06-03-2011, 09:36 PM | #41 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
| You really cant go wrong with a tekin. I would choose a decent 35t. Brood makes a very nice motor as well as Holmes. I have ones from both and they have their ups and downs. If you don't want to spend an arm and a leg to get moving i would suggest the sport from holmes. Its priced less than an integy and is a solid performer. Avoid the tekins, novaks, integys and other cheapo motors as they are just not as solid as a nice as a "built" motor. Next time I see ya I will open the Holmes motor to full tilt for ya. We have a nice custom Brood I had built also you can check out.
06-03-2011, 09:37 PM | #42 |
Rock Crawler Join Date: Jun 2008 Location: Grants Pass OREGON!
okie dokies! thanks for the tip on the pinion,BUT i might not run the ax10 tranny will possibly make a XR10 frontside jones tranny for the poison dart.
06-03-2011, 09:45 PM | #43 |
got any brood links? would like something that will last me a little while,lookin at HH right now tryin to fing broods too. Last edited by Mr. crawl; 06-03-2011 at 10:04 PM. |
06-03-2011, 10:07 PM | #44 |
| For sure http://teambrood.com/catalog/product...roducts_id=125 and a link to an ass kicking battery http://www.cheapbatterypacks.com/pro...Lipo-Pack.aspx That motor is gonna give unreal low end control that will be amplified by the lower gearing of the fsj tranny. The only down side is the 4 mag can is lack of drag brake, but with your lower gearing the weaker drag brake will not be an issue. I would run close to the lowest gears you can on the tranny and feed it off 4s lipo. So in recap you would have unbelievable low speed control, instant spool up, axle breaking torque, and wheel speed to make people wonder WTF? You do need to recap the tekin for safe 4s use though |
06-03-2011, 10:09 PM | #45 |
06-03-2011, 10:14 PM | #46 |
I love that recap HLC!! gonna go with the motor you posted,and not sure if my old duratrax ice intellipeak charget can handel a 4S pack do you? FXR SPECS: Input Voltage: 4-9 Cells/2-3S Lipo Motor Limit: 12 turn On Resistance: 0.0012 ohms BEC: 6V/3A Dimensions: 1" x .8" x .4" (25mm x 20mm x 10.2mm) so is the FXR PRO any much of a difference in performance? Last edited by Mr. crawl; 06-03-2011 at 10:21 PM. |
06-03-2011, 10:26 PM | #47 |
1-10 NiCd or NiMH cells, and 1-4 lithium-ion (Li-Ion) or lithium-polymer (Li-Po) cells for that guy. Not a bad unit either. she gets the job done but is a lil tricky to use. http://holmeshobbies.com/product.php...0&cat=0&page=1 This motor in a 16t on 4s is a freeking rocket ship also. Only reason I have been using brood motors lately is because eddie is just a nice guy to deal with. He will answer my questions and help get you set up and happy. When I got a personal phone call from him was the day he sold me as a customer. |
06-03-2011, 10:30 PM | #48 | |
06-03-2011, 11:14 PM | #49 |
yeah the only difference between the fxr and fxr pro is the pro will run a 10T on 0.0006 ohms,not a plus for crawling indeed. so i have a huge list made up on RPP,if everything goes to plan i will order the whole list tomorrow The list: Castle Creations BEC 10A Switching Regulator Racers Edge ALUM PRO SERVO HORN SS HITEC BLACK Tekin FXR ESC FWD/BRK/REV Futaba 4PL 2.4G FHSS w/R2104GF Rx Axial HEAVY DUTY BEVEL GEAR SET 43T/13T Hitec RCD HS-7950TH Mega Torque Ti Gear Digital Dual BB Vanquish Products Incision XR-10 Axle Motor Plate Black Vanquish Products XR-10 Incision XR-10 Axle Transmision Case V1 Black RC4WD XR10 Hardened Steel Replacement Gear set Rpp Hobby 5x11x4mm Rubber Sealed Bearing (1) Rpp Hobby 10x15x4mm Rubber Sealed Bearing (1) FELSENFEST NO SLOP spools 3racing CVDs new SS hardware Brood Creep Type HHK-R/T 35 Turn and thats it til the 36/14 gears are back in stock for the front axle. |
06-04-2011, 09:07 AM | #50 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Hey, Can you just order up 2 FXR's and 2 Brood motors and send one of each too me. LOL !
06-04-2011, 09:15 AM | #51 |
lol gotta take that up with my wife,shes already a little P/O at the high end choices i made for this build. On a side note I'm bored and excited at the same time,So I made up some delrin UL to your specs,90mm front and 110mm rear Last edited by Mr. crawl; 06-05-2011 at 01:35 PM. |
06-04-2011, 09:43 AM | #52 |
Before you are to set on link length you might wanna consider switching out those problematic Axial rod ends. If you are gonna be comping with it I would look into some Traxxas ones Like this for uppers http://www.amainhobbies.com/product_...rce=google_ext And for lowers, Revo rod ends are a must have for any comp truck. http://www3.towerhobbies.com/cgi-bin...&I=LXHGB7&P=FR This small upgrade will save you so much problem and frustration in the long run |
06-04-2011, 11:39 AM | #53 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
For the upper links, the axial ends are no issue at all. But, the lowers you will be receiving need Revo ends. Casey |
06-04-2011, 11:47 AM | #54 |
Revo rod ends are in the mail already,I have some of the first ones I'll swap them over asap I'm sure there's enough adjustability between the chassis and VP 4 link plates it shouldn't matter that much.
06-04-2011, 01:51 PM | #55 |
man its like christmas over here for me,sold my bike engine so im goin on a little spree. so ordered axial cvds,UD and OD gears,hitec 7050th,10A ccbec,servo horn,VP SLW V4 black wheels with blue beads and .600 spacers,tekin fxr, VP XR10 black alum tranny case,axle bearings. about to order the Brood motor,4pl Tx and rc4wd hardened gear set for the XR10. this should be a fun build with all new parts and mostly gonna be here at once. |
06-04-2011, 07:00 PM | #56 |
No chassis yet. Come on Monday! |
06-05-2011, 01:42 PM | #57 |
Got bored some more and wrote up this exact list of this build I ordered up some FELSENFEST spools don't know when they will get here so me thinks those will be the hold up as far as assembly,NO AXLES=NO CRAWL. Also Its looking like im gonna be goin in a different direction on tires,plan to get the first set of meats custom tuned to my surrounding terrain. Last edited by Mr. crawl; 06-05-2011 at 01:50 PM. |
06-05-2011, 01:52 PM | #58 |
At least you can start the next chapter on the subject I am Jones'n to seeing The "Frontside Jones". Oh wait, you don't have the VP Dig on your list ?
06-05-2011, 02:09 PM | #59 |
Yeah gonna focus on gettin him built and gettin the FSJ tranny figured out and modified to fit in the PD chassis cleanly,thats gonna be a bit down the road too so i should have the dig figured out and hopefully pictorialed before this things ready for any action. REEEEAAAALLLLYYY EXCITED tho,Never got the chance to just up and build a high dollar rc before let alone a comp ready rig. which is gonna be funny for any of you pros that get to see me run as im a total noob to comp class/style crawling,nor do i have any experiance using a dig so just try not to laugh to loud if your watching. Last edited by Mr. crawl; 06-06-2011 at 01:50 AM. |
06-06-2011, 06:11 PM | #60 |
| What was that ? Is it Santa or the Postman ? Is the package there ? I just checked the tracking # ! Where is it ? |
