN ISLE MN
| Re: Hot Racing Dig for AX10 Stock outta my underground bodiless. |
05-08-2015, 11:30 AM | #129 |
| Re: Hot Racing Dig for AX10 Cleaned lubed and dig installed on the transmission. |
05-08-2015, 11:31 AM | #130 |
| Re: Hot Racing Dig for AX10 40 in oz micro metal gear |
05-08-2015, 11:31 AM | #131 |
| Re: Hot Racing Dig for AX10 Servo mounted and linkage intalled. |
05-08-2015, 11:33 AM | #132 |
| Re: Hot Racing Dig for AX10 Back in ... Reroute the wires , esc and panels back on. |
