10-07-2014, 06:27 AM | #81 |
Rock Crawler Join Date: Jan 2013 Location: Australia
| Re: eric113's Portal axle JK.. now with curries
just feeling a little bit jealous over here... |
10-07-2014, 09:20 PM | #82 |
| Re: eric113's Portal axle JK.. now with curries |
10-07-2014, 09:26 PM | #83 | |
| Re: eric113's Portal axle JK.. now with curries Quote:
I haven't ran the Holmes yet.After reading,talking,seeing roc 412, I wanted to try one for my self. I just like the the idea of 4 pole motor. Holmes mentioned of a 4 pole he working on, I know I will want to try one out. I do have Holmes BL in my mog. Thanks and sorry. | |
10-08-2014, 07:38 AM | #84 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Damn looking good Eric, looks like you about got it ready for Crawlapalooza this weekend!
10-08-2014, 11:32 AM | #85 |
11-15-2014, 04:32 PM | #86 |
Small update. I beefed up WB8 driveshafts. I used a old aluminum link. I also have Gunnar pins installed I had a proto type Locked up Rc commando free spooling winch with the upgraded up motor for while . Install was easy and followed the directions I swaped to stainless screw.Addition to to free spool and motor, I used Maddogrc fairlead and hook. I also used Locked up Rc winch saver, Locked up Rc extreme winch line. Waiting for more parts to come in. Last edited by eric113; 11-15-2014 at 05:14 PM. |
11-24-2014, 05:39 PM | #87 |
11-26-2014, 10:47 AM | #88 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
Nice rig my friend. Love them Currie portals. |
11-26-2014, 07:29 PM | #89 |
Quarry Creeper Join Date: Mar 2014 Location: Loris, Sc
Awesome build!
11-27-2014, 07:39 AM | #90 |
11-27-2014, 07:49 AM | #91 |
I worked on it most the day yesterday and got he rear axle done. During mock up. I when back and counter sunk the screws that hold the lock out on. Little tip if you are drilling and tapping holes in delrin.Use a smaller drill bit and use the screw to cut the threads, it be tighter than using a tap. I also installed my JC link raisers, which also to work out since my upper links were little short. Before I called it a night. I got one omf's mounted. If anyone has tricks for mounting proline tires on the omf's please post up! Sorry for the crappy pics and messy work bench. |
11-27-2014, 07:23 PM | #92 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Another very cool build sir, all your builds are clean and unique. |
12-12-2014, 09:11 AM | #93 |
12-12-2014, 10:48 AM | #94 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Wouldn't the 2300Kv be a better choice than the 3100Kv being that you're running a 4 cell? You should swap out those link risers for the steel ones.
12-12-2014, 10:57 AM | #95 |
12-26-2014, 10:34 AM | #96 |
12-26-2014, 07:38 PM | #97 | |
Why should I swap the risers? Who makes steel risers? | |
03-01-2015, 09:21 PM | #98 |
Newbie Join Date: Oct 2014 Location: DFW Texas
How did u get the portals on the rear currie axle?
03-01-2015, 09:22 PM | #99 |
03-03-2015, 11:32 AM | #100 |
eric113's Portal axle JK - Similar Threads | ||||
Gmade portal axle | Zrock | General Crawlers | 2 | 01-10-2016 09:01 AM |
eric113's 2nd portal Mog | eric113 | Axial SCX-10 | 11 | 03-22-2013 10:00 PM |
r1 portal axle bearings | 530_crawler | G-Made Crawlers | 4 | 03-17-2013 01:10 AM |
portal axle torque? | Duxx | G-Made Crawlers | 2 | 06-08-2012 10:10 PM |
