05-12-2009, 01:26 AM | #21 | |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
Exact size we're looking for Fits perfect on the hex nut and the hex out drive nut All assembled! | |
05-12-2009, 01:35 AM | #22 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
Cool beans. What the part number of that bearing pack? I need to order some for when my dig come in.
05-12-2009, 01:38 AM | #23 |
More importantly what size is that bearing? I don't have a tlt to scrounge from but I do have a bunch of old tamiya's laying around somewhere.
05-12-2009, 01:42 AM | #24 |
RCC Addict Join Date: Jan 2005 Location: Germany north
looks like 8x5mm
05-12-2009, 02:40 AM | #25 |
05-12-2009, 07:45 AM | #26 |
Quarry Creeper Join Date: Feb 2009 Location: Warwick
| bearing swap
...is that 5X8 2 mm or 2.5 mm wide? Bocca Bearing has both.
05-12-2009, 09:01 AM | #27 |
8x5 2mm
05-12-2009, 11:03 AM | #28 |
05-12-2009, 11:09 AM | #29 |
Quarry Creeper Join Date: Nov 2008 Location: Boise
So where is the video? I would love to see this thing in action |
05-12-2009, 11:41 AM | #30 |
05-12-2009, 11:43 AM | #31 |
05-12-2009, 07:04 PM | #32 |
05-18-2009, 12:39 AM | #33 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I set mine up with a 8x5x2.5mm bearing, and white lithium grease, seems to be running good after some early tests.
05-18-2009, 06:52 AM | #34 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
05-18-2009, 03:28 PM | #35 |
| Throw some bearing grease in there and you will be fine. The tiny open slot at the top isn't that big of a deal. Tear it down ever few months if you are worried about it. Or use a small piece of thin lexan as a shroud over it. Don't get too hung up on that part.
05-18-2009, 06:40 PM | #36 |
Anyone else have any issues with it binding up a bit when you spin it after it's attached to the trans? I see in step 15 ya mention if you tighten down to the trans too much, it'll bind...but I can barely even snug it. Possibly use a washer sandwiched between the dig case and trans case? Last edited by Offroader5; 05-18-2009 at 06:44 PM. |
05-18-2009, 07:31 PM | #37 |
Ok, official problem was.......... The aluminum trans case The trans case I was attaching the dig to was a GH aluminum and for some reason the dig binds up once both mount screws are even the slightest bit snug. I swapped the dig to a OEM plastic cased trans...and it works smooth as butta. I'm going to find out why the aluminum case wouldn't work though...:-( |
05-19-2009, 06:00 PM | #38 | |
http://www3.towerhobbies.com/cgi-bin...?&I=LXHFS5&P=7 | |
05-19-2009, 08:51 PM | #39 |
Could someone, anyone please go out and play with your dig and report back here. All this jibber jabbin and no one has tested it out yet? Get with the program peeps:-P |
05-19-2009, 10:03 PM | #40 | |
Narly1 | |
