09-09-2016, 04:08 PM | #1 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
| Spur gear not spinning Freely
I just bought a vanquish Transmission housing for my Deadbold f-250 truck, i put HR HD tranny gears in it i put it all together and my spur gear is tight it doesn't spin freely. if i give it a spin, it stops immediately no free spin at all. im pretty sure its suppose to spin very very easy. hope i explained that well enought im not real sure whats wrong i put it together just like the stock on is. is it the housing? thanks for any help. |
09-09-2016, 04:34 PM | #2 |
| Re: Spur gear not spinning Freely
manual shows this spacer https://www.amainhobbies.com/search?s=AX30499 but it has this spacer does that matter? https://www.amainhobbies.com/search?s=AX31180 |
09-09-2016, 08:26 PM | #3 |
Well I got it to loosen up a bit, still not sure why it's so stiff but got it enough tested it and it wasn't super hot we'll see how long the plastic spur lasts with it Sent from my SAMSUNG-SM-G935A using Tapatalk |
09-10-2016, 08:18 AM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
If im not mistaken, the upper spacer is for a 48p spur and the lower spacer is for a 32p spur.
09-10-2016, 09:09 AM | #5 |
Oh okay so the spacer is right then thanks eliminates on thing then lol Sent from my SAMSUNG-SM-G935A using Tapatalk |
09-10-2016, 09:49 AM | #6 | |
RCC Addict Join Date: Apr 2011 Location: San Diego
| Re: Spur gear not spinning Freely Quote:
The AX31180 is for the newer slipper design. Got any pics? Which slipper do you have? | |
09-10-2016, 09:51 AM | #7 |
I have the new dual slipper like the one in the wraith spawn and yeti Sent from my SAMSUNG-SM-G935A using Tapatalk |
Spur gear not spinning Freely - Similar Threads | ||||
Rear wheels spinning freely | Smonkman | Vaterra Ascender | 6 | 05-29-2015 11:34 PM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
should these axles be spinning freely? (freewheeling) | 53 willys | Axial XR10 | 14 | 10-31-2010 08:47 AM |
How freely should the Spur Gear spin? | Steve at Danfor | Axial SCX-10 | 11 | 04-10-2009 01:29 PM |
