11-01-2019, 01:28 PM | #101 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: El Chivo Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-01-2019, 01:33 PM | #102 | |
| Re: El Chivo Quote:
I follow your thinking but the way the rest of the skid is designed the trans wouldn't clear up front and the motor would hit in the rear. The angle of the skid would also necessitate a much longer set screw to capture the links or just turning that screw for another 5 minutes to send it home. Then the links would clear but the skid would now be the lowest part and it would get caught on things worse. As it is a straight front lower provides a smoothish transition from link to skid. The issue was just that worthless hex they included on the rod ends for some reason. | |
11-01-2019, 02:11 PM | #103 | |
| Re: El Chivo Quote:
Integy C27400 (M4 Size Angled 28mm Length Ball Ends Type Tie Rod Ends, w/ 3mm Ball Links) Integy C27398 (M4 Size Angled 25mm Length Ball Ends Type Tie Rod Ends, w/ 3mm Ball Links) Integy OBM-1327 (Alloy Machined M4 Angled Long Ball Ends, w/ 3mm Ball Links)...thesew offered in black, gunmetal, red & silver I don't know if any of Therese would work, but I don't see why they wouldn't. They all fit M4 rods, and the ball IDs are for M3 screws. They're all angled...and NO hexes on the rod ends. I was looking for angled offset rod ends, but couldn't find any...they all seem to be 'straight', 'angled', or 'offset'. If angled-offset rod ends could be found, that would solve both "problems". ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-01-2019, 02:18 PM | #104 |
| Re: El Chivo
Or just take a razor blade to the hexes. I'm lazy so rocks did a fine job but took a while longer. |
11-01-2019, 02:55 PM | #105 | |
| Re: El Chivo Quote:
My dad taught me to use an X-Acto knife...think I cut myself more than I would have every done with a single-edge razor blade...lol ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-01-2019, 02:59 PM | #106 | |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
| Re: El Chivo Quote:
11-01-2019, 03:15 PM | #107 | |
| Re: El Chivo Quote:
The trick is figuring out the 95% garbage, from the 5% "decent" quality. For the parts I mentioned, I probably wouldn't trust the aluminum rod ends, as their "aluminum" tends to be somewhat on the "tin-ish" side (I'm sure you already know exactly what I mean)...but, as for the plastic rod ends, those should be more than good enough...not quite Losi-quality plastic (as mostly found in the Capra kit), but definitely better than RPM-quality plastic. ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 11-01-2019 at 03:19 PM. | |
11-01-2019, 03:41 PM | #108 |
| Re: El Chivo |
11-01-2019, 04:14 PM | #109 |
| Re: El Chivo |
11-12-2019, 10:53 PM | #110 |
| Re: El Chivo
And then this happened. Fully loaded but missing the body its 4.33 lbs rtr. Guess I need to get another set of brass dice from dlux for next season. I have a br-mini, brood conflux 30 turn and a savox 2290 going in it so it should have lots of woopow. |
11-12-2019, 11:21 PM | #111 |
| Re: El Chivo
Dang she's low! Are you keeping it that low with the skid lower than the pumpkins?
11-12-2019, 11:36 PM | #112 |
| Re: El Chivo |
11-13-2019, 06:23 AM | #113 |
| Re: El Chivo Well thats a weird place for the motor recommendation: Drop your fronts down one hole and run your rears lower at the axle. wise man gave me that suggestion about mine and felt much better his way. ( although I know you havent run it yet lol ) |
11-13-2019, 06:59 AM | #114 |
| Re: El Chivo
Don't tell me what to do! I'll tinker with it of course but its gotta be going first. Should have it up and running this weekend. |
11-13-2019, 07:05 AM | #115 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
| Re: El Chivo |
11-13-2019, 10:07 AM | #116 |
| Re: El Chivo |
11-13-2019, 12:54 PM | #117 |
| Re: El Chivo |
11-13-2019, 01:23 PM | #118 |
| Re: El Chivo Physical labor? Im ordering another Capra from santa for myself. This way I can go full comp driver on it and not tinker with my daughters. Little finger big throttle vs dad with big finger and smooth throttle |
11-15-2019, 04:42 PM | #119 | |
| Re: El Chivo Quote:
It's about time you got your own rig too! Ready for testing this weekend. . Not the bestest wiring job ever but it's all safe and secure. I have a bunch of these little 3s packs which will save the drivetrain but I do have some 4s if I decide to party. Last edited by WHITE-TRASH; 11-15-2019 at 04:45 PM. | |
11-15-2019, 07:38 PM | #120 |
| Re: El Chivo
I think my favorite part about portals is how high the tie rod ends up. Even centered on the housing its still over 1/2" higher than no portals.
