![]() | #121 |
I to love this T1E Moonbuggy shafty Eddie, it's been the best dam shafty I've every owned or driven anywhere and the fact that it allows a good old Gatekeeper set-up makes it something very special. Mine kept up with the 2.2 open class all last summer, it never missed a trick it climbed and side hilled like a Demon. It had some great finishes much to many MOA owners dismay, and that was the best part. I'm currently setting it up for the 2012 Sporty class, I'm pretty sure my club (MNRCRC) isn't going to outlaw the Bodiless chassis'. ![]() |
![]() | #122 | |||
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| ![]() Quote:
![]() ![]() ![]() ![]() Quote:
![]() The 2.2 S Class on the USRCCA still has a number of things to work out and finalize. In the mean time, I am going to run this truck as is and upgrade it as I can. | |||
![]() | #123 |
| ![]() I really like how this shafty runs now! ![]() ![]() ![]() Wheels, Tires & Foams Front: - VP 1" SLW - C.I. 1/4 wheel wideners (placed on outside of the wheel to gain track width) - 1.25" total wheel width - 725 Hubs - C.I. Proto inner foams - C.I 5.5 Soft Outer - no weight added to wheel - C.I. Hybrid Cut N Shut Tires; White Dot Sedona inside w/ Pink Dot Block outside Rear: - VP 1" SLW - C.I. 1/4 wheel wideners (placed on outside of the wheel to gain track width) - 1.25" total wheel width - 725 Hubs - C.I. Proto inner foams - C.I. 5.5 Double Deuce Medium Outer - no weight added to wheel - White Dot Sedona inside w/ Red Dot Block outside ![]() I taped 1.75 ounces to each rear lock out. ![]() ![]() Last edited by Nova's Ark; 11-23-2011 at 04:12 PM. Reason: added information |
![]() | #124 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
So. . . How you liking those pins on the outside? ![]() |
![]() | #125 |
| ![]() I have hybrid tires on every competition truck I own if that tells you anything ![]() |
![]() | #126 |
It's been a long time since I have posted to this thread but I have been driving and working on this little truck. We did not have enough 2.2S Class comps to qualify our local club for Texas State Finals. To make it worse, the USRCCA in their dysfunction thought it was best to Ban Bodiless mid-season and outlaw trucks like this. I completely disagree with this ruling and it's timing so I have not changed my truck and don't plan to at this point. I realize I can't compete in the 2.2S class, but sometimes you just have to take a stand on principles. It wasn't fair to the participants to en-act a rule mid season. Competitors had already spent months competing and learning their trucks, only to have a sanctioning body tell you must change mid season for no sound reasoning or logic. Anyways... I drove the truck all season with the hybrid tires. Sedonas w/ red Blocks. Very nice tire for our terrain. Every comp this truck was in, it won. I have made some changes and I will get some pictures posted. I ran this truck last Saturday at the ARCC comp in Little Rock Arkansas. I got 3rd in 2.2 S, 2 points behind First. Here is a link to the videos ROLANDROCKSHOP made of the comp. |
![]() | #127 |
Eddie....I dont think anyone would mind you running that truck in the 2.2S at TSF. ![]() |
![]() | #128 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
I'm glad I got one of the bodiless rigs from T1E. We don't comp around here, but I like having the best performing chassis to start out a good basher 2.2 comp rig. I still don't understand why they are limiting it to bodied rigs only. Are they going to tell us that we can only run Hardline bodies next? Dumb.
![]() | #129 |
| ![]() With the National Championship approaching, this truck was due for some much needed attention and updates. First and foremost was making it USRCCA legal. I had a painted up lexan body sitting around the shop that I made use of for this build. I decided it was easier to just cut the rockshow cab off so that I could the base of it to strengthen the chassis. The entire chassis is delrin and Rockshow Mike had cut me a set of thinner sideplates & cab last year to reduce to weight. That thinner material is more flexible so incorporating the cab rails into chassis helps to strengthen it overall. ![]() ![]() ![]() ![]() |
![]() | #130 |
| ![]() Body Off Pics: ![]() ![]() ![]() ![]() Current Specs: Motor - Holmes Hobbies 45T Hand Wound ESC - Tekin FXR Pro 200amp Battery - Sky Lipo, 40C, 4S, 800 Mah TX & RX - Losikid Hacked GT3B Servo - Hitec 5955 TG BEC - Castle 10amp wired into the servo Axles: Front ; Axial plastic housing SDS Customs 300M Axial CVD's w/ locker Axial Over Drive Gear set with new 5mm round pinion (allowed me to remove the C.I. metal 5mm to 6mm adapter) Vanquish Products 8* Aluminum Knuckles & C's Lunsford Steering Link Modified VP knuckle weights Rear; Axial plastic housing Axial Aluminum rear lock outs w/ lead weight taped around it Axial straight axle shafts Axial Under drive gear set Axial Transmission with: Axial plastic trans case Axial Slipper spur gear assembly Axial top shaft & top gear BWD HD Motor Plate Crawler Innovations Transmission Outputs RRP Steel Idler RRP Hard Ano Output Gear Traxxas 4927X Yokes Traxxas 4951X Shafts Chassis: T1E Lunsford Titanium Links (Front upper, front lowers & rear uppers) Crawler Innovations Delrin Rear High Clearance lowers Current RTR Weight is: 5 pounds 2 ounces |
![]() | #131 |
Quarry Creeper ![]() Join Date: Dec 2008 Location: San Diego
how do those tires work? they look great ..
![]() | #132 |
![]() | #133 |
RCC Addict Join Date: Feb 2007 Location: LRC
Looks good Eddie...What kind of tires are those ![]() |
![]() | #134 |
![]() | #135 |
![]() | #136 |
![]() | #137 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
So the new tires mean you're no longer Mr Hybrid? "I have hybrid tires on every competition truck I own" "I drove the truck all season with the hybrid tires." I'll bet you did a "drive-off". Care to share? |
![]() | #138 |
| ![]() I ran the 2.2 Meat Grinders at Glen Rose Park where the Texas State Finals were held back in June. They worked really well at that location. I then brought the 2.2 Meat Grinders to the National Championship in September at Cherokee Rock Village and they did not perform well there. I ended up competing with a hybrid set of 2.2 Meat Grinder & Plowboy Hybrids. I am still using and testing hybrid tires.
![]() | #139 |
| ![]() SOLD to BigJeff1313 After returning home from the National Championship, Big Jeff made me an offer on this truck. After clearing it with my sponsors, Big Jeff is now the new owner. The timing was perfect because the entire truck had been gone through for Nationals. I placed 30th out of 42 drivers in the 2.2S Class at the National Championship. I made three mental mistakes in particular that cost me that day. The truck performed outstanding all day and it is the best performing comp shafty I have built to date. I already have another competition shafty in the works and it will use the same style T1E Shafty chassis but with AR60 axles this time. I will put up a build thread for it in the Ridgecrest section later. Thank you to everyone that followed this build thread and contributed ![]() |
![]() | #140 |
Sweet! Good to see it stayed in your club! ![]() |
