12-19-2008, 09:07 AM | #81 |
Pebble Pounder Join Date: Sep 2008 Location: Red Deer,Alberta
Looks good hank!!
12-19-2008, 11:18 AM | #82 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
Thanks for the kind words guys. Hanks rig is coming along. |
12-22-2008, 07:59 AM | #83 |
Newbie Join Date: Dec 2008 Location: Djursland, Denmark
| This thread is so cool !!+! I especially liked when you went to Florida, Hank on his towel, made me smile.... Loud Merry X-mas from small and flat litlle Denmark! (Thats Scandinavia, Europe, if anyone was in doubt ) |
12-24-2008, 07:28 AM | #84 |
Got Rocks? Join Date: Apr 2005 Location: Shen Valley VA
12-24-2008, 12:13 PM | #85 |
All it takes is 2 zip ties and hank is there. Just remember Hank is still running a stock chassis.:-P |
12-24-2008, 12:15 PM | #86 |
Quarry Creeper Join Date: Jan 2006 Location: hagerstown
Hank's the man he does good for what he has to work with.
12-24-2008, 08:00 PM | #87 |
12-28-2008, 06:55 PM | #88 |
Went to a GTG today. Truck ran great until Hank blew apart a shock and the rear dig started to slip. I have not had much time to help Hank as I have been working on his buddy Chip's 71 Blazer. 71 Blazer trail rig |
12-28-2008, 07:43 PM | #89 |
Pebble Pounder Join Date: Sep 2007 Location: Fallbrook
this is some of the best tech and fun reading iv had in a while! keep up the good work
12-28-2008, 07:52 PM | #90 |
Newbie Join Date: Mar 2008 Location: maple ridge,BC,canada
12-30-2008, 04:17 PM | #91 |
12-30-2008, 08:32 PM | #92 |
Rock Stacker Join Date: May 2008 Location: dayton,VA
I think hank needs a job |
12-30-2008, 09:26 PM | #93 |
Pebble Pounder Join Date: Sep 2008 Location: middle river
kane i just found this thread. i was laughing the whole time. my wife asked what was so funny about rc crawlers cause i was laughing so hard . good build
12-30-2008, 10:10 PM | #94 |
Quarry Creeper Join Date: Nov 2008 Location: Lightin' The Desert In
12-31-2008, 10:51 AM | #95 |
The dig on Hanks truck was starting to slip so we decided to take the trans apart to see what was going on. This is what we found. If you look close you can see that the rear trans output bolt heads pulled threw the output. You can also see the midle gear is stripped. The striped gear hapened after I put the trans back together the first time after cleaning up the dig coupler. I should have fixed it right the first time and I dont think the gear would have striped. On a side not when I put the dig together the first time I think I over torqued the bolts holding the too halfs together. Hank pulled the gear he needed out of Chips Blazer. That still left the problem with the dig. I emailed DNA and they are sending out new parts. They were great to deel with. I am not sure how long it will take to get the new padts so I decided to redrill the outdrive so I could bolt it back together. I drilled out the outdrive for the bolts and then used a dull 1/8 drill bit to make the counter bore to recess the bolt heads. I used a dull bit as to not cut right threw the outdrive. I could not believe how much trash was in the case and stuck in the gears. If you ever have trouble with your trans make sure you clean it up very well.:-( |
12-31-2008, 10:56 AM | #96 |
I took some pix of were I had to grind the Dig case to clear the lower link. |
12-31-2008, 04:37 PM | #97 |
Hank borrowed a CC link from youngblood to program his BEC and has had it at 6.5 volts for 4 or 5 battery packs. He needs to give it back soon so we are going to run it at 7.0 volts and see how it does. He has the BEC so it is only powering the steering servo (Hitec HS5955TG) Seems good so far YMMV. |
01-10-2009, 02:37 AM | #98 |
Quarry Creeper Join Date: Sep 2008 Location: !! MOAB !!
Hey what happend to Hank. Havent seen him in a awile. had to find him on page 10 !!! maybe hank found a Woman????
01-10-2009, 03:03 AM | #99 | |
The same thing happened to my dig outdrive. took less than a week to get it. Much props to DNA. | |
01-12-2009, 05:31 AM | #100 | |
http://www.jpcustomrcs.atomicshops.c...77/5814353.htm Thanks for looking KR | |
