09-13-2010, 06:49 PM | #41 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I built my 4 link setups last night. I bent the links with a lighter to accomodate the angles of the 4 link plates. The caster in the front is about +4 degrees, and the rear is around +2 degrees. Also, yesterday, I ordered a BR-XL and a Team Brood Creep Type R 35T. Casey |
09-13-2010, 09:36 PM | #42 |
I just ordered some MIP driveshafts and a replacement axle housing with clockable Cs. Thanks TCS And, as of right now, this is the proposed wiring diagram I will use to setup my BEC and dual servos. Casey Last edited by KC_JoNeS; 09-13-2010 at 09:57 PM. |
09-13-2010, 10:29 PM | #43 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Looks good to me I got to say you win points for ingenious front link designs Some people say the cars do better with the links under the front plate, its just an idea so I dunno if you have tried it or not, just a thought. Tried clocking your knuckles back with your tubes or... not yet |
09-13-2010, 10:40 PM | #44 | |
As for the knuckle clocking...to be honest, I am just not interrested in it yet. Also, I just dont want my tires to be all up in my battery and servo. Casey | |
09-13-2010, 10:44 PM | #45 |
Gotcha, yeah everyone says it different. I take it as "tomato tomoto" Oooh man you don't know what your missing, the steering's way better due to the improved approach angle on the tires, now that's just me but whatever, just me. Time to turn more tubes at home... once I get a new M3x.5 tap, stupid mistake today broke it after like 40 holes, its like "really... misalignment not old age" did it in |
09-13-2010, 10:56 PM | #46 | |
As for the links, if I can squeeze the drag links under there with no issue, I will attempt to put the links underneath. Casey | |
09-13-2010, 11:02 PM | #47 |
Yeah clocking does "nothing" for movin the tires into your stuff... that's that. I found it worked good and i said guys like Gunnar... wouldn't go to such great engineering lengths if it was just a bunch of hokus pukus Well lets see... I was lining the tap up and I was in a bad mood/tired and it was a long spiral tipped TIN coated tap from McMaster... lets say it threads in... comes up and "wait is that a tap sitting on the part.... OOH NO done with tapping for the day " So there goes the rims for today, so now its called "do I nag someone to drive me to Travers to get my tools so we can save shipping " but ya, got to love snapping your own freeking tools |
09-13-2010, 11:07 PM | #48 |
My other issue would be with my tie rod. As it sits right now, my tie rod is just one hair away from my springs. If I attempt to clock any further, it would need a redesign. Casey |
09-13-2010, 11:15 PM | #49 |
Oh good point, forgot with BTA's its a mess with clocking... shims on the knuckles. Heck look what Gunnar did, and he just had a hacksaw and a blowtorch |
09-14-2010, 11:07 AM | #50 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
| I don't have a blowtorch, just a big lighter. Casey has enough smarts to come up with his own solution. My clocked steering still needs some work, but it's pretty close. It will be improved with some adjustments.
09-14-2010, 08:28 PM | #51 | |
[pushes the "Steering for Dummies" book under another book/] | |
09-14-2010, 09:01 PM | #52 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
i like your upper links. i was thinking that may be what i have to do on mine to keep my geometry where its at and keep the rod ends from binding on the 4 link plate. right now its preventing me from getting the articulation i want.
09-14-2010, 09:04 PM | #53 |
| On mine, it is a must. My steering goes right under the plate, and the plate angle is such that the links "must" have some bend somewhere. I accomplished something similar on my other Frogger build by using the bent ends provided by Axial. They look like the LOSI lower link ends.
09-15-2010, 05:52 AM | #54 |
Well, it seems I am nearly finished. It is just a waiting game for the final parts now. My axle shafts are stuck in customs, and will clear Friday. My wheels from B.A.M. will be in the mail within the next couple days. The BR-XL is ordered and being processed. The Brood Creep Type R (35T) is ordered and being processed. The MIP driveshafts are in the mail from TCS. Tomorrow, I will order up an SR300 receiver, and that should be it. Today: Installed JeepinDoug Spring cups filled shocks with oil finished the drag links (attached to the tie rods as I originally intended). I am happy to report I have nearly the same throw left and right. cycled and dialed in the suspension to where I want it. I love the stance! I think it should be about 2.5" from the skid to the ground. LOW AND MEAN! Last edited by KC_JoNeS; 09-15-2010 at 05:55 AM. |
09-17-2010, 08:12 PM | #55 |
Paul over at B.A.M. sent me this picture of my wheels. They are being sent out tomorrow. I think they will look awesome on this bad frogger. |
09-17-2010, 08:30 PM | #56 |
Quarry Creeper Join Date: Jun 2010 Location: Ravenna/ Sault Ste. Marie
| those wheels are sick
09-17-2010, 08:52 PM | #57 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
wow casey thats looking great and barney purple wheels cool. on a side note I have been well past busy I have spud day in shelley tomorrow I almost have my frogger done just have to put esc and rec in the rig then drive it! Last edited by rockerrc; 09-17-2010 at 08:55 PM. |
09-17-2010, 10:53 PM | #58 | |
| YEP! Paul does nice work. He has a vendor thread in the wheels section. Quote:
Spud day...that sounds like fun. I will see if my dad plans to attend. It will be cool to see what you do to solve your upper link issue in full droop. Get that sucker runnin. Casey | |
09-17-2010, 10:58 PM | #59 |
Today I received my 3Racing CVDs. It is about time. They had to travel a whole 50 miles to get to me from 3Racing, and it took 9 days. Stupid customs. Anyway, got the 3Racing CVDs installed, 3Racing hexs installed, and stuffed the front with 36/14 HD gears. |
09-18-2010, 12:47 AM | #60 |
I hope the pins for them don't take as long to get there Steering looks good Casey. Those wheels are sick, do they use SLW hubs? Looks like it. Last edited by gunnar; 09-18-2010 at 12:51 AM. |
