02-19-2016, 03:25 PM | #201 |
| Re: Why not.... for sale section build |
02-20-2016, 10:33 AM | #202 |
Forward motion.. So much extra space now! A little too much wire.. But that's easy enough to take care of.. OK. Back to replacing the XJ starter.. |
02-20-2016, 10:34 AM | #203 |
Newbie Join Date: May 2014 Location: Evanston
I need to order a Holmes esc. Sent from my SM-N910V using Tapatalk |
02-20-2016, 10:37 AM | #204 | |
| Re: Why not.... for sale section build Quote:
I couldn't be happier with the setup! I set that one to "sensored only".. But I think I might go "smart sensor" on this one and boost the shit out of it! Lol.. 35-40mph, here I come!!! | |
02-21-2016, 10:38 PM | #205 |
Battery tray's.. With some Velcro, they will be much easier for battery swaps.. Reinforced the wing mounts. Flushed the heads. Getting wired!!! And drying.. A put some of the panel's back on. Should have some Powah to her tomm! |
02-23-2016, 07:40 AM | #206 |
Mounted.. So nice and clean! I forgot what a Animal this thing is! And today.. |
03-11-2016, 04:21 PM | #207 |
| Re: Why not.... for sale section build Thank you sir! So, I'm use to running big motors with big power, but nothing like the Powah out of the 540xl! Not even out of HD.. In less then one full 2200mah pack. I think I blew out Both gear sets and shattered atleast 1 hex pin! And that was just a easy test run!!! Now to replace them and give it hell! |
03-11-2016, 08:46 PM | #208 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
So I've got a question for ya Winnerone. Are you doing anything about the weight bias that comes from running the battery on one side of the vehicle, like it is. I ask because I've got one too, built very similar. Ya add weights? Two batteries for super long run times? I can't decide what I want to do, because I feel like two large Mah batteries would be way too heavy, maybe two smaller packs would work out. I modded a stock wraith battery holder to sit where the battery goes in on a stock EXO, and screwed it to the frame rail, fits a 2300Mah 3s perfect. BTW, great job testing out that XL motor, Dang! |
03-11-2016, 09:26 PM | #209 | |
If I'm only running one battery, I run it on the driver side. The Sexo doesn't seem to take notice to the weight. In my mind (scary place) the battery aids in torque twist. Mainly for initial launch. I run a pack on each side, in parallel, for longer hauls. Trail runs, KOH, g6, etc.. I thought about running "smaller" packs. But I was going to go with 2x 2s in series. Only problem with that, I wouldn't barely ever use them. That and even 2x 3300mah 2s, weighed more, costed more, less capacity (then 2x 2200mah 4s), and I run my scx XJ with the same packs. So I ditched that idea.. Lol.. More testing coming, on the XL.. I know one thing. This, in comparison, I figured it would be close to the 3500kv HD.. Well... That's not what the rig said! With the setup I run, I never really got the front end to come up, on speed runs. It does now! Talk about a grin, from ear to ear! On the rock pile.. I could shoot a couple spots and launch off a couple others.. Hehehehehehe.. Instead of jumping a gap, I completely cleared the rocks I use to land on! Instead of jumping up to catch the front end on a upper ledge, I landed on top of the rock! Instead of having to feeling like I had to build rpm's to get the full umph.. I can hammer down at any point and feel like I have the pony's to do what I want! (OK, so maybe my easy testing, isn't so "easy").. Lol.. | |
04-19-2016, 07:34 PM | #210 |
Powah!!! Dun ripped all 4 screws out of the tranny! Time for some brass inserts, Dlux knuckle's and ofna love! I'll be back, right after I find the inserts.. (Amongst my parts) Lmao.. Last edited by winnerone23; 04-19-2016 at 07:37 PM. |
04-29-2016, 04:10 PM | #211 |
OK, brass inserts found! I like new stuff! HH spool and a new HD gear, in stock ratio. New bearings for the output shaft.. And just for some Extreme Abuse this weekend! It's not as sleek as my clean steering links setup as before.. But it seems high enough and gives full lock to lock.. |
04-30-2016, 11:37 AM | #212 |
Today was a Great day!!!! Hill climbs jumps,rock racing, rock crawling Broke a link screw Stripped the servo horn Dunno how long this was missing for.. Ooops Stripped a 32p spur gear and I think another gear set is shot.. Lol.. As much as I hate the idea, I think I'm going to have to look into a V2 VP axle case.. :( I got almost 4400mah of 4s thru it and a little video, of what makes me smile! Which I'll get posted, once it's downloaded.. Going out crawling now.. |
05-01-2016, 04:20 PM | #213 |
OK.. So this wasn't much and was only running with one hand.. But it gives you a small idea of what this rig goes thru.. https://youtu.be/AHiL6OzMTkk |
05-01-2016, 04:28 PM | #214 | |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
4s....... thats ridiculous my wraith falls apart as soon as the hh3500xl see's a 3s coming its way lol | |
05-01-2016, 04:39 PM | #215 | |
All stock parts, wish they could run fast enough to get away! Baahahahaha.. I replaced all posts yesterday and had it out today.. Just got done replacing a new spur and pinion.. Went from a 54/11 to 56/13.. Hopefully it will mellow out the torque and gain some speed.. 54/13 is where I would like to be, again. Drive train parts lasted longer. Muuwaahahahahaha.... Other then the stock axle housings, rear axles, skid, and tranny case, everything else is upgraded.. She runs like a Beast, takes me beatings, and never talks back! (Much).. Lol.. | |
05-01-2016, 04:50 PM | #216 | |
i would be amazed if she could talk after your beatings | |
05-01-2016, 05:06 PM | #217 |
05-02-2016, 06:33 AM | #218 |
Wow! Quite the beating! Amazed that some of those parts dont break! Good job!
05-02-2016, 06:57 AM | #219 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
. You need rpm racing to sponcer you. Seriously though looks like fun
05-02-2016, 07:53 AM | #220 | ||
Seriously, that was 30 seconds of 3hrs put in the Sexo, this weekend.. I'll try to get back out and get 2 handed driving video.. It gets worse.. More controlled, but worse! The hill climb is a killer... Making it is fun, but the pile of times it doesn't go all the way, it comes down in cart wheels and flips.. Ouch... The race to the bottom, makes for sweet jumps, off the 3 bench's.. | ||
Why not.... for sale section build - Similar Threads | ||||
For Sale section....... | EdmontonTrader | Comments, Suggestions, and Help | 78 | 05-11-2015 07:34 AM |
Sale Section | Hemipower23 | Comments, Suggestions, and Help | 7 | 09-13-2010 12:38 PM |
Wanted section and for sale section | InFlames | Comments, Suggestions, and Help | 13 | 10-20-2008 09:12 AM |
4 sale section/wanted section ????? | stevew | Comments, Suggestions, and Help | 21 | 12-14-2006 06:38 PM |
Do any noobs in the wanted section read the 4 sale section? | Unimoger | Chit Chat | 11 | 01-24-2006 12:21 PM |
