04-15-2020, 01:54 PM | #81 |
| Re: Bud |
04-17-2020, 06:42 PM | #82 | |
Pebble Pounder Join Date: Jul 2012 Location: Northeast
| Re: Bud Quote:
So here's what I'm wondering: What happens if you paint the body color, then the white backer, and then use black backer over the white? Will using the black over the white make the body color appear darker than without it? | |
04-18-2020, 06:00 AM | #83 | |
| Bud Quote:
It might..... silver is a blocking color, if the white backer is thin , it could darken. Usually it will mottle, a few darker areas. Ive found that the “backer” white is more solid than the bright white a couple of even coats works for me. Remember paint on these is reflecting the light from outside. Also inner fenders block that view Hang up and Drive | |
04-18-2020, 02:06 PM | #84 | ||
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Bud Quote:
04-18-2020, 09:11 PM | #85 | |
| Re: Bud Quote:
04-18-2020, 09:20 PM | #86 | |
| Re: Bud Quote:
I’ll probably copy your painting of the strips by the bumper and hood too now as a precaution—thanks for the heads-up. | |
04-19-2020, 01:48 PM | #87 |
| Re: Bud
Speaking on inner fenders, Axial was nice enough to provide openings for rock lights, so I grabbed a set from Club5 racing , made for a MOG, made a box and cover to hold them, and printed off a set. LEDs drop down onto a ledge, some E6000 will hold all together easily. Yeah red housings, the PETG was in the printer already A quick spray will solve that issue. Hang up and Drive |
04-22-2020, 06:42 PM | #88 |
| Re: Bud
Upgrade today as I’m waiting for My Trick RC halos , installed some beef.... portal covers that is. I’ve got the Beefs up front SSD in the rear. Quick drive on my tree roots, Between the 70 wt oil and these portal weights this truck is planted. I’m really enjoying 23%OD, and never a click. I noticed a bit more growl up front, those OD gears are all business. Hang up and Drive |
04-24-2020, 04:13 PM | #89 |
| Re: Bud Serious lighting! Hang up and Drive |
04-25-2020, 04:23 PM | #90 |
| Re: Bud
Quick test, OH YEAH!! Halos, headlights, brake and taillights. Not shown are the rock lights. Runs off 2 or 3s direct to balance plug or adapter to battery. Not cheap, but well made and versatile. This Covid is getting to my PayPal.... Hang up and Drive |
04-25-2020, 04:31 PM | #91 |
| Re: Bud
Test print of the new fender lips, from Knight Customs. I say test as I failed three time’s trying. Then I enabled supports and printed great, I’m gonna set a different infill and then will print all four in Carbon PETG . Great files! Hang up and Drive |
04-26-2020, 04:33 PM | #92 |
| Bud Printed up some of Harleys Halo mounts, painted them silver. Installed and tested.... they look pretty good. Hang up and Drive Last edited by mikemcE; 04-26-2020 at 04:51 PM. |
04-26-2020, 05:24 PM | #93 | |
| Re: Bud Quote:
The halos look awesome. I was tempted to do this, but wiring up bodies with LEDs can lead to a PITA cluster. When will we get wireless LEDs? | |
04-26-2020, 07:15 PM | #94 |
Rock Stacker Join Date: Feb 2009 Location: Oakland CA/Seattle WA
| Re: Bud
Excellent choice in light kit |
04-26-2020, 07:37 PM | #95 | |
| Bud Quote:
One pin cable connector between chassis and body, two extra for rock lights. And it’s switched from the truck ( if you’ve got a channel) or wired switch. Wireless trailer lights are available for scale semis Hang up and Drive Last edited by mikemcE; 04-27-2020 at 10:40 AM. | |
04-28-2020, 06:44 PM | #96 |
| Bud
Had a brief tree run by the creek. Water is down, so lots of test rocks. After I got over the pretty lights, I ran this rig. These tires aren’t bad at all, foams not even , and a bit soft out back. Sure Hope Eddie gets some foam, I’m hurting for my CI !!! The front and rear portal covers seem to plant things much better, as much as the foams allow. All that OD is great, no issues turning or driving on the trail, does have a nice deep growl, with the PullerPro. Side note I did enjoy the lights, even brakes for me, a first on RC, worked perfectly on channel4 Hang up and Drive Last edited by mikemcE; 04-28-2020 at 06:47 PM. |
04-29-2020, 10:49 AM | #97 |
| Re: Bud
Sweet looking light kit! I love the look with the halo's! I'll have to get a set of those for my JLU! I'm curious to see how the fender flares turnout. I saw that Knight Customs is offering them to print and was thinking about buying the file. |
04-29-2020, 12:15 PM | #98 | |
| Re: Bud Quote:
I did buy the file, well worth 8.00, I’m still using up this spool of red filament.... it seems endless, but the carbon will disappear it will go so fast. Hang up and Drive | |
04-29-2020, 12:17 PM | #99 |
| Re: Bud
Well Silly me. Went to CI direct, my foams will be here direct on Monday Eddie delivers again!! Hang up and Drive |
04-29-2020, 07:55 PM | #100 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Re: Bud
By chance what foams did you get?
Bud - Similar Threads | ||||
Tf2 bud naked | Sqbiedoo | RC4WD Trail Finder 2 | 4 | 05-27-2013 11:37 AM |
bud rims 1st look | SEMIJOE | Non Crawler RC's | 4 | 11-10-2010 03:05 PM |
Bud #8 Slash | TIMZKRAWLER | Non Crawler RC's | 14 | 08-12-2008 04:01 PM |
