08-11-2018, 01:54 PM | #1 |
Rock Stacker Join Date: Feb 2016 Location: Gorham, Maine
| Ar60 uneven gear mesh
Started my axles the other night. Front no issues, rear I noticed a slight amount of in one spot. It does spin by hand, but 1/4 of the way around I can feel the teeth engaging. I marked my ring gear and its always the same spot. I did try a spare factory Axial carrier and new gasket with no change. Anything I should be concerned with or just run it and break it in? Im going to be running an 8th scale system anyhow so Im not concerned with overheating a small can motor. Once again its only enough where i can feel it when roling the pinion gear by hand. Thanks Pete |
08-11-2018, 02:15 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Ar60 uneven gear mesh
Both my axles had the same issue you are describing using the axial housings and LURC FI Spools. I did 3 rebuilds and added shims. After all this i still couldn't get it to be butter smooth so i kept them like that. I think my Bomber is noisy from that little binding but it's been running fine on 3s and a 21T brushed motor. I think my plastic axle housings are warped and the only cure will be aluminium housings. Sent from my Nexus 6 using Tapatalk |
08-11-2018, 04:27 PM | #3 |
The tolerances are rarely perfect all the way 'round... Run 'em in, it'll get better. |
08-11-2018, 05:04 PM | #4 |
Thats what I figured, Im pretty sure my Yeti did the same thing, and that hasnt blown up yet.
08-11-2018, 06:25 PM | #5 |
I chucked up the pinion shafts in a drill, ran them for a while in both directions... That way, if it is really bad you can sense it and let off the trigger, and open them up and re-shim if needed. Better than taking apart everything after running it as built. |
08-11-2018, 08:49 PM | #6 |
Could be a bent axle putting pressure on the diff. Chuck them up in a drill lightly and watch them out of the housing. Or roll them across glass to look for wobble.
08-11-2018, 08:57 PM | #7 | |
| Re: Ar60 uneven gear mesh Quote:
08-12-2018, 05:57 AM | #8 |
New assembly kit, no shafts in yet, more likely uneven run out on the ring gear it self since i changed indexed the ring gear and then changed carriers to a new spare I had in the parts bin.
08-12-2018, 10:59 PM | #9 |
Most likly it would only damage the ring and pinion any ways. I would still run them unless it's bad enough to cause enough resistance to heat up the motor esc. Since the fix sounds like a new ring and pinion any ways.
08-12-2018, 11:02 PM | #10 |
Oh the ring gear screws into the locker you could sand down the back side of the ring gear that's tight. I would put a micrometer on it first to check though.
08-15-2018, 09:32 PM | #11 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
Mine was the same way. Its now nice a smooth thanx to my castle 1410 3800kv motor. Every axial axle I've built has a spot where it binds while rotating the axle shafts. |
Ar60 uneven gear mesh - Similar Threads | ||||
Pinion gear and ring gear mesh question | flyboy320 | Axial Wraith | 18 | 01-09-2016 02:41 PM |
Gear mesh | rc crawler boy | General Crawlers | 12 | 07-29-2013 02:17 PM |
Gear Mesh? | Bansh88 | Newbie General | 16 | 02-07-2013 02:37 AM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
bevel gear, ring gear mesh | rocksteadily | Tamiya TLT Crawlers | 5 | 05-09-2009 12:04 AM |
