06-10-2012, 07:18 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Rob's sportsmen build going Gatekeeper
Well, I picked up a Ridgecrest on Friday for a Sportsmen build. Currently I am running an XR10, but I plan on selling this so I can have a crawler in the same class as my wife and son. My plan is to keep this a low budget build, and use as many parts as I can from my spare pile. I have some concerns with the axle width of the Ridgecrest, so I am not sure how well this will do. If it fails, I will dig out my old Warthog chassis and do the XR10 mod to some Scorpion axles. The only thing I have purchased for this is the Ridgecrest, and Axial XR10 aluminum C-hubs and knuckles. Ridgecrest Axial XR10 aluminum c-hubs Axial XR10 aluminum knuckles Axial aluminum shocks with delrin pistons, and purple springs Axial aluminum lower links from a Wraith kit Axial universal axle shafts XR10 wheels with HB Sedonas Old bug body that I ran on my LCC 1) Flip the shock mount and lower the COG. 2) Changed out the shocks 3) Changed out the lower links 4) Changed out the c-hubs and knuckles 5) I was going to make some upper links, but I found the 101mm 30 degree bent links with some short angle rod ends were the correct size. So I used these for the front and rear. 6) Make steering linkage!!!! This has been kicking but butt since 5:30 this morning. I cannot get my tubing bender to make the short tight turns. I have given up for now on that, I have to build some sort of a jig to get the bend to match the stock linkage. Last edited by rob5059; 10-14-2018 at 04:59 AM. |
06-10-2012, 10:33 AM | #2 |
| Re: Rob's sportsmen build
I got the steering linkage made, I think it looks like garbage but it is better than stock. This was my 5th attempt at trying to get made. I went digging through some parts bins for electronics. FRX with 45T or 35T motor. I am going to try the 45T first. CCBEC Hitec 5955 DX6i RX Last edited by rob5059; 10-14-2018 at 04:59 AM. |
06-10-2012, 10:56 AM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: chico
Good start keep it up |
06-11-2012, 04:10 AM | #4 |
Thanks
06-11-2012, 07:07 AM | #5 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Just curious as to why you would use this as a sportsman platform, I would think it would be much easier to start with your scorpion axels, and have this as a scaler?
06-11-2012, 09:43 AM | #6 | |
| Re: Rob's sportsmen build Quote:
I still have concerns about the width. It may or may not work out as a sportsmen, but half the fun is building and rebuilding to make how you like it. I can say right now that my sons AX10 performs better than the Ridgecrest. I need to lower the battery, maybe a servo battery mount. | |
06-11-2012, 04:03 PM | #7 |
| Re: Rob's sportsmen build This is exactly what I was thinking. If we all keep building with AX-10 axles, we'll all still be driving the same trucks next year, and the year after that, and the year after that.... For me, the Ridgecrest represented a fresh start with something new. It may not be the best platform to start with, but it's definitely interesting. |
09-07-2013, 07:40 AM | #8 |
| Re: Rob's sportsmen build Well it has been a while since I updated this thread. I have made a lot of upgrades to it, and I am pretty happy with its performance. All of the upgrades came from my Wraith that I was not feeling the love for. So here is how it sits right now. She is a little on the heavy side weighing in at 5lbs 7.7oz with the battery. Front axle: Axial knuckles Axial chub Axial CVD Axial lower link mounts RC4WD upper 4 link mount HR locker Axial 36T/14 HD gears STRC diff holders VP titanium drag link and tie rod STRC diff cover Rear axle: Axial straight axle lockouts Axial lower link mounts RC4WD upper 4 link mount HR locker Axial 38T/14 HD gears STRC diff holders STRC diff cover Transmission: HR harden gear set Axial machined motor plate Suspension: VP titanium upper and lower links Axial aluminum shocks with delrin pistons Axial orange springs on the front, 30W oil Axial purple springs in the rear, 35W oil Electronics: Tekin FX-R Tekin 35T Pro motor, 14T pinion CC 10A BEC Hitec 7955TG servo AR6210 RX Gens Ace 1300 2 cell Last edited by rob5059; 10-14-2018 at 04:59 AM. |
09-08-2013, 06:02 AM | #9 |
| Re: Rob's sportsmen build Well I decided it was time to try and loose some weight. I had a Gatekeeper chassis sitting in the back of a cabinet and figured I would give it a shot. The only thing I will be moving to the new chassis is the axles, tires and electronics. I had an AX10 non-slipper transmission with HR gears that I will use. I have it sitting as a rolling chassis right not. Nothing appears to be binding and the drive shafts just clear when you flex the chassis. I am still mocking up a battery/servo plate for the front axle. I have a set of VP Wraith knuckles on order, so I can try and get more steering out of it. Last edited by rob5059; 10-14-2018 at 04:58 AM. |
Rob's sportsmen build - Similar Threads | ||||
Rob's first scale build | dingo2010 | 2.2 Scale Rigs | 57 | 12-28-2011 09:02 PM |
Rob's SCX-10 | Rob Cote | Axial SCX-10 | 97 | 11-28-2011 07:28 PM |
G-Rob's Yota | grob23 | 1.9 Scale Rigs | 38 | 05-17-2011 05:47 PM |
G-Rob's Axial | grob23 | Axial AX-10 Scorpion | 20 | 06-18-2010 05:25 PM |
G-Rob's Latest | grob23 | Tamiya TLT Crawlers | 14 | 01-19-2009 10:35 PM |
