06-02-2009, 10:13 AM | #61 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Is anyone using the servo mount? My drive shaft hits before full compression/droop. I'm really not happy with the one hole mount either. Made a mount out of 1/8 alum but it bends. I'm cutting out a real mount but it is a pain. Of course all digs need some kind of mount but I'd think the one designed for the dig would at least come close to working. I'm also not to happy about the short lock-up hex. ya really have to set the epa right to get it to engage without over stressing the servo and the long freewheel area allows alot of rollback on a controlled climb. But overall I like it. We'll see how the alum hexs hold up.
06-02-2009, 11:35 AM | #62 | |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
The "long" freewheel area (or length) is a consequence of the minimum sliding collar width necessary to ensure a robust engagement in both the 4WD and rear wheel lock mode. I suppose you could look at as fast a servo as possible to minimize the transit time......maybe even a "throttle return spring" type arrangement to help speed the transition up (at the expense of making your servo work against the spring force in 4WD and rear freewheel modes). Also if you are on a really steep section of the course perhaps running in rear freewheel mode would be a better decision. If that is the case then the transition time between rear freewheel and rear wheel lock modes is greatly reduced...... Narly1 | |
06-02-2009, 11:59 AM | #63 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
06-02-2009, 05:53 PM | #64 | |
Yes, I have moved it all sorts of ways. Seems to me the one slot mount is a pretty poor way to mount anything (handy for taking apart/falling off). I admit to being an idiot and haven't figured out how to post photos. But it is a stock ax10 Chassis/trans/axles/shock setup 4 linked with bent links and pede shaft (the mpi shaft is worse). | |
06-02-2009, 06:17 PM | #65 | |
06-02-2009, 09:22 PM | #66 | |
This one is from the side with the suspension fully compressed. There is still clearance between the driveshaft and the servo mount. | |
06-02-2009, 11:33 PM | #67 |
I guess I just have too much up travel. I'm making a mount that angles the rear of the servo up, and the front alittle lower. No big deal. The dig worked pretty well at the comp tonight, even with my floppy mount. Only didn't engage lock a couple times (could be my finger or the mount). I'm using an old traxxas 2070 servo and it has plenty of power. BTW that's a very kool looking chassis. Last edited by oldhippie; 06-02-2009 at 11:37 PM. |
06-03-2009, 08:31 AM | #68 |
06-04-2009, 09:41 AM | #69 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Where's the breaking video or did I miss that somewhere?
06-04-2009, 11:45 PM | #70 |
RCC Addict Join Date: Nov 2007 Location: in the woods
06-05-2009, 08:12 PM | #71 |
Rock Stacker Join Date: Mar 2007 Location: yakima
| its been a while since i have posted pics but i hope these work. I made an "L" bracket to mount the servo mount. i also drilled a hole in the servo mount so that it had two secure screws. hope it helps somone else out. it works well for my truck, weight is low, it clears everything by tons of room, like 1mm :-) Last edited by The Cracker; 06-05-2009 at 08:13 PM. Reason: better pic attempt |
06-05-2009, 08:29 PM | #72 |
Looks good!
06-07-2009, 04:14 PM | #73 |
Newbie Join Date: May 2009 Location: fresno
06-07-2009, 04:20 PM | #74 |
06-07-2009, 04:24 PM | #75 |
06-07-2009, 04:26 PM | #76 |
06-07-2009, 04:28 PM | #77 |
06-07-2009, 04:33 PM | #78 |
06-07-2009, 04:36 PM | #79 |
| good info. ill see what i can come up with. what's the minimum oz of torque you recommend for a servo? it seems pretty smooth, like it does not take much.
06-07-2009, 04:42 PM | #80 |
| I run a JR ST47 on mine that has about 50 ounces of torque at 6v. 50 is about the minimum I would suggest.
