06-28-2012, 08:57 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Denver
| Trazh's Wraith Build
So I got a kit for a great deal just because the box had a small gash in it. It arrived and I have put about 4 hours into the build. Here is a list of the parts I have been collecting for the build and I will post pics soon. Castle Creations Mamba Monster ESC Castle Creations 4600kv 4 Pole Motor OEM 284 oz Servo Aluminum Servo Arm Futaba 2.4 3ch RX Light Controller 8 channel (15 lights total at this point) Stainless Steel Wraith Screw Kit MIP Drive Shafts STRC Rear Lockout Hubs STRC Aluminum Lower Links STRC Front C Knuckles STRC Front Steering Links STRC Motor Plate STRC Steering Link and Drag Link Axial 103MM Aluminum Threaded Shocks Axial Universal Light Bar Blue Shock Socks 3 Racing Pan Hard Link and Chassis Mounted Servo Kit 3 Racing Shock Droop Setup HR Diff Covers HR Sway bar kit 25mm Axle Extensions Hood Hinge Kit RC4WD King Kong Tow Shackles Traxxas Rod End Bushings Tamiya Toyota Hilux Front Hard Body Aluminum Side Panels Aluminum Rear Panel Aluminum Top Panel Aluminum Skid Plate Aluminum Front and Rear Inner Fender Panels Custom Spare Tire Mount Pro Line Roof Rack Roof Rack Bungee Net Custom Made Tow Straps Custom Made Rope Line Chain Losi Window Nets Tractor Supply Tool Box (for electronics) Losi Bead Lock Wheels Lots of Shrink Tube (for wires) Lots of Zip Ties A cool driver and passenger (to be revealed close to finish) Plenty of Scale Goodies! Radio Shack Project Box Scale Diamond Plate Bed Top Plate Been building the collection of parts for a while, I am making this for a trailing rig that has some speed. I would like to get a nice low ride but still have some crawling capability. Last edited by Trazhcan; 08-01-2012 at 08:05 PM. |
06-28-2012, 09:19 PM | #2 |
| Re: Trazh's Wraith Build |
06-29-2012, 07:58 AM | #3 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Good start so far. Looking forward to the finished project.
06-30-2012, 11:56 PM | #4 |
So I painted the roll cage and got it mostly assembled. I left some parts unfastened to have access later to get the interior and electronics in. Here are some pics of the process. |
07-01-2012, 07:43 PM | #5 |
Quarry Creeper Join Date: Jul 2008 Location: Stuck in Missouri for now.
Did the hilux body fit that nicely from the get go or did you narrow the front of the cage? By the way, that spray job on the cage looks awesome. Glad to know that it can be done. |
07-01-2012, 08:41 PM | #6 |
I haven't done anything to the cage. I did cut away at the back of the body though to get it to drop down all the way. I will be chopping the hood and fastening the fenders to the shape of the cage. Then trimming the hood and hinging it.
07-05-2012, 12:20 PM | #7 |
| Re: Trazh's Wraith Build Some Body work prep More to come!!!! |
07-13-2012, 10:42 AM | #8 |
Been busy both at work and on the rig here are some update pics I had a piece of scrap from my Radio Shack project box so I found another use for it |
07-13-2012, 11:01 AM | #9 |
Looks like you changed directions a little bit. Are you planning to run the Hilux cab with the Wraith panels in place? Doesn't look quite right to me. Would be better if you maybe chopped the rear of the cage up a little and then dovetailed the Hilux bed to fit. Or just run it with the Hilux cab and bare rear cage.
07-13-2012, 11:56 AM | #10 |
Don't judge a piece of artwork until its finished |
07-14-2012, 10:31 AM | #11 |
Newbie Join Date: Jun 2012 Location: Smithfield
. You must have a ton of cash. . |
07-14-2012, 12:00 PM | #12 |
That silver painted cage is SWEET. I've been thinking about the possibility of doing that to mine and after seeing how it looks it might be in for a tear down and some paint this winter.
07-14-2012, 03:43 PM | #13 |
I thought a blue one would look cool, just remember, numerous light coats. Thanks for the props
07-14-2012, 05:05 PM | #14 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
always love a Yota build!!
07-18-2012, 01:59 PM | #15 |
More Building More to come! |
07-18-2012, 02:12 PM | #16 |
07-20-2012, 10:32 PM | #17 |
I chassis mounted the servo instead of axle mount, just seemed like the right thing to do given the space between the servo and the chassis. I am looking at having a brushed motor in this thing so I can get the motor wet. I am looking for some speed however. I had my eye on a Traxxas Stinger 20t or a Traxxas Titan 12t. I will be running a 3s 40c 3300mah on 80/15 gearing, any suggestions? I would just hate to destroy an awesome Castle 4600 4 pole motor because I wanted to get a little muddy.
07-21-2012, 01:34 PM | #18 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
I blew my stock motor about 10 months ago and have, believe it or not, been running a Titan 12t EVER SINCE without fail. I can't believe it myself but my rig out-crawls every other wraith in the springs. Not to be cocky hahahaha.
07-23-2012, 07:00 AM | #19 |
| Re: Trazh's Wraith Build On the stock AE-2 ESC? I ran the 12T 550 for a while, but it kept getting hot really quickly, so I switched to an Integy 35T V11 Pro, which seems to be a better choice. Although, I think I have the rear short shaft issue, which could be the culprit, too.
07-23-2012, 01:16 PM | #20 | |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Trazh's Wraith Build Quote:
Love the silver cage too, that looks awesome. | |
Trazh's Wraith Build - Similar Threads | ||||
1.9 Wraith build | rckjeep | Axial Wraith | 25 | 07-07-2012 02:47 AM |
New Wraith Build | Savage121 | Axial Wraith | 1 | 06-03-2012 02:03 PM |
My Wraith Build | acesal | Axial Wraith | 29 | 05-02-2012 09:59 PM |
My First build the wraith | redneckrampage | Axial Wraith | 5 | 04-18-2012 09:44 PM |
Wraith build | pwrwgn2000 | 2.2 Scale Rigs | 2 | 10-17-2011 07:27 AM |
