01-08-2012, 07:55 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: nc
| running 2.2 tires on a scx10
is it worth running 2.2 tires on a scx10, it looks awesome but does it do anything for performance
01-08-2012, 08:00 PM | #2 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: running 2.2 tires on a scx10
I ran PL Hammers on mine, the added ground clearance and extra width helped alot over the stockers. I wanted a more scale-ish look and picked up some Rox Lox (1.9) which are about the same height as Hammers. But it's your rig, run what you like .
01-08-2012, 08:03 PM | #3 |
what wheels did you run on your scx10 for the 2.2s
01-08-2012, 08:07 PM | #4 |
Stock AX-10 beadlocks, just cuz I had them laying around.
01-08-2012, 08:07 PM | #5 |
ok i think those r the ones i read that will work on that setup
01-08-2012, 08:30 PM | #6 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
like said before do what makes you happy if you think you would like it try it, see how it works if you dont like it go to something different! its all about what you like in this hobby do it for you buddy and then run it y-d-open ha ha |
01-08-2012, 08:55 PM | #7 |
Quarry Creeper Join Date: Jan 2011 Location: Kingston NH
2.2's will fit on the stock honcho wheels the 1.9's ?
01-09-2012, 01:30 AM | #8 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
im running 2.2 TSL/SX on honcho.. you'll have to lift the body or cut the body. no 2.2 tires wont fit on 1.9 wheels. im running the rockstar rims, they come in black or chrome. the stock ax10 wheels and stock scx10 honcho wheels are the same. but you have to buy a set of 2.2 wheels if you want to run 2.2 tires. i've also ran a set of 2.2 hammers on my truck and they are ok.. they are a smaller tire though.. personally im very glad i went to a 2.2 tire, i can take lines that i never could on my 1.9's.. they give you more ground clearance, wider tire, lots of sidewall rubber. always got hung up on rocks with my 1.9's and i can take the same line and not get hung up.. you can run any 2.2 wheel on the honcho as long as they have a 12mm wheel hex but watch the offset too.. i only have ran the rockstar's and the stock ax10/scx10 wheels. here's my setup, because i had to cut so much out of the body i made some inner fenderwells from a margarine container to hide the electronics. |
01-09-2012, 02:43 PM | #9 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
Another option is running a longer shock. This can limit up travel and keep the tires off of the body. I used some Wraith shocks with slightly trimmed Honcho body to fit 2.2 Ripsaws. |
01-09-2012, 04:28 PM | #10 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
The way i look at it (not saying it looks bad or anything) is that 2.2s are made for more scale comp buggies or something to that extent. If your running in lots of snow or mud, yes, the 2.2s will help.
01-09-2012, 05:24 PM | #11 |
heres a pic of my honcho on 2.2 going with axial beadlocks when they show but this is just a mock up
01-09-2012, 07:07 PM | #12 |
Rock Crawler Join Date: Oct 2011 Location: Warren
I like my 2.2's. Like others have said it is necessary to trim the body or lift thenbody. (I recommend trim.. lower COG) However, I don't think I can go back the 2.2's definitely improve the performance of the truck it can go many places the same setup with 1.9's cannot. For me 2.2 is the way to go.
01-09-2012, 07:42 PM | #13 |
i called axial today and it has to be the rockstars or 8 hole wheels because they have a different offset then the wraith wheels the wraith wheels will hit the suspension....im going to get the rockstars in black chrome
02-02-2012, 03:53 PM | #14 |
Rock Stacker Join Date: Dec 2011 Location: pell city
| Re: running 2.2 tires on a scx10 |
02-02-2012, 04:04 PM | #15 |
they're close. if you look at my previous post in this thread that is a stock scx10 honcho beadlock. got bored and since i just bought a set of sedona's for my ax10 and got them mounted i wanted to see what they looked like. here is a stock ax10 beadlock. jdacus- i'll take my rig the same place you do and i'll have way less troubles than you. running 2.2's compared to 1.9's is like night and day. |
02-02-2012, 05:36 PM | #16 |
Rock Stacker Join Date: Jan 2012 Location: Fuquay Varina
I love my 2.2 TSL's. It does take away fom the scale look as mentioned however I feel the increased mobility is worth it.
02-02-2012, 05:44 PM | #17 |
Quarry Creeper Join Date: Sep 2008 Location: Fab Shop
I like my 2.2's. |
02-02-2012, 06:16 PM | #18 |
i ran 2.2 for a while, but didnt like them, but im a fan of a more scale look, if you want it to perform better, go with them, if you want it to look more scaleish stay with some tall 1.9's i run irok's and they work great compared to the stockers and look great also!
02-02-2012, 06:16 PM | #19 |
02-02-2012, 09:23 PM | #20 |
Newbie Join Date: Jan 2012 Location: halifax
Scx10 1.9 wheels use the narrow 12 mm hex....ax10 wheels use the wider hex with a center nub. 2.2 PL hammers on the honcho, 2.2 HB rovers on the ax10.....and 1.9 ripsaws on my boy's ax 10....yup he wants his wheels back!
running 2.2 tires on a scx10 - Similar Threads | ||||
Running more than one stock RTR SCX10 | XcrawlerkidX | Axial SCX-10 | 8 | 01-07-2011 12:39 PM |
anyone running their scx10 on the sand? | eyeopenher | Axial SCX-10 | 8 | 12-16-2010 03:56 PM |
Anyone here running a 4 link setup on the rear of your SCX10? | BigB_117 | Axial SCX-10 | 36 | 07-12-2009 07:41 PM |
FRONT vs BACK TIRES - running different tires? | RyanTuomi | Tires and Wheels | 29 | 08-28-2006 04:42 PM |
