04-21-2014, 04:02 AM | #41 | |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
| Re: Dravpnir's NCD's SuDu One FL Quote:
why not make some nice carbon lower links ;) | |
04-22-2014, 01:07 PM | #42 | |||
DravTech Join Date: Aug 2012 Location: Sweden
I sent Tomi the new drawing for half an hour ago, so it should not be long I hope Hmm.. there it is again... do people actually drive with their crawlers? Just silly... Quote:
Even though I dont drive much... I like to have the option to replace worn out parts atleast Quote:
This is how they look on my sporty I will look over the option to have the raw aluminum surface coated black. It would look much better imho. | |||
04-22-2014, 02:14 PM | #43 |
Rock Crawler Join Date: May 2009 Location: Calgary
I like the contrast between the aluminum and CF. |
04-25-2014, 11:32 PM | #44 | |
RCC Addict Join Date: Oct 2008 Location: Finland
Thanks Tobias for working this out! Tomi | |
04-28-2014, 03:52 PM | #45 | |
Thanks Tomi! I didn't have any time to look at the parts today, but hopefully tomorrow or on wednesday. | |
05-02-2014, 04:56 PM | #46 |
Like I mentioned before I got a little package from Tomi the other day. The CF sway bars mount seems very good Tomi also milled a electronic plate for me. Before I sent Tomi the drawing I modified it a bit from my delrin version. I made it sligthly wider and tried to copy the design on the 4 link plate so it would look more uniform. Like the sway bar mount it fits very nicely. Thanks Tomi So now I have a roller With the body mounted Btw, if you noticed there is now a little blue star under my nick, so if you want a something "magic" in your chassis, look here |
06-03-2014, 01:26 PM | #47 |
I love the NCD RC4WD transmission, but feel a bit nervous about having an open transmission. So... this is something that I have been thinking about for a while and tonight I finally got time and energy to start to design it. It is a bit of more work to do, but my cover idea is atleast visible If people are interested and it works as I plan, I can offer these parts in my Shapeways store. |
06-03-2014, 01:48 PM | #48 |
RCC Addict Join Date: Aug 2013 Location: South East
Great addition to that piece..... I like the sound reducing of the housing and keeping gear grease where it needs to be. I saw a standard one a few months back and it sounded like a LNC transmission. This looks like a great idea......
06-03-2014, 03:37 PM | #49 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
If and when you make that cover I'll take one and a set of wands! Let me know when your going to start production! Great idea!
06-30-2014, 01:49 PM | #50 | |
Thanks for the support. I havent had time to get around and finish it, but vacations is near so hopefully I will have more time soon. | |
06-30-2014, 01:50 PM | #51 |
Some pictures from the Nordics 2014 thanks to Arttu Ahtiainen |
07-15-2014, 10:14 AM | #52 |
Time to increase the dlux density for this build! Pictures will come soon |
07-15-2014, 11:42 AM | #53 |
I've seen the pics.. Nice parts my friend!!!
07-15-2014, 01:39 PM | #54 | |
07-15-2014, 04:41 PM | #55 |
There, front axle atleast bolted together. There is still some work that is needed but I like what I see so far With the narrowest SLW hubs (350) I get around 10.8 - 10.9" in width with LaaLaa Rovers. The servo only sticks down a little bit under the axle tube. Nice and low knuckles weights that sits as far out in the wheel as possible |
07-15-2014, 10:20 PM | #56 |
Quarry Creeper Join Date: Feb 2014 Location: Chapel Hill, NC, USA
This has to be one of my favorite build threads. Such a nicely detailed clean design. Never seen a sway bar used before on a crawler. What purpose does it serve? I am also curious about your driveshafts. What are they? |
07-16-2014, 02:42 AM | #57 | |
The drive shafts is a propeller shaft from S.D.I 4x4. The sway bar helps to prevent torque twist while still allows you to use soft springs for the suspension. | |
07-16-2014, 03:26 AM | #58 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: Dravpnir's NCD's SuDu One FL |
07-16-2014, 05:27 PM | #59 |
| Re: Dravpnir's NCD's SuDu One FL Thanks The build is coming along quite nicely Around 10.8" wide in the front and 10.3" in the rear. The electronics will not be like that, I was just to lazy to solder it off the motor. I have also change side of the pumkin to better match up with the output shaft of the transmission box. I was able to just transfer the old lower links and drive shafts, but I got to make new upper links and links for the sway bar. Last edited by Dravpnir; 07-16-2014 at 05:30 PM. |
07-16-2014, 06:11 PM | #60 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Skins designed |
Dravpnir's NCD's SuDu One FL - Similar Threads | ||||
Dravpnir's 2014 "Standard sized" Berg | Dravpnir | EnRoute Berg | 108 | 08-16-2016 11:34 PM |
ZZR's Shafty...NCD's SuDu one FL | ZZR 1100 Racer | Axial AX-10 Scorpion | 178 | 03-14-2015 12:57 PM |
Fester's SuDu | FesterUK | Axial AX-10 Scorpion | 21 | 05-31-2013 09:50 AM |
Harvo's SuDu | Harvo | Axial AX-10 Scorpion | 37 | 05-02-2013 07:22 PM |
