01-26-2013, 10:00 PM | #101 |
Rock Crawler Join Date: Nov 2009 Location: Etowah
| Re: Hoyt's HoNcHo
Rig looks great!! I just got the same interior for mine and am having trouble figuring out how to get it mounted inside the body. How did you mount yours, I was looking thru the build and couldn't see how you have it fixed?
01-27-2013, 12:22 AM | #102 | |
Quarry Creeper Join Date: Feb 2009 Location: Rockaway
| Re: Hoyt's HoNcHo Quote:
Velcro. Two small strips in the back and one on each oF the doors. Seems plenty strong to hold. Was gonna go double sided tape but went with Velcro instead. I will take some pics tomorrow to show. | |
01-27-2013, 12:13 PM | #103 |
| Re: Hoyt's HoNcHo
@greencrawler I use stuff called VELCRO (Industrial Strength), can be found anywhere really from walmart to homedepot. Some pics to go with the description above. |
01-27-2013, 08:17 PM | #104 |
| Re: Hoyt's HoNcHo I'm on my first scale rig so still trying to figure out all the tricks Thanks for the info and pics |
01-27-2013, 08:27 PM | #105 | |
No problem. | |
01-28-2013, 08:23 AM | #106 |
Newbie Join Date: Jan 2013 Location: Detroit
| Re: Hoyt's HoNcHo
Looking great!! Giving me some good ideas for my first crawelr... but also reminding me to take my time with the project! |
01-29-2013, 11:05 PM | #107 |
Rock Crawler Join Date: May 2009 Location: branchville
| Re: Hoyt's HoNcHo
hoyt this sat 11am the usual spot we gona show some new guys the spot plus i need to talk to you
03-18-2013, 03:25 PM | #108 |
| Re: Hoyt's HoNcHo |
03-18-2013, 03:36 PM | #109 |
| Re: Hoyt's HoNcHo
Got the truck out today before (hopefully the last) snow storm hits this afternoon. No breakage and some good rocks so all in all a good outing. The treps seemed to do just fine but I will need a couple more runs on them before making a judgement. It was cool today at 33 degrees so they seemed a little slick on some of the rock and the fronts are not weighted yet. Anyways heres some pics |
03-18-2013, 06:20 PM | #110 |
Newbie Join Date: Feb 2013 Location: Montreal, Quebec, Canada
| Re: Hoyt's HoNcHo
those beadlocks are HARD !
02-22-2015, 09:02 PM | #111 |
| Re: Hoyt's HoNcHo
Man I haven't touched this thread in almost 2 years. This truck no matter how many times I tear her down always gets resurrected. The honcho will never die. No changes to the body or cage at this time. May make a few cosmetic changes to the trug section when the weather gets warmer. Also want to repaint it to but that wont be for a while. This time around I decided to go with some performance enhancements. First up would be some RCBRO splined tubes SCX/width. Just gonna show a little bit of the work since this is my first time working with the shorter tubes. Went together fairly quickly and no setbacks. Cut the axle housings. Then dug into the xr-10 universals. flattening down and then cutting to size. Wanted to make sure everything was good before continuing. Im also trying the axial overdrive gear 36/14 up front (rear stock) to see how I like it. . Got everything back together including drilling the holes to lock in the tubes to the housings. I had a spare straight VP titanium tie rod from my now gone xr-10 days that I bent up. You will see that I am also using VP wraith knuckles and plastic wraith c-hubs. I still need to drill and tap for the c-hubs. And last but not least some new shoes. VP KMC'S Locked up hardware and some CI Deuces wild foams. Thanks for looking and hopefully more updates to come. |
02-23-2015, 09:39 AM | #112 |
| Re: Hoyt's HoNcHo
dam bro long time no see. your gona love the pit bulls. once it gets warmer out we gotta get together. there a bunch of us that crawl up in washington. check out mountain man crawling on face book |
02-23-2015, 10:29 AM | #113 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
| Re: Hoyt's HoNcHo
Brilliant!! Really liked this build and glad to see it's still about, look forward to future updates |
02-23-2015, 08:29 PM | #114 | |
thank you, right now I just want to get it back up and running and will go from there. | |
02-23-2015, 08:34 PM | #115 |
| Re: Hoyt's HoNcHo there now a hobby shop by me on 206 that has some crawler parts and hobbytown isnt in newton any more its on 206 in byram by the shop rite now. the place we run is up in washington at a guys house
