06-15-2009, 10:43 PM | #101 |
06-15-2009, 11:03 PM | #102 |
I'd really like to see a vid of the dig working flawlessly in a real bind;)...not on basicly flat ground without the tires bound up on slippery rock(like in the only vid I've seen of this dig in action).
06-15-2009, 11:08 PM | #103 |
06-15-2009, 11:09 PM | #104 |
Worked great when...
06-15-2009, 11:12 PM | #105 |
| When I'd get it (the truck) bound up. Don't know if it means anything to you, but I'd never spun a hex untill I got this dig. Since then I've wiped out three Axial rims on the front axle. Currently waiting to seal the deal on an aluminum set...COUGH COUGH Last edited by Duuuuuuuude; 06-15-2009 at 11:23 PM. |
06-15-2009, 11:22 PM | #106 |
| See, that doesn't tell me anything, because one person's bound up isn't the same as another person's bound up. My dig shifts everytime...period..no hangups ever....it's about as close as you can get to a Berg type electronic dig, with a shafty of course...no matter how bound up or twisted up or whatever, it will shift period. And this is on lava type rock that is just like rough sandpaper...no forgiveness. I don't run an Eritex one BTW. I keep reading about how these work so great, even bound up, but that is not what I have seen in person at my local comps I don't want to badmouth the Eritex dig, I just want to see what everybody means when they say it works flawlessly, because that's not what I'd say about them. |
06-15-2009, 11:29 PM | #107 |
I can't say mine worked flawlessly because I jacked it up pretty seriously (no fault of Eritex). However, when I did manage to have it going pretty well, I loved it. There can be a bit of delay to get the rears locked, depending on the orientation of the hexes in the dig, but its very minimal. Usually if the suspension is bound up in 4wd, when you shift to the locked position the rear tires will turn just a hair as the truck relaxes and will cause it to engauge. I've driven it up a nearly verticle face untill the rear tires almost touch, shifted to dig, let the front tires grab the edge and start to pull the truck up and over, and while still on the throttle, shift back to 4wd without problem. But still, I didn't get that much usable drivetime with it. Hopefully next week will be different. |
06-15-2009, 11:41 PM | #108 |
Right on. A good first test I always use, is on the carpet in the living room. I drive into the couch on an angle and start to climb up and basicly almost stall the motor out because you have the tires stuffed so hard, and then disengage/engage without having to move the truck forward or backward....if it won't even do that, I won't even take it out on the rocks, as I already know it won't work reliably in a bind on my rocks.
06-15-2009, 11:48 PM | #109 |
The HRD has to pass through its neutral point to get from 4wd to dig, so its pretty much imposible to make it shift into a severly bound up axle. Once it hits neutral, even for that split second, its enough to make the suspension relax a little.
06-16-2009, 01:10 AM | #110 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
Ive tested mine it this situation where I hold the rear wheel and throttle it till the front wheels are at about 45* then shift it out of 4wd. It seems to work pretty good with a 225mg |
06-16-2009, 01:15 AM | #111 |
Quarry Creeper Join Date: Jan 2009 Location: Langley, BC, Canada
Tanis, what DIG are you using? I just got my Eritex hooked up, and I think it's cool, but it is my first DIG and I really just don't know any better anyway. lol
06-16-2009, 09:46 AM | #112 |
Pebble Pounder Join Date: Nov 2008 Location: Prescott
| x2 What mechanical dig are you using that shifts easily under full bind. The only one I've seen doesn't use a positive engagement system. It uses a friction disc like a one sided clutch. So far I've used the DNA and the CKRC FT. The Eritex HRD has been the best so far. When I dig/drag my rear tires up to a ledge, It is hard to get the dig to release when it is hanging all it's weight on the stuck rears. Mine also has trouble going to nuetral when bound up. I was getting wedged in a crack, and had to release tension on the drivetrain to get to freewheel. Mine is no electronic dig by any means, but it is my new favorite for mechanical dig. I'm using it with a HS-475 and synthetic grease. Last edited by cruzer971; 06-16-2009 at 09:57 AM. |
06-16-2009, 11:13 AM | #113 | |
Quarry Creeper Join Date: Nov 2008 Location: Boise
06-16-2009, 11:21 AM | #114 |
Quarry Creeper Join Date: Aug 2007 Location: right above my feet
Tanis, my Eritex worked great on Sunday, made Pat's look like crap. his feels like it's full of peanut butter when shifting it by hand. Granted, I wasn't ever in a huge bind, but so far, so good. (i lighten up before snapping my SSS) For doubters, Tanis's dig is instant, and consistent. he's got a huge servo on his that thing. I'll let him say what internals he's running. |
06-16-2009, 07:30 PM | #115 |
06-16-2009, 08:04 PM | #116 | ||
And like I said, I'm not putting down the Eritex dig at all, I just want to be on the same page as the rest of you, as far as how it works under bind. | ||
06-16-2009, 10:35 PM | #117 |
Rock Stacker Join Date: Mar 2007 Location: yakima
Alright its time for me to chime in. Chris, my dig started out at the comp a whole lot better and smoother then when you felt it. Im not sure yet what caused it to go rough, i havent taken it apart yet. I run a 645mg servo, according to some previous posts i may be using a to torquey servo. I built my dig exactly as the guide suggested. it worked about as well as a dna dig with a mini servo, however by the end of an hour of crawling, it jammed up. I couldnt slide the shifter with the servo or by hand, it was jammed untill I dismantled it. I then got out the dremmel and buffed up the shift pin, all sharp edges, and the sharp edges on the delrin shift guide. then i noticed that there was quite a bit of drag, which seemed to be comming from the case "pinching" the delrin. So i took a file to that, then buffed it with the dremmel. After much smoothing and buffing i got it to shift smoother with some reliability. I also reassembled it without andy lube at all. In our area there is very fine dust and ash soil, we have great rock because of volcanic action but we also have a fine grit dirt that reeks havoc on greased parts. Since the rebuild it has been working much better, by not stretch flawless. I read those posts and wonder if i got a dig that was machined with incorrect tolerances or if people are using it on their patio or slippery rock. Im not angry or digruntled, I dont regret my purchase, I just wanted to add my experience to the list.
06-17-2009, 10:07 AM | #118 | |
RCC Addict Join Date: Nov 2007 Location: in the woods
Also, you run yours without grease? I came up with this idea for a customer and it seems to be working well.... Bag of party balloons, $.99 Cut the top 2 inches off... Stretch over the dig with the mouth piece towards the trans. Unscrew the shifter linkage from the ball joint on the dig and pierce the balloon with a small allen wrench. Then, thread the shifter rod back through the hole. Tada, dig condom. Might help for you guys that run in dusty areas. Thanks, Gerame | |
06-18-2009, 06:18 PM | #119 |
Rock Stacker Join Date: Feb 2008 Location: Bay Area
06-19-2009, 05:27 PM | #120 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Hi Gerame, I ordered the dig without the servo mount, and I now see that I need the servo mount. I actually have the dig installed, but because I haven't figured out a way to mount a servo yet, I can't use the dig! Your site says the servo mount is backordered. How long do you think it'll be before you've got more servo mounts ready to ship? Thanks! |
