Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX-10 Scorpion
Thread: Axial tips and tricks
Old 01-01-2009, 07:19 PM   #1
666
MODERHATER™
666's Avatar
Default Axial tips and tricks
This section needs a tips and tricks sticky I have a few to add feel, free to add threads and tricks you know that are helpful.
Mirror Imaged Transmission
Output shaft fix
Maxx Shafts made easy.
666 is offline   Reply With Quote
Old 01-04-2009, 09:30 PM   #2
MODERATOR™
EeePee's Avatar
Gear ratio chart for easy referencing.
Just noticed the 16/87 is the same as the 15/87. Should be 41.82 by my calculator.
Old 01-06-2009, 04:11 PM   #3
Anti Squat and Suspension Tech
This one is very helpfull! All though it still makes my brain numb when I think about it. Thanks everyone that contributed.
wild bill is offline   Reply With Quote
Old 01-06-2009, 06:19 PM   #4
build your own dig
http://rccrawler.com/forum/showthread.php?t=101507
zach is offline   Reply With Quote
Old 01-12-2009, 03:27 AM   #5
When you attach the top of the shock absorber to the chasis put grease on the little washer so that it doesnt keep falling off as you thread the cross bolt in. -Migs
Migs is offline   Reply With Quote
Old 01-12-2009, 03:31 AM   #6
Default Beadlock Tire Assembly
When assembling the tires, squeeze the rubber rim completely into the rim on both sides, then start all the beadlock screws 4 turns through the beadlock ring. Next slide the rubber rim out from inside the rim into its place under the beadlock ring. Finally finish screwing down the screws. As a last check see that the screw heads all touch the ring. Remeber not to overtighten the screws.-Migs
Old 01-14-2009, 08:00 PM   #7
pjr
Default templates
This belongs here!!
http://rccrawler.com/forum/showthrea...t=AX10+battery
pjr is offline   Reply With Quote
Old 01-16-2009, 08:38 PM   #8
Default On Receivers and Antennae
This one is important:
As you route your receiver's antenna through its mast, consider how close it comes to that hungry, nasty gear. Take your time to make sure it comes no where near that chainsaw of doom! A little duct tape may be necessary to route it away from this spinning devil.
Be sure to put a half drop of cyanoacralate glue on the base of the tube mast, lest you pull it off the wire antenna every time you remove the body!
You can also measure how long the antenna wire goes into the mast and cut the excess mast off, but I would recommend leaving the excess on because eventually you mast will crask at the bottom, and then you will need some excess material to trim off and be like new.
Migs
Old 01-17-2009, 09:15 PM   #9
use loctite on every thing that dosn't nylock and ckrc bta all the way
patchettdestruc is offline   Reply With Quote
Old 01-18-2009, 03:13 AM   #10
this has been very helpful to me but i did it the cheap way http://rccrawler.com/axialcompbuild.html
Crawler_from_Oz is offline   Reply With Quote
Old 01-23-2009, 07:34 AM   #11
Default Body Clip Management
Here is a good one so you will be able to remove the body clips without tools, and also so they will be harder to loose: Wrap a little duct tape (I use Gorilla Tape) around each clip more carefully than I have done. Pulling the clips out is now easy! Like so:
Old 01-26-2009, 06:31 AM   #12
Here's a tidy alternative to wheel weights that just sprung to mind - Plumbers lead free solder comes in 500g rolls, just wrap as much as you need around the inside of each wheel, it packs neatly just like an armature winding, then wrap a length of duct tape around it
Kev
ManxCrawler is offline   Reply With Quote
Old 01-27-2009, 02:34 AM   #13
Vent your rims! I find that two 1/8" holes opposing eachother on each rim is beneficial. You may want to try varying the size and quantity of the vents, depending on your choice of foams and tires.
I recommend using a finger bit, or a Dremel on low RPM rather than a full sized drill on plastic rims.
CreepyCrawl is offline   Reply With Quote
Old 02-01-2009, 12:55 PM   #14
I finally got sick of all whell slop the axial has in the wheel bearings. So I came up with a cheap fix. I went to the local hardware store and picked up a little bag of 5mm washers. They fit perfect right behind the hex pin on the stub shaft. They are not very tight but do put a slight preload on the bearings. This took all of the wheel slop away.
With the addition of a good tight fitting locker I got ALL of the slop to disapper. Now it is so much easier to control.
moabax is offline   Reply With Quote
Old 02-01-2009, 10:10 PM   #15
This is not specific to Axial but........ cut a scap of lexan that is big enough to fit inside the body and wrap your antenna wire around, no more mast, much cleaner.
fixed13 is offline   Reply With Quote
Old 02-03-2009, 11:15 PM   #16
also another tip is flip ur shocks up side down to get the center gravity lower so ur gettin more weight down so if can flip shocks
kdizzle122 is offline   Reply With Quote
Old 02-04-2009, 04:44 PM   #17
Default AS-1 Servo Rebuild
Has anyone tried to rebuild the stock servo from the AX10 Rock Racer RTR?
Looks like a futaba unit to me but I am not sure which gear set to use for the rebuild as it is not listed anywhere.
Thanks
lwarc is offline   Reply With Quote
Old 02-04-2009, 08:06 PM   #18
Got it - The Axial AS-1 servo is really a Futaba S3010 High Torque servo. Replacement gears are about $10.
Old 02-05-2009, 01:59 PM   #19
if you ever want to have decent steering make sure to run a bec with the higher powered servos
BEN214 is offline   Reply With Quote
Old 02-05-2009, 09:24 PM   #20
Thumbs up
Does this make any difference?
Has anyone removed the foam from their tires?
Im not running foam and it seams to do just as well as with the foam.
I also cut my hammers to resemble Super Swamper Boggers
My battery is mounted to the rear upper links, held down by the velcro.
I have found that if the front weighs to much the servo struggles.
I had a problem with spinning my drivelines and so I decided to take a file to the output shaft on the transfer case. I filled down the side 180 degrees from the factory flat spot and installed two set screws.
TourevoEclipse is offline   Reply With Quote
