03-05-2013, 12:05 PM | #101 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Re: New Axial Rubicon
Its fun to do your j/k would be able.to do it.
03-13-2013, 10:14 PM | #102 |
Newbie Join Date: Mar 2013 Location: San Diego
Got mine and took it out straight out of the box. A few hours later and she was running fine.. I did move the battery forward and the parts to do this are in the bag of the RTR box. I used a promatch 4000 battery that me and the kids ran for almost 2 hours and still had plenty left over. Its light weight and very usable. Changed the gearing to 16x87 and that really helped the speed out of the box issue. Did some crawling sat and the battery forward really helped. I feel some dialing in with weights on the axils and in the rims might help take it to the next level.. My history - Nitro and EC buggy racing... Crawling is a whole new beast that requires some thought and is full of a TON of FUN.. 20130302_132252_resized by ChumminRob, on Flickr 20130313_190544 by ChumminRob, on Flickr 20130302_124322_resized by ChumminRob, on Flickr |
03-13-2013, 10:21 PM | #103 |
Has anyone gone to the Alum shocks for this setup? Im still using the stock plastic shocks from the RTR kit. I see it has dual shocks on it and the spacers are backed out 100%. I dont seen any benefit on moving the shock spacers down. Thoughts or point me to a thread that explains this. on the race cars, the shock springs are used for ride height and all the inerts are used to help with the suspension. With that in mind, are there upgrades to the Rubicon that I can look into? Thanks... |
03-15-2013, 10:25 AM | #104 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
| Re: New Axial Rubicon That's something I forgot to include in the thread... shock's! After hearing so many good reports on Traxxas "Big Bore's" and how well they hold oil, I decided to give a set a try on my rig. (My stock plastic shocks leaked profusely!) I used a set of Crawler Innovations spring cup adaptors and picked up 2 Losi MRC spring assortments so I can play around with tuning them... The shocks were about 15mm longer than stock, so I used short lengths of nitro fuel tubing internally (installed on shaft below piston) to limit the throw length close to what it was with the stock shocks. Haven't had a chance to run the rig with the new setup, but I think it's going to work out nicely once I get the spring and oil weight combo dialed in |
03-24-2013, 10:38 PM | #105 |
Found some free time so I worked on my rig a bit Today's mod's were mainly focused on installing the servo winch which was hand built by my buddy Mike @ my LHS including waterproofing and a custom machined servo horn spool I played around with mounting options above and below the surface of my J.R. plate looking for that sweet spot that would not interfere with my rig's steering, suspension articulation, ect., and ended up with this --> |
03-25-2013, 07:00 AM | #106 |
Quarry Creeper Join Date: Oct 2010 Location: West Melbourne, Florida
Awesome build, im keeping up with this one
03-29-2013, 09:37 PM | #107 |
Rock Stacker Join Date: Nov 2012 Location: South East Michigan
I have to say that looks great, i love the Black on Black paint scheme! how has the paint and the body held up? I have the same thinking as you pertaining to the silver body. I like the fender wells you have as well, i'm going to have to do that. I just ordered the axial beadlocks and MT Baja Claws. I also thought it was funny when i saw you used the grim racer speed grease, that's what i used for my axles. I'm making my tubes for the axles out of a plumbing part i found someone mention in a post. thanks for keeping this updated with good pictures! keep up the great work! I cant wait to see what you do next. |
03-30-2013, 11:13 AM | #108 |
Newbie Join Date: Mar 2013 Location: Cape Town, South Africa
very nice spray bud.. really like the colour with that rubi. well done
03-30-2013, 11:47 AM | #109 | |
Thank's for all the positive comments guy's! Quote:
03-30-2013, 05:31 PM | #110 |
That does look realistic, thanks for the pic!
03-31-2013, 07:31 AM | #111 |
Any up date on the finish of the winch?
03-31-2013, 11:34 AM | #112 |
Rock Crawler Join Date: Jan 2013 Location: Australia
I am curious on your thoughts regarding the performance of the shocks you put together. Cheers H2Micr0 |
04-02-2013, 12:24 PM | #113 |
| Re: New Axial Rubicon I am still in the process of relocating most of my wiring to the rear using a Radio Shack project box, so I have not actually used the new servo winch yet... I kept the RC4WD Warn winch on the bumper as a "dummy" scale-looking winch, and I ran the line from the new servo winch through the RC4WD roller fairlead. Also swapped out the (highly functional but ugly) hook that was included with the servo winch over to the less-functional but much better (more scale) looking RC4WD Kong hook On a side note, I did also have to raise the front body posts up 1 notch to allow the body to clear the servo winch housing... the body is now sitting a little higher than I would prefer, but I have a lot of weight down low on this rig so my COG should still be pretty good I hope... I wont know how it really performs until I get this wiring all cleaned up, and that part seems to be taking me forever to accomplish |
04-02-2013, 12:27 PM | #114 |
| Re: New Axial Rubicon |
04-15-2013, 11:25 PM | #115 |
Rock Stacker Join Date: Mar 2013 Location: Temecula
Awesome Build! just recieved my scx10 rubi kit today. i really like the looks of those rims and you cb antenna.
04-27-2013, 10:55 PM | #116 |
Thanks for the kind words Once again I have been lacking on updating this thread... too many pans in the fire I suppose... I got side-tracked with my Wraith Build and have been neglecting finishing off the Rubicon... finally got around to relocating the majority of wiring to the rear installed into a Radio Shack Project Box, still need to button things up - should turn out pretty clean when it's done |
05-10-2013, 09:40 AM | #117 |
Pebble Pounder Join Date: Jul 2011 Location: NorCal
Rig looks better and better every time you run it Any updates? |
05-10-2013, 02:16 PM | #118 |
Thanks for the compliments I did finally get all the wiring shortened/extended where needed and got everything mounted into the project box... BEC, lighting controller, ect., I also installed a micro-switch towards the front of the box from the inside to operate the lights... turned out nice and clean (better than my crappy pix can show - lol) and everything is functioning properly Still need to do some programming to the 4PL to get the winch working off one of the momentary rockers and then I will call it "done" (for wiring at least)... not as crafty as one of Mike Pham's wiring jobs, but still cleaner than most I see rolling around locally |
05-12-2013, 12:50 PM | #119 |
Newbie Join Date: Apr 2009 Location: New Brunswick
I may have to break down and finally buy one of these, nice job!
05-15-2013, 07:01 PM | #120 |
did the project box mount easily? thinking about giving that a try with mine. Still have my battery located in the rear.
New Axial Rubicon - Similar Threads | ||||
Harley's Axial JK Rubicon | Harley | Axial SCX-10 | 369 | 03-06-2015 08:31 AM |
New Axial SCX10 Jeep Wrangler Unlimited Rubicon Axial Promo Vid | B94Cast | Scale Videos! | 0 | 10-30-2012 12:20 PM |
New axial jeep rubicon | pajey | Newbie General | 4 | 10-30-2012 06:22 AM |
Jeep Rubicon body for my axial | bnoland | General Crawlers | 5 | 08-18-2008 12:54 PM |
Need pics of Jeep Rubicon Axial combo.... | JLOC | Newbie General | 20 | 12-05-2007 08:50 AM |
