06-20-2009, 10:09 AM | #121 | |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I got one I couldn't use on my rig. Pm me if ya want it. | |
06-22-2009, 12:56 PM | #122 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
OK, so I managed to build my own servo mount, which basically works and looks nearly the same as the HRD dig servo mount. While in dig mode, it does not release when the rear wheels are under tension. I have to reverse the throttle slightly to get the dig to switch to freewheel mode. Also, after about 30 minutes of crawling this weekend, I the new Hitec 225 servo I was using died, even though I had adjusted the EPA's. I'm not sure what's wrong with my setup. Is the servo not strong enough? Too strong? How far from the center of the servo horn should I attach the shifter arm? Should I use a servo saver? Last edited by XPLORx4; 06-22-2009 at 04:16 PM. |
11-04-2009, 09:07 AM | #123 | |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
11-04-2009, 10:49 AM | #124 | |
what radio are you using now? i think the bind is your problem, but some radio's don't like non digital servo's. Last edited by indiana mudcat; 11-04-2009 at 12:37 PM. | |
11-04-2009, 03:30 PM | #125 |
Thanks Ed. Im using a vemom vr3t. Its a computerized fm setup. I dunno if mabey the problem is my outputs, out of line or something. I have tried to make sure that the outputs are centered on the trans gear, and they are as centered as I can get them. I doesnt make alot of sense to me..... When this dig works its sweet, I've just got to figure out whats goin on with it and get it right.
11-04-2009, 04:06 PM | #126 |
I have been running this dig with a 225 with no issues. Make sure that everything is free of bind prior to hooking up the servo. Alot of grease helps, and things do free up with some run time. If you notice a bind spot, be sure to diagnose the cause of it and try and rectify the problem. Sometimes a little polish will help smooth out the shift rod and stuff. As far as the servo horn and linkage, the servo has more mechanical advantage over the dig mechanism when the linkage is mounted as near to the servo output as possible. Obviously, this limits the total available travel the servo can actuate, so, a little trial and error is necessary as clearance also becomes an issue. Also, having the linkage setup to run parallel to the movement of the dig mechanism, and on as flat a plane as possible, will optimize your servos ability. Obviously, running a flat plane on a rotational movement is impossible, try and line up the linkage with the dig movement for best results. The servo will have a had time pushing and pulling the dig mechanism if it can't have a nice straight push/pull on it. An you shouldn't have to reverse to disengage anything. You may not be able to do full throttle engagement/disengagemt until everything breaks in, but just letting off should allow you to shift. |
