05-26-2009, 11:26 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
| Creepy's Eclipse Build
Build time is in limited supply for me lately, but I thought I'd share a bit of my Eclipse build as I go. Just waiting on my Eritex HRD and a couple of other small items. I really dig this chassis, but not zippy'd panels, so I had my buddy Monkeybiz braze on some RCP tabs... Back from powder coat, black of course... Some Axial HD optional gearing... Front 36/14 installed... And the rear 43/13... Sullivan Dry Ice for the Axial CV's... A dab of silicone to retain the CV sleeve... RCP knuckles... Buttoned up; low CG plate, 3Racing tri-link mount, straight axle and a TCS aluminum Boomerang... I rough cut the panels tonight as well, not sure what color to go with though. Stay tuned... Last edited by CreepyCrawl; 05-26-2009 at 11:29 PM. |
05-26-2009, 11:48 PM | #2 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
Very nice and clean start. I should try the overdrive for my front as well. Won't you be using the hood panel? I saw there are no tabs in that part. Hope you find more build time so we can see more!
05-27-2009, 07:06 AM | #3 |
Rock Stacker Join Date: Oct 2008 Location: Epsom
nice start its about time its getting built
05-27-2009, 11:14 AM | #4 |
Pebble Pounder Join Date: Jan 2009 Location: San Mateo
looks great, looking forward to more of the build.
05-27-2009, 02:27 PM | #5 |
Nice job on the tabs, thats the only thing I am not thrilled about on my Eclipse.
05-27-2009, 06:28 PM | #6 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
I realy like that chassis and have been waiting for more builds to pop-up to see how others go with it. The pannel tabs are nice touch but what about the hood area? |
05-27-2009, 08:09 PM | #7 |
Rock Stacker Join Date: Dec 2008 Location: Marion, iowa where no fun happens,ok, maybe once in a long while!!
why do you want the front axle to spin faster than the rear?
05-28-2009, 08:53 AM | #8 | |||
Just for that I'll hang on to your dig when it shows up Thanks man Quote:
I was all good on a droop set up, but after seeing your Eclipse build I'm debating on going sprung with a set of the short Traxxas Big Bores ;) Quote:
Best answer I can give is to check out the thread: Optional Ratio Gear Sets | |||
05-28-2009, 09:02 AM | #9 |
I had heard that using the overdrive front and underdrive rear was a little too much difference. They were recommending one or the other but not both. I will be interested to hear what you think of the setup. Nice build man, the tabs are a nice mod |
05-28-2009, 10:45 AM | #10 |
Yeah, I'm not sure if the UD gearing will stay in or not. I continue to read up on them, and I think I may revert back to the stock HD gearing in the rear. I did notice that the OD gears up front are silky smooth...I mean ridiculously smooth...it's nice The UD is a bit tighter and not quite as free, which makes sense since the gearing is taller and what it's purpose is. We'll see what happens. I appreciate the comments Harley, thank you. |
05-30-2009, 05:06 PM | #11 |
Newbie Join Date: Mar 2007 Location: new hampshire
nice job with the pics creepy. I was hoping to see it go on the rocks tomorrow but I can wait. Hopefully you will have it for the next comp. |
05-30-2009, 05:51 PM | #12 | |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
"Our testing has shown that choosing either all one gear ratio, or running a combination of the stock in combination with one of these nets the best results. We tried the high speed/low ratio combo and found that it caused issues when in binds sometimes. The low speed set would stutter trying to catch up to the high speed gears." Seems like it's not a good idea. | |
06-01-2009, 01:19 AM | #13 |
Updates?
06-01-2009, 07:31 AM | #14 |
I recently read that Axial info as well. I'll be switching back to the stock HD gearing in the rear. If I wasn't running a dig, I'd probably try it though. I've been a bit ill for the past few days so I haven't touched the Eclipse, but I'm hoping to get back to it very soon...I'm anxious to finish it up ;) |
06-01-2009, 11:20 PM | #15 |
| Eritex Dig
I had some time to wrench tonight, so I cleaned out the tranny and re-greased it with some Rocksmith Gear Jelly, and also added a couple of much needed updates. An East End Machining HD motor mount plate... And an always true Kimbrough spur... Assembled and installed the Eritex HRD dig as well...fit and finish is absolutely superb The goods... A little quality time with Mother... Chucked the shift pin in the Dremel at 6K and hit it with some 280 grit and then the Mothers... Polished up the rest of the HRD components as well... Replaced the transmission outdrive bushing with a Traxxas 5x8x2.5 (#5114) sealed bearing... A nice anchor for everything... Bolted up to the tranny with the servo mount, and locked down to the sweet East End Machining triangulated skid... Replaced the supplied cap head hardware with button heads; cleans it up a bit... Real estate for the electronics will be tight in the Eclipse... More to come... |
06-02-2009, 12:31 AM | #16 |
Looking good Creepy, can't wait to see more progress. |
06-02-2009, 08:00 AM | #17 |
looking good cant wait to see it done
06-02-2009, 08:20 AM | #18 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
looking good my brotha...GSRCC Drail
06-02-2009, 09:34 AM | #19 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
This thing's gunna be evil. |
06-03-2009, 10:04 PM | #20 |
you may have just convinced me to give the dig a shot... I may wait to see how yours pans out though. |
