04-18-2016, 07:33 PM | #61 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: JENS' SuDuOne FL 2.2 Shafty
Great work. I really like the body, but can you tell me with the cut you made, what is the total length of the body? Out local rule needs it to be 317mm (12.5"). Thanks. |
04-18-2016, 08:35 PM | #62 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Most international rules have been revised to reflect the changes made at the start of the USA season. 2.2S only requires an 8" body now.
04-18-2016, 10:33 PM | #63 |
| Re: JENS' SuDuOne FL 2.2 Shafty |
04-18-2016, 11:39 PM | #64 |
No idea, I don't write the 2.2 rules.
04-19-2016, 12:39 AM | #65 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
05-07-2016, 12:44 PM | #66 |
Second comp in the Norwegian series today,-and another win with the SuDuOne |
05-07-2016, 02:00 PM | #67 |
RCC Addict Join Date: Jun 2007 Location: Finland
05-17-2016, 11:53 AM | #68 |
Very happy with third place at New England Monster Showdown !! The rig is really doing well on the course : Sent from my iPhone using Tapatalk |
05-17-2016, 01:35 PM | #69 |
DravTech Join Date: Aug 2012 Location: Sweden
Way to go Jens! Congrats |
05-17-2016, 02:34 PM | #70 |
Rock Crawler Join Date: Jan 2011 Location: Portugal
Congrats!!
05-17-2016, 10:09 PM | #71 |
Very cool trophy....
05-28-2016, 02:58 PM | #72 |
05-28-2016, 04:30 PM | #73 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Congrats, looks like them axial axles are working much better for you! |
05-29-2016, 01:30 AM | #74 |
Pebble Pounder Join Date: Nov 2012 Location: Bavaria / Germany
Congrats Jens,you and your shafty seems to be a perfect combination |
06-05-2016, 11:54 AM | #75 |
06-18-2016, 02:46 PM | #76 |
06-27-2016, 05:28 AM | #77 |
| Re: JENS' SuDuOne FL 2.2 Shafty From the finals at Nordics,not that happy with the run..... Tore the right upper front link out of the rod end on the big fall at gate six,was able to continue,but run out of time..... Thanks Samu for the video :-) : Last edited by JENS; 06-27-2016 at 05:35 AM. |
06-28-2016, 12:47 PM | #78 |
07-01-2016, 10:21 AM | #79 |
Replaced the stock plastic front diff cover with a SSD alu one,-just cut off the lower lip to match the shaved pumpkin It's lower profile,-but maybe the alu will not slide so well on the rocks,-have to try it While the cover was off, I replaced the chromoly diff locker with an alu one from GPM,-may have to change it if/when it gets sloppy With the locker weight loss,-I added 18 grams of knuckle weight,-so RTR the rig is now 1493 grams or 3lb 4.66oz : |
07-02-2016, 02:19 PM | #80 |
Some Mod and Shafty action from our fourth Norwegian series comp Thanks for the video Hans Petter : |
JENS' SuDuOne FL 2.2 Shafty - Similar Threads | ||||
DravTech presents the SuduOne FL - 2.2 Sporty/Shafty chassis | Dravpnir | Chassis and Suspension | 29 | 09-24-2019 07:19 PM |
jens jeep | gooba | Axial AX-10 Scorpion | 7 | 04-27-2009 03:42 PM |
