11-20-2017, 05:30 AM | #41 |
Newbie Join Date: Nov 2017 Location: Reno
| Re: What mods to make SCX10-II crawl great
Ditch the stock front bumper and stock tires. Stock bumper catches on everything and the stock tires don't shed mud. Sent from my Nexus 6P using Tapatalk |
11-20-2017, 12:57 PM | #42 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
Instead of adding aluminium bits for durability and adding weight for low center of gravity, try to remove unecessary weight, move components such as esc and battery as low as possible. Probably the most capable rig I've ever had is a pretty much bone stock "plastic fantastic" SCX10 gen 1 Jeep kit. I did only a few mods; better links/rod ends, battery up front, Axial 8-hole plastic beadlocks with 70 grams of lead on front wheels, TSL XL tires with CI foams. And a proper set of electronics of course. Light weight will add durability on stock plastic bits. No lights, drivers or any scale bits, smaller battery and so on. Look at the pro crawlers. They shave of everything that doesn't need to be there. Less is more! |
What mods to make SCX10-II crawl great - Similar Threads | ||||
Can we make a tips/tricks/mods sticky? | fbuonpensiero | Axial SCX-10 | 3 | 09-02-2010 02:39 PM |
what mods should i make? | trevdogg420 | Axial SCX-10 | 1 | 12-13-2009 10:21 PM |
Which mods to make to my rtc??? | DAN8701 | Axial AX-10 Scorpion | 4 | 08-25-2009 08:37 PM |
simple mods to make your ax10 rtc a real crawler | NORCALDAN | Axial AX-10 Scorpion | 2 | 10-05-2008 12:20 AM |
Mods 4 WK trans to make it like AX-10 | Leeroy | HPI Wheely King | 14 | 05-22-2008 10:34 PM |
