01-14-2013, 09:07 PM | #1 |
Newbie Join Date: Dec 2011 Location: Beach
| Best way to vent wheels?
Is there a science to venting the wheels to eliminate the flat spots on my swampers? Thinking about just drilling one 1/8" hole between the spokes towards the inside of each wheel? Just the drop in temp from 70* inside to 28* outside, sucks the air out of the tires, making several flat spots that don't go away while wheel'n. It sits on a stand, so no flat spots from sitting. I have heard of guys venting the tires, but I don't see the benefit? We do run in the water, so maybe a couple holes would be better to allow drainage/evaporation and possibly stiffer foams?
01-15-2013, 12:51 AM | #2 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Best way to vent wheels?
Drill away |
01-15-2013, 01:13 AM | #3 |
| Re: Best way to vent wheels? That's what I did with my XR beadlocks on Wraith, then tune your foams, I'm running two stage home-made. Some stiffer 2.2 buggy rear foams and the stock Wraith foams cut to make thinner outer layer. If they get wet, take them apart and let them dry out or they will turn nasty and the foams will get wasted.
01-15-2013, 06:11 AM | #4 |
Rock Stacker Join Date: Aug 2008 Location: Albuquerque
The benefit to venting in the tire is to allow water drainage so your tires don't become to heavy and to allow your foams to dry so they won't wear easily. I found that burning a tiny hole with a solder pen creates a hole but also mends the sides of the hole so it doesn't tear easily!
01-15-2013, 08:49 AM | #5 | |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Best way to vent wheels? Quote:
01-15-2013, 11:00 AM | #6 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
The guys at Crawler Innovations recommend venting the tires especially if you use closed cell foam. They use a leather punch...who knew, eh?? I like the soldering iron melt trick idea...so the tires are melted and less likely to rip. I have a fear of ripping tires if I vent the actual rubber but that is part of my OCD I guess. Scared to ruin a tire..DOH!! |
01-15-2013, 11:41 AM | #7 |
| Re: Best way to vent wheels? |
01-15-2013, 11:43 AM | #8 |
Rock Stacker Join Date: Oct 2012 Location: Connecticut
For venting tires do you want one single hole or multiple?
01-15-2013, 02:03 PM | #9 |
Best way to vent wheels? - Similar Threads | ||||
vent the wheels? | Dust Puppy | Tires and Wheels | 17 | 10-25-2010 11:49 AM |
Vent HBs or vent the rims or both? | boisetrucker | Tires and Wheels | 10 | 12-27-2009 05:58 PM |
Poll: To vent, or not to vent... that is the question... | Katon | Newbie General | 20 | 12-23-2009 10:29 AM |
dna asassin wheels vent question | midship909 | Tires and Wheels | 26 | 06-26-2009 11:26 AM |
New Tires... To vent, or not to vent??? | sportpak | Newbie General | 27 | 05-08-2008 01:13 PM |
