04-12-2015, 04:15 PM | #121 |
Newbie Join Date: Apr 2010 Location: Homestead,Fl
| Re: DT's WranglAR - Just another Jeep
Looking good |
04-12-2015, 06:33 PM | #122 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
Geez DT, thats some carnage there |
04-12-2015, 07:30 PM | #123 | |
| Re: DT's WranglAR - Just another Jeep Quote:
04-15-2015, 05:33 PM | #124 |
Newbie Join Date: Feb 2015 Location: Chillicothe,Ohio
Dang hard landing. Seeing you Knight grill pop like a toothpick scares me and what could happen to my grill.
05-01-2015, 11:44 AM | #125 | |
I have a beater 1.9 truck to send up the hill now. I need to get the new body painted and grill setup soon, They are collecting dust in my workshop. | |
09-19-2015, 06:49 AM | #126 |
Pebble Pounder Join Date: Aug 2010 Location: claremont... for now
bad ass truck man!!!
09-22-2015, 10:25 AM | #127 |
Thanks!
09-23-2015, 01:20 PM | #128 |
Great build and thread. Thanks for all the pics and inspiration. I'm one step closer to swapping my AR60s into my JKU. I have to ask. With all the parts, money, and time put into building your rig strong with mips, beef tubes, HD gears, etc. why didn't you put more into the trans? You went with steel internals and mips but kept the flat spot style outputs with grub screws instead of HD outputs with through pin screws. Just wondering because I've seen this more than once.
09-24-2015, 09:38 AM | #129 |
| Re: DT's WranglAR - Just another Jeep I had all the trans stuff already, migrated from rig to rig over the years without failure. My outputs are hardened steel, not stock axial. They are just old school type from back when AX10's were fairly new.
09-24-2015, 12:38 PM | #130 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Hey what's that vendor that sells the plates you told me about, man? Need to order them up so I can get my rig going.
09-24-2015, 12:58 PM | #131 |
| Re: DT's WranglAR - Just another Jeep Are you talking about Tod Bldz's Wroncho plates? I have a set and they are awesome!
09-24-2015, 01:31 PM | #132 | |
09-24-2015, 05:24 PM | #133 |
He's in the vendor section. Really cool guy to deal with. I originally got these for a Wroncho build then the SSD D60s came out. I ended up using these anyway because they are great for anti squat and dialing in pinion angle perfectly. These plates are incredibly versatile and very nice quality. I'll just get another set for my future Wroncho build because they're so nice.
09-25-2015, 06:27 AM | #134 |
how do those work out for mounting the upper links? That's the issue I'm having with my Wroncho build....need a place to mount the upper link to the frame rails/chassis. They look amazing, though!
09-25-2015, 07:53 AM | #135 |
All of those holes in the plates are places to mount your upper links. Raising the mounting location at the chassis this way makes them clear the driveshafts and gives better suspension geometry at the same time. Plus you can move the upper link mounts forward or backward to dial in pinion angle as well. Let me get a pic up to help explain. There are also pics in his thread in the vendor section.
09-25-2015, 08:10 AM | #136 |
I looked....sold! We now return you to DickyT's awesome WranglAR build thread! |
09-25-2015, 08:12 AM | #137 |
Ok, here's a pic showing both front upper link mounts. You can see how they now run parallel to the lower links and stay above the driveshaft the entire length. Anti squat is also dramatically improved on climbing and descending. You can also rotate the axle by moving the upper link mounts forward or backward letting you achieve an ideal pinion angle.
DT's WranglAR - Just another Jeep - Similar Threads | ||||
DT's Viper II | DickyT | Videos! | 13 | 06-06-2012 03:33 AM |
DT's SCX Jeep JK | DickyT | Axial SCX-10 | 124 | 06-13-2011 08:08 AM |
DT's UGC Viper | DickyT | Axial XR10 | 943 | 04-20-2011 05:45 PM |
DT's FF-4 build | DickyT | Axial AX-10 Scorpion | 91 | 06-23-2010 07:34 PM |
Got a case of the DT's | Duspan | Losi Micro-Rock Crawler | 4 | 01-11-2010 02:15 PM |
