08-06-2012, 07:34 PM | #81 | |
| Re: Badd's 2.2s say what ? Quote:
08-06-2012, 09:45 PM | #82 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
Well I got a few mins to work on my new drive shafts tonite . What I did was take a well used but straight Axail 98mm link and cut my some pieces . Everyone has some of these laying around, so it is a cheap mod . The two pieces where 1 3/4" long . I cleaned up the cut marks with a file . I then put a drop or two of oil on the peices and taped them into the male side of the wild bores . Even with the alum. piece they are very light . For those that don't know why I did this . I did it in hopes to keep the shafts from twisting . some pics of the mod wild bores before mod 29 grams after the mod 31 grams the JunFac shafts 48 grams |
08-06-2012, 09:51 PM | #83 |
Nice, I will be interested to hear how they hold up |
08-06-2012, 09:54 PM | #84 | ||
As for the me part man I'm rusty as can be . I'm not sure I can drive this rig as good as it needs to be drove . As for the S class, heck yes it was a great move . I have said my thanks to the power that be . Quote:
But I will keep that in mind if I have a problem . thanks | ||
08-07-2012, 07:35 AM | #85 |
08-07-2012, 07:46 AM | #86 |
I ended up changing the arm out in my motor . The 13t 5 slot had all kinds of power . The wheel speeds was great . The lowend startup was not as good as I wanted . But I had it done for a class 3 scale rig . So lowend start up was really not needed . So I got John to make me up a 30t arm to go in my can . I will post up later on how it does . Sent from my SCH-S720C using Tapatalk 2 |
08-07-2012, 07:59 AM | #87 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
I dunno Andy, "Johns arm in your can" may get people whispering JK rigs looking good, whats she weigh now? |
08-07-2012, 08:04 AM | #88 | |
As for the weight I'm not sure my links are in Pell City . I hope to have the new ones here early next week . Sent from my SCH-S720C using Tapatalk 2 | |
08-13-2012, 04:10 PM | #89 |
My new Tie links came in today . Big thanks to Nick (BTF) for getting them done so fast for me . I got him to do the front uppers/lowers and rear lowers . The rear uppers I where using are alum. so they are light . old front uppers new front uppers old front lowers new front lowers old rear lowers new rear lowers Slowly losing some weight here and there . I hope my lockers make it in this week . I'm pretty sure that will put me under the 5lbs mark . |
08-16-2012, 10:11 PM | #90 |
I got my felsenfest spools in today . These are some very nice pieces . They are vert light weight . I will post the weight of the Stage 3 lockers amd the new one when I pull the axles apart . I'm sure with these the rig will be in the 4 lbs range . Sent from my SCH-S720C using Tapatalk 2 Last edited by Badd; 08-17-2012 at 08:11 AM. |
08-17-2012, 11:15 PM | #91 |
The Stage 3 lockers where 47 grams . The new lockers are 12 grams with the 4 set screw for the axles . Now that is a big difference . New RTR weight 4.91 lbs My goal has been to get this rig under 5 lbs RTR . Looks like I made it, but darn . Light weight cost money to go slow or go fast . lol |
08-19-2012, 08:49 AM | #92 |
Parts list (update 07/25/12) chassis SC-1 proto Not using the axle link mounts with the chassis . custom front and STRC rear plate Links T1E bent and cut to my specs . front uppers and lowers are tie rear lower are tie rear upper are homemade alum . straight Traxxas 5355X alum. Hollow balls threw out . Traxxas Revo rodends shocks Traxxas Bigbores shock cap mod (done with T-maxx rodends) jeepindoug mini T cups mini T red springs on front with 4mm external limiters on the fronts mini T red springs on the rear with 4mm external limiters on the rears and 2mm inside front axle AX-10 case 36/14 (2.5714285) hardend gear Fesnelfest spool Avid bearings XR-10 vanquish products knuckles and Cs XR-10 inter shafts Home made steel Mid tubes Home made BTA sterring Blue Monkey XR-10 knuckle weights Blue Monkey super20tuner kit rear axle AX10 case 43/13 (3:3076923)hardend gears Fesnelfest spool Avid bearings stock lockouts and straight axles trans . Hot Racing alum. gears Stage 3 outdrives NO slipper clutch 87 spur gear Avid bearings Heavy duty motor plate (unknow marker) drive shafts Wildbore with alum. rod pressed inside the male shaft . motor 30t Holmes Hobbies Crawlmaster 13 tooth pinion ESC Holmes Hobbies BRXL (decased) with 10amp castle BEC set at 6v servo JR8711 Wired straight to the bec . Crawler Innovations servo protector drill to remove weight . RX/TX (decased) DX3R / SR3000 (only using 2 channels) wheels Mayhem Evolution front 1" rears 1" hub sizes changes I have 4 setsof hubs tires White Rovers siped a lot foams Crawler Innovations closed cell duel stage Hardline body Painted by me pearl white with metallic black . |
09-07-2012, 09:05 PM | #93 |
Well the little rig done good at Nationals . First course I had a -4 , second course I broke the locker . Yep the locker, that locked up the front axle . It was before gate one so 40 . Third course -12 & forth course -2 . I think I ended up in 20th place . I was happy with the rig and my driving . But I was not happy with the set screw locker . Let us say there is some alum up on the Mnt . Oh yes I didn't try any of the bonus gate . My goal was to finish all courses . But that locker messed that up . lol sent from my cordless walkie talkie thingie . |
09-07-2012, 09:18 PM | #94 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
the felsenfest locker f***ed up? damn sorry to hear that man. i have ran a few of em and never had an issue, sucks to have it happen at a time like that. i have been paying close attention to your build thread im thinking sporty is gonna be my next build. sweet little truck man |
09-09-2012, 10:55 AM | #95 | |
sent from my cordless walkie talkie thingie . | |
09-13-2012, 08:05 AM | #96 |
Well this rig was a blast to build . It was even more fun to take it to Nationals and hang out with old friends and make new ones . But now I remember why I walked away in 2009 . It is just to hard on me to try and keep up with a comp rig . My health is not where it needs to be . It has took me all week to get over last weekend . With that said this rigs has a new home as of this morning . I don't think I will be building another comp rig anytime soon . Thanks to everyone that help me get back up to speed . It was fun !!
09-13-2012, 08:06 AM | #97 |
It was good to see you Andy. Who bought it?
09-13-2012, 04:07 PM | #98 |
09-13-2012, 05:03 PM | #99 |
| Re: Badd's 2.2s say what ? :flipoff : |
09-14-2012, 10:57 AM | #100 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
| Re: Badd's 2.2s say what ? Dang that's a shame Andy but you gotta take care of yourself. It was great to see ya again. If you need anything give me call or pm me here. I aint going anywhere. also if you feel like every coming to another comp to hang out, you can drive my truck. I am sure you will place it better than I can |
Badd's 2.2s say what ? - Similar Threads | ||||
Badd's K-5 Blazer | Badd | 1.9 Scale Rigs | 399 | 06-17-2011 09:18 PM |
Badd's K5 Blazer | Badd | Scale Videos! | 15 | 09-09-2009 03:38 PM |
Four.0h (Badd's Berg) | Badd | EnRoute Berg | 89 | 05-28-2009 10:15 AM |
Badd's OCM | Kamikaze | Videos! | 19 | 06-07-2008 03:09 AM |
