Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX-10 Scorpion
Thread: Battery on Axle/ 4 link question
Old 07-11-2018, 03:40 PM   #1
Question Battery on Axle/ 4 link question
https://www.amainhobbies.com/st-raci...a30486s/p32730
Who all uses this plate?
I am wanting to get my battery on the axle since I don't have anywhere to currently mount it (hot racing chassis)
how much does going to 4 link up front do compared to the Y link?
Anyone have pics of the setup? any thread I find the pics have been hijacked by photobucket
What are other plates out there that will move the battery onto the axle?
sinat1 is offline   Reply With Quote
Old 07-11-2018, 03:42 PM   #2
snapon boy's Avatar
Default Re: Battery on Axle/ 4 link question
I used it a few years back.
149 r/c worx/scalerfab/team brood.
snapon boy is offline   Reply With Quote
Old 07-11-2018, 03:44 PM   #3
Custom Carbon Fiber
Robbob's Avatar
Other options
Destroy Front Axle
And RCBros makes a carbon one too. (i cant link this one from work sorry)
Robbob is offline   Reply With Quote
Old 07-11-2018, 03:46 PM   #4
snapon boy's Avatar
I currently use the part robbob makes above
Old 07-11-2018, 04:14 PM   #5
That's a nice setup. whats the benefit of mounting the servo like that?
What size lipo could I fit? I wanna run 3s if possible
any more pics of it with battery etc on it?
Old 07-11-2018, 04:15 PM   #6
I run the destroy plate too. It is great. Going to a true 4 link will make a big difference.
Side note Billet Works Design makes a couple different styles of these plates as well but I haven't tried them so I can't say whether they are any good or not.
here is the link for those.
Nightmare-S Wide Servo/Battery/Electronics Tray Kit for XR modded AX10 Axles - Billet Works Designs
AX/SCX LW Servo Mount - Billet Works Designs
Dezertdirt is offline   Reply With Quote
Old 07-11-2018, 04:31 PM   #7
Running the servo vertical will lower the cg, because it moves the heaviest part of the servo closer to the axle. It also will move the steering links up and out of the way. I used to run a fit a 1300mah 3s on mine. I got like an hour and a half of crawling on that. I wasn't really pushed for room. I tried a 2200 mah but but that was too long. Now I run a 450mah 3s because it is lighter.
I know these threads have good pics in there somewhere with batteries.
I always wanted a EVO..
Krazed Builds un-Stuck line into 2.2S
Little Winner, gettin UN-Stuck..
Old 07-11-2018, 06:22 PM   #8
this is a 1500mah 3s
Live it love it crawl it
tjsnyder is offline   Reply With Quote
Old 07-11-2018, 06:23 PM   #9
Sorry forgot to say that is on the destroy plate
Old 07-11-2018, 06:31 PM   #10
Btw if you have the stock battery tray from the scorpion you can drill a couple holes in it and make the same thing as the one you were asking about. I did that and ran it for a while and worked pretty good for free. I’ll see if I have any pics of it.
Old 07-12-2018, 07:09 PM   #11
That's the downside, mine didn't come with a battery tray at all lol
Sent from my SM-G930P using Tapatalk
Old 07-15-2018, 02:50 PM   #12
So I ordered the destroy plate. so on to the next question.
What do I need to get rid of the Y link and make it 4 link?
Old 07-16-2018, 01:27 AM   #13
'Most " after market plate come pre-drilled for the uppers, certainly the old VP, BWD and current RCBros plates are pre-drilled.
After that its a bag of rod ends, and some threaded links or allthread and cut and fit.
I use drinking straws which I cut to length between hole centres as best I can, then build the links to hat length, eye-to-eye.
I am using the RCBros Front 4-link plate and with the se
rvo under-mounted and and RX immediately above it can comfortably fit 3s430 packs, and probably up to a 1A pack on top.
stewbaru is offline   Reply With Quote
Old 07-17-2018, 06:26 PM   #14
well, all the screws, ends etc have been ordered. I used the list of parts from the STRC plate for the 4 link so we will have to see how that goes (hopefully one of the set screws also fits in the driveshaft)
Old 07-25-2018, 10:21 PM   #15
Plate is installed. was it supposed to come with spacers to go between the axle and the plate?
Also need some spacers and to make my drag link
Old 07-25-2018, 10:23 PM   #16
snapon boy's Avatar
Your set up looks correct. What wheel do you have?
Old 07-25-2018, 10:30 PM   #17
Stock AX10 scorpion wheels with 2.2 China tires
Old 07-25-2018, 10:36 PM   #18
snapon boy's Avatar
Looks like you have vintage voodoo tires. You need to space out your wheels some.
Old 07-25-2018, 10:36 PM   #19
It doesn’t come with spacers and I’m not sure if they are required but I did put one on mine on the servo side only. I figured with the torque of the servo it needs a little more support on that side. But like I said I don’t know if it is actually needed.
Old 07-25-2018, 10:39 PM   #20
snapon boy's Avatar
The distroy plate is fine like you have it. I ment you may need to widen the space between your front tires to clear the plate.
Battery on Axle/ 4 link question - Similar Threads
Question about link mount position on axle maverick67 General Crawlers 6 01-09-2018 12:51 PM
JR battery plate currie servo axle mounted question desertdude Axial SCX-10 1 07-09-2015 10:17 AM
front axle link question crazy nick Axial SCX-10 1 12-27-2013 08:50 AM
newb question re 4 link system and battery pack opsman Axial AX-10 Scorpion 3 01-24-2010 01:44 PM
