08-01-2011, 06:47 PM | #41 |
Quarry Creeper Join Date: Jul 2011 Location: Monterey, CA
Kinda torn between the gc3a chassis and the fastback II....
08-01-2011, 06:55 PM | #42 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
08-01-2011, 06:59 PM | #43 |
08-01-2011, 07:04 PM | #44 | |
Well you want a 50/50 chassis {like yours now} or a 60/40 {Fastback.} Ive driven both, both are nice, that's that Ok on my home-made 60/40 it was nice and the fun feature was if you were good at it, you could slam the gas with the wheels turned and "dig" the rig without a dig or alt. gearsets. Go with your gut tho, they got their ups and downs, I stuck with 50/50 but im thinking of a 45/55 chassis | |
08-01-2011, 07:06 PM | #45 | |
08-01-2011, 07:37 PM | #46 |
Here's how I see it: Gc3 comes with links and plates (yaay) It is a 50/50 It uses a body Fastback needs links/plates It is a 60/40 It doesn't need a body! My $.02: the fastback is super duper slick! So I'd go there personally but I can make me own links in my sleep plus Juan is a super nice guy that I've dealt with |
08-01-2011, 07:43 PM | #47 | |
JUAAAAANNNNN! stop that shipment I'm adding a fastback to it!!! | |
08-01-2011, 08:08 PM | #48 |
Good man! If you need links yell at me and I'll see if I can do something I can't wait to see this bad boy done |
08-01-2011, 08:14 PM | #49 | |
thinkin' I might like some lower Ti links and aluminum uppers........ I might hit you up. when I'm ready to switch everything over. | |
08-01-2011, 08:16 PM | #50 |
08-01-2011, 08:19 PM | #51 |
08-01-2011, 08:27 PM | #52 |
08-01-2011, 09:24 PM | #53 |
08-01-2011, 09:29 PM | #54 |
It will... That's the conundrum to deal with, that's that!
08-03-2011, 10:40 PM | #55 |
Things to do to get ready for sunday, assuming all my parts come in.
And hope like hell everything works properly. |
08-03-2011, 11:26 PM | #56 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
Take some pictures!
08-04-2011, 02:29 PM | #57 |
Wow quite the list! I think you can do it in time I agree with pictures! |
08-06-2011, 02:41 AM | #58 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
oh man, i cant believe i didnt see this thread. this is awesome!! |
08-07-2011, 06:37 PM | #59 |
| Yes sir! Updates... Finally... Sorry! All taken apart Fastback II built up Installing motor/tranny I had issues with the mounting location... Clearanced the motor a bit... Still not enough to run anything larger than a 14t pinion... Need to talk to Juan about this. Edit 8/11/11: The problem is motors that are 1.9 inches (I.E. motors with sealed end bells like the factory axials) weren't intended to be used with this chassis, the holes are drilled perfectly the problem is the motor choice. I temporarly solved the problem by shimming the tranny up with 2mm hard rubber washers that were included with my big bore shock kit. Last edited by Crawford; 08-11-2011 at 10:47 PM. |
08-07-2011, 06:48 PM | #60 |
Got the rear linkage in roughly the right length, need to adjust for the crappy pinion angle. Front upper & lower links made up. pinion angle also incorrect here too, adjusted later, made the gap between the inner ends of the revo's 53mm. Also bent them in after realizing that inboarding the lower shock mount & link caused clearance issues & binding at roughly 30 degrees of front axle articulation. Stopped for a break after Getting the electronics mounted how I wanted them. Or thought I wanted them. Receiver is mounted underneath the underground sticker with the antenna going back inside the loom. Mounted back there so I don't have to deal with a huge bundle of wire or remaking plugs. Local Inkdaddy66 made me up some "RAMRODS" out of tool steel. MAS BEEF. (Think beef toobs) Fit was absolutely perfect. No modding required, actually held my broken C-hub together quite well today without and issues. Inkdaddy66 will also be making me a set of C-hubs. They're in the works. After seeing his C-hubs today.... I'm excited. Last edited by Crawford; 08-07-2011 at 06:50 PM. |
