11-08-2010, 09:24 PM | #81 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Heavy? Haha....the aluminum blocks weigh nothing. The upper links? I will weight them tonight, but they dont weight that much. Casey |
11-08-2010, 09:32 PM | #82 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Yeah just me though. The one advantage of bigger rear D-links is you can tap the aluminum and use no nuts, more streamlined |
11-08-2010, 09:34 PM | #83 | |
Casey | |
11-08-2010, 09:35 PM | #84 |
OOooh gotcha, I thought they were stand alone units like the ones Juan sells, my bad then |
11-08-2010, 09:37 PM | #85 | |
We will see. Trial and error...trial and error. Casey | |
11-08-2010, 09:43 PM | #86 |
Trial and error, its all in a days work. Heck at least the titanium stuff looks bad, to bad its not to fun on tools to machine though |
11-09-2010, 06:23 PM | #87 |
So, this was the goal.... I still have a couple bugs to work out with the lower links and the shocks, but overall, I really like it. I measured the weight of the links, and they are 9.8 grams each. The total weight of the link mount, links, and hardware comes to 33 grams. Casey Last edited by KC_JoNeS; 11-09-2010 at 06:28 PM. |
11-09-2010, 08:02 PM | #88 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Very nice Casey, good work.
11-09-2010, 08:10 PM | #89 |
11-09-2010, 09:28 PM | #90 |
Wow the links and stuff are waaaay smaller than I thought, I was expecting it to be some huge unit, my bad then Judging by the image you should be fine threading into aluminum, just make sure to use a lil threadlocker and stuff should be fine maybe a radius or two on the edges would make it look nice n snazzy |
11-09-2010, 09:39 PM | #91 |
Yeah, the mount is tiny. It is 1.5cm by 1.5cm by 2.7cm. When I get some time in the next couple days, I will attempt the threaded option with some thread locker. As for cleaning it up...not quite sure what I will do to it yet. Casey |
11-17-2010, 05:55 PM | #92 |
I have been having TT issues with my Delrin lowers, as they are really fat and must be inboarded to clear the shocks. So, I placed an order to RPPHobby for some Lunsford Ti lowers and ends. The TT has been dramatically reduced, and it handles awesome now. The only thing that slightly irritates me is that my custom made uppers are thicker diameter than my lowers. Oh well. Casey |
11-17-2010, 09:47 PM | #93 |
Lookin good MR. Jones. you could always sleeve your lowers with a clear pen outer to bring up the thickness and still be able to see the shiney goodness of the TI
11-17-2010, 09:52 PM | #94 | |
Thanks Camo. I hear what you're saying. But, I will just leave it for now as the clearance is good and the Ti slides really well over things. Casey | |
02-23-2011, 10:56 AM | #95 |
Rock Stacker Join Date: Feb 2011 Location: inman
Nice rig makes me want to get one of those chassis for myself |
02-25-2011, 05:23 AM | #96 |
Rock Stacker Join Date: Dec 2008 Location: CARO
what did you use for the roof plate on your frogger looks sweet |
02-26-2011, 06:16 PM | #97 |
02-26-2011, 08:59 PM | #98 |
Casey, did you ever re-make the rear aluminum blocks with taped holes or not |
02-27-2011, 04:23 AM | #99 |
02-27-2011, 04:36 PM | #100 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
Like your roof Casey, wondered how you did that. I cut mine out yesterday out of 1mm lexan sheet and gently heated it to form the curve ( hair driers do have some uses)! Built one chassis up today just to get the feel of how it sits - very happy, just some tuning to remove the link / shocks interfering with each other, will be better when I go with a proper skid. You can add the Venom one to your STRC bin list - it's just the same. Well, worse actually, threaded and they don't even line up properly. I'm running stock length links, although looks like I may change the uppers, not sure yet. This chassis is a non-dig build, overdriven front, underdriven rear, mirrored tranny (shafts down the rhs) and four point linkage. Upper Links are above the plate. Steering is not BTA (yet), 3 racing cvds with Hot Racing "C's" and Knuckles. Electrics are nothing special, Rooster Combo (55T) and DX3e. I've set it up on 3racing shocks, running semi droop, they settle off the car at 113mm as the internal spring acts as a limiter but sit really low when built I've got differential rate springs on too, horizontally opposed across the body with the left rear /right front being one grade higher. I'm going to them out swap out for Losi 100mm tomorrow just to see the difference - they're on Losi golds. Looks to sit well. Will shake it down and then get the camera out once it's on the rock - you can add some UK gritstone to your international collection! |
