11-11-2013, 08:50 AM | #61 |
| Re: eric113's Portal axle JK |
11-11-2013, 10:50 AM | #62 | |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
| Re: eric113's Portal axle JK Quote:
Thanks | |
11-11-2013, 10:53 AM | #63 |
11-11-2013, 11:17 AM | #64 |
Well mostly for the front axle, because the back axle shafts being stuck still allow for all bearings to be changed. But lets say for both axles, because I think, if i'm not mistaken, that you need to remove the axle shafts from the lockers to be able to separate the locker from the ring gear.
11-11-2013, 12:31 PM | #65 | |
The rear, take the locker and shafts all as unit, put the hex pin and hex on back on and samething pliers and hammer to lightly tap them out. | |
11-11-2013, 12:43 PM | #66 | |
When I get back home I will try it . Just to be shure, do you mean I should grip the axle shaft with pliers and then hammer the pliers whilst they are attached to the axle shafts? Thanks | |
11-11-2013, 12:46 PM | #67 |
11-17-2013, 06:42 PM | #68 |
Newbie Join Date: Jan 2005 Location: Houston, Texas
Good looking Jk! What's the wheelbase on it?
11-18-2013, 07:23 AM | #69 |
11-22-2013, 10:17 AM | #70 |
I've been able to remove (with a bit of force and two vice-grips ) the axle shafts from my lockers without damaging them . Now, I need to clearence them so they go in and out easily. What kind of sand paper did you use to do on yours? Thanks |
11-22-2013, 12:01 PM | #71 |
| Re: eric113's Portal axle JK I used a dremel with a sanding drum. Sand, and test fit till your liking
11-26-2013, 04:26 PM | #72 |
Newbie Join Date: Nov 2013 Location: littleton
| Re: eric113's Portal axle JK I've actually wheeled with this guy on several runs out in Moab during Easter Jeep Safari in both my old JK 4 dr on 40's and my buddies JK 2dr on 44's. Pretty fun to watch him go over stuff. But he doesn't wheel it hard. mostly a show pony. lol
01-27-2014, 06:22 PM | #73 |
01-27-2014, 06:24 PM | #74 | |
Anyway you could get me in-touch with the guy ? | |
02-01-2014, 10:31 AM | #75 |
09-14-2014, 04:19 PM | #76 |
09-25-2014, 10:43 PM | #77 |
10-01-2014, 06:33 AM | #78 |
Quarry Creeper Join Date: Jan 2011 Location: Waterford MI
| Re: eric113's Portal axle JK I have been wondering when you were going to be putting those portal boxes to the test. I really want to buy a set but I have been waiting on you to see how they turn out and hold up. Keep us posted Last edited by Honchoforever1; 10-01-2014 at 07:02 AM. |
10-06-2014, 07:36 PM | #79 |
10-06-2014, 07:41 PM | #80 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
eric113's Portal axle JK - Similar Threads | ||||
Gmade portal axle | Zrock | General Crawlers | 2 | 01-10-2016 09:01 AM |
eric113's 2nd portal Mog | eric113 | Axial SCX-10 | 11 | 03-22-2013 10:00 PM |
r1 portal axle bearings | 530_crawler | G-Made Crawlers | 4 | 03-17-2013 01:10 AM |
portal axle torque? | Duxx | G-Made Crawlers | 2 | 06-08-2012 10:10 PM |
