Thread: Maxx Shafts made easy.
Old 02-27-2008, 12:48 PM   #1
R.I.P. Chip
jason's Avatar
Default Maxx Shafts made easy.
Sitting at the shop a few weeks ago I was trying to figure out how to put Maxx shafts onto my Scorpion without having to drill the outputs on the tranny or the pinions. Bender told me about a way that a few of the other Colorado guys had been doing it and it sounded perfect.
I decided to snap pics so everyone could see this simple mod.
First pic is the stock Axial steel yoke and a stock Maxx yoke.
jason is offline   Reply With Quote
Old 02-27-2008, 12:49 PM   #2
R.I.P. Chip
jason's Avatar
This next pic show the first step, cutting the ears off the stock Axial yoke. I used my lathe, but you could use a Dremel or even a hacksaw.
Old 02-27-2008, 12:50 PM   #3
R.I.P. Chip
jason's Avatar
Now you can see the modified Axial yoke sitting next to the stock Maxx yoke.
Old 02-27-2008, 12:51 PM   #4
R.I.P. Chip
jason's Avatar
Next you need to drill the hole in the Maxx yoke out with a 29/64 bit. Once again I used the lathe, but you could just use a drill.
Old 02-27-2008, 12:53 PM   #5
R.I.P. Chip
jason's Avatar
Once you get the Maxx shaft drilled out you can slide the stock Axial yoke right into the Maxx shaft. You can see here it's read to go together.
Old 02-27-2008, 12:54 PM   #6
R.I.P. Chip
jason's Avatar
Here's the last pic showing it all going in. You can use 2 3mm screws on each shaft. They just pass through the Max shaft and thread into the Axial yokes.
Old 02-27-2008, 12:58 PM   #7
Nice write up. Im sure alot of people will benefit from this.
Cslax06 is offline   Reply With Quote
Old 02-27-2008, 01:05 PM   #8
Excellent tech Jason.
If anyone needs some Hex button head screws for this, LOSI has some that work great. http://www.horizonhobby.com/Products...rodID=LOSA6238 They are the gold screws in the link.
Rubbaneck is offline   Reply With Quote
Old 02-27-2008, 02:31 PM   #9
ghetto fabulous newbie
Nice write up Now I may have to put revo shafts on my Ax10 the same way
What Kind of lathe is that??
yotachump is offline   Reply With Quote
Old 02-27-2008, 02:49 PM   #10
It look s really good. But I was wondering if you had to grind down the max sized yoke on the transmission end so that it wouldnt rub you spur gear?
Biscuit is offline   Reply With Quote
Old 02-27-2008, 10:52 PM   #11
2006 2.2 National Champ
BENDER's Avatar
You can grind the OD of the Maxx shafts down a little to clear the spur, or go to a slightly smaller spur and be done.
I just ground the yoke a little, you may need to grind the end of the yoke so it clears the AX10's tranny housing too. Here's a link to my install.
My latest SW3 build........Good-bye Bug, Hello Grappler
BENDER is offline   Reply With Quote
Old 02-27-2008, 11:34 PM   #12
Jason awesome mod my friend... is that a 3-in-1 machine you have there??... if so I have one also and love it to death...
HauntFreaks.com is offline   Reply With Quote
Old 02-27-2008, 11:37 PM   #13
great write up, simple but super effective, nice
tat2INDY is offline   Reply With Quote
Old 02-28-2008, 09:52 AM   #14
[HOONIGAN]
Wrecker's Avatar
Good write up J.
Rubbaneck told me about this when I switched over to maxx shafts a while ago, I've been running it ever since and it works great!
btw, that's a pretty sweet new RCCrawler.com logo.
Wrecker is offline   Reply With Quote
Old 02-28-2008, 04:00 PM   #15
no talent hack
do you know the part numbers by any chance?
edit:
is this right 4928x for yokes, and 4951x for sliders?
Nabil is offline   Reply With Quote
Old 02-28-2008, 10:38 PM   #16
Reminds me of the black market bikes logo
Old 02-28-2008, 10:49 PM   #17
TEAM MODERATOR
Reflection's Avatar
Like Bender stated,you could grind them down. Just for an example though....I'm running Revo shafts on my Axial tranny and a 81t spur. There is about 1/16" between the two. Stock being an 87t spur,I doubt it'd take much smaller spur to clear the Maxx yokes.
Reflection is offline   Reply With Quote
Old 02-28-2008, 11:00 PM   #18
How will this work with tlt steel yokes ?
drumbeater is offline   Reply With Quote
Old 03-04-2008, 09:03 PM   #19
yeah anyone tried that yet? im also curious
Got Rocks? is offline   Reply With Quote
Old 03-15-2008, 07:56 PM   #20
Try looking in the TLT section, I saw a similer article using TLT drive cups with Revo shafts.
Thorsteenster is offline   Reply With Quote
