04-13-2020, 04:57 PM | #61 | |
Pebble Pounder Join Date: Jul 2012 Location: Northeast
| Re: Bud Quote:
While catching up on some necessary reading before I start building my rig, low and behold, you have the same color green I wanted! I should've figure someone would've beat me to it already. . So I have to ask: What exact brand and color of paint did you use? | |
04-13-2020, 05:09 PM | #62 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: Bud
Tamiya PS8, as noted in Post #18.
04-13-2020, 05:28 PM | #63 |
| Re: Bud D'Oh! I even read that post and still missed it. Guess I was just too excited. Thanks for the help though AK KRAWLER. Does anyone that has painted one these bodies know if one can is enough or do I need to get two? Also, I'm not seeing what color he backed it up with--any ideas? Unfortunately, my LHS has decided to stay closed for COVID-19 during the entire month of April so I'll need to mail order all of the paint materials. I just want to be sure I get everything on one order. |
04-13-2020, 05:41 PM | #64 | |
| Re: Bud Quote:
04-13-2020, 05:49 PM | #65 |
| Re: Bud |
04-13-2020, 06:00 PM | #66 |
| Bud Yessir PS 8 backed with white. Blame the lights on Josh’s....... I always buy two cans..... One if done neatly should be more than enough backed with white. I used Spaz Solid White Backer SZX00209..... Really makes fluorescents pop Hang up and Drive Last edited by mikemcE; 04-13-2020 at 06:06 PM. |
04-13-2020, 06:37 PM | #67 |
| Re: Bud
Thanks so much mikemcE! One last question (I hope). You don't have any problem using the Spaz Solid White Backer with the Tamiya paint? I hate to sound like a paint noob (I sort of am) because I thought different brands didn't work well together, or at least shouldn't be used together. |
04-13-2020, 07:05 PM | #68 |
| Re: Bud
I have found most of these play well, if dry. Hair dryers work well to speed it up. HemiStorm also taught me you don’t need a opaque paint job, just solid from the top.... don’t look thru it from the inside, when you back it your done.... saves paint and dry time just no mottles Hang up and Drive |
04-13-2020, 08:14 PM | #69 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Bud So funny that you'd mention that. I was always taught to hold the body up to the light, sun even, to know when the paint was thick enough. After hearing that tip from hemistorm last week (2012 video...?), I shot this one thinner and slower and didn't look through it from inside. Best I've ever had paint come out!
04-14-2020, 04:38 AM | #70 | |
| Re: Bud Quote:
I’ve done the last three that way.... after all we see reflected colors... it works! Hang up and Drive | |
04-14-2020, 07:28 AM | #71 | |
| Re: Bud Quote:
04-14-2020, 03:11 PM | #72 | |
| Re: Bud Quote:
Well all I can say is heat the paint and mist it. 3 light coats is all you need, but it has to be even. Distance of the can/ airbrush is critical, also overlap of strokes, 1/2 to 1/3 overlap..... more opacity tighter strokes.Candys are the supreme test. Hang up and Drive | |
04-14-2020, 05:07 PM | #73 | |
| Re: Bud Quote:
That's why I don't have the guys to spray candy paints. My biggest problem areas are, for instance, something like the top of a window lip. I have a tough time getting paint down in there between the window lip and the roof. | |
04-14-2020, 05:20 PM | #74 |
| Re: Bud
That’s why you heat the paint. Tamiya when run under hot tap water , shaken vigorously will mist out. If you mist those spots first, you’ll usually get full coverage. I’ve learned to “pre paint “ without paint, a habit I got from learning airbrushing. I visualize with my AB where I’m going to spray, as I don’t want crossing in corners. I’ve spent 40 years painting, and still learn daily. An engineer buddy taught me “Plan your work” and “Work your plan” ...... it helps. Hang up and Drive |
04-14-2020, 06:55 PM | #75 | |
| Re: Bud Quote:
Painting is one of those never ending works in progress for me. Learning every time I pick up a can for sure. | |
04-14-2020, 07:56 PM | #76 |
| Re: Bud All right, Mike, you opened the door lol. How hot, and for how long? And I'm assuming one would just roll the can under the running water? Spill. |
04-15-2020, 04:42 AM | #77 | |
| Re: Bud Quote:
Tap water in a coffee cup.... till you feel the warm can when shaking. Even temps. I’m gonna say a couple/ three minutes. When I did styrene builds, Tamiya TS was the best laying around. When heated it atomizes better and seems to be even pressure.But it’s the “mist” that works best. Painting teaches me patience..... when I don’t it always sucks. Hang up and Drive | |
04-15-2020, 08:23 AM | #78 | |
| Re: Bud Quote:
Yeah, I'm pretty sure I'm back to Tamiya paint exclusively, small cans notwithstanding. Patience is not a virtue I possess in spades...maybe I'll get there. Still refining the basics like distance from material and stroke speed. I have overlap down. Thanks! | |
04-15-2020, 08:44 AM | #79 |
| Re: Bud
I live in Florida... my paint is always 75 degrees. I routinely warm all paints I spray... biggest problem to watch for is water still on the can, I use a fresh paper towel Hang up and Drive |
04-15-2020, 11:15 AM | #80 |
| Re: Bud And that's one of the reasons I hate warming them in water. The water can drip if you miss any and the label disintegrates.
Bud - Similar Threads | ||||
Tf2 bud naked | Sqbiedoo | RC4WD Trail Finder 2 | 4 | 05-27-2013 11:37 AM |
bud rims 1st look | SEMIJOE | Non Crawler RC's | 4 | 11-10-2010 03:05 PM |
Bud #8 Slash | TIMZKRAWLER | Non Crawler RC's | 14 | 08-12-2008 04:01 PM |
