04-19-2014, 10:53 AM | #621 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build
I've been making progress. Trying to finish up the metal work today. Cut out one of the cross braces to make a winch mount. Added a fairlead mount up front Added some "sliders" to get some more scale points |
04-19-2014, 02:57 PM | #622 |
Wanted to add some style to the chassis as well. I'll be adding a light bar insert to this as well. Needed a light bar for points, so a MORE LLC equiped VP bar got mounted. I made two very simple plates. |
04-19-2014, 02:58 PM | #623 |
I've had one of these TSS Billet radiators for quite awhile, I decided I wanted it in this truck. Very simple install. |
04-19-2014, 05:21 PM | #624 |
I forgot to post yesterday's video. Today's video will be up in an hour or two. |
04-19-2014, 05:27 PM | #625 |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
That radiator looks sick on that chassis What kind of winch is that, a Tziworld?
04-19-2014, 05:29 PM | #626 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build |
04-20-2014, 01:04 AM | #627 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
| Re: Harley's $50 Poison Spyder Wraith Budget Build Now started to make my way through this thread, I've got a question regarding installation on the Vanquish SLW wheel hubs.. You mentioned the Vanquish hubs use a 4-40 hardware for installation and from what I can see, each hub uses 6 screws to attach the wheel to it.. So why does Vanquish sell their "Scale Wheel screw kit" (link below) with only 21pcs of 4-40 screws!? Am I missing something somewhere? Scale Wheel screw kit Can you recommend a link to purchase compatible hub screws? Thanks.. |
04-20-2014, 01:24 AM | #628 |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Stainless Steel Socket Head Cap Screw 100 4 40x1 4 | eBay Would those work? Guess I will have a few extras... |
04-20-2014, 06:55 PM | #629 | |
| Re: Harley's $50 Poison Spyder Wraith Budget Build Quote:
04-20-2014, 06:59 PM | #630 |
Next update... I added tabs and panels to facilitate a simple interior as well as battery a battery mount and dash. The interior is going to be a flat metal floor, nothing crazy. The dash will be 3D printed. |
04-20-2014, 07:04 PM | #631 |
I did a mock up of the stock PSC body, I actually liked the style but I'll be going with some aluminum panels and skins. Then it was time for primer! While the paint was drying, I made the choice to throw the Curries under it. Paint finally dried. |
04-20-2014, 07:08 PM | #632 |
After everything dried I bolted things up. Still have a lot of details to finish up but most of those are 3D printing tasks. |
04-21-2014, 08:04 AM | #633 |
04-21-2014, 11:19 AM | #634 |
Made two phone calls this morning to get the last of the parts I need (I hope). I called Eddie @ Crawler Innovations and got some Deuces Wild single stage foams on the way. While a dual stage may have been a little better for the crawling portions, I just really like the handling of his single stage foams now. Then I called Rick @ Super Shafty for a big favor. The shock mounts on this chassis are a little further forward and above the line of the front shock mounts. So I decided I wanted a little longer shock. Rick offered up a set of the Velvets in a couple lengths to fit my exact needs. Looking forward to running them on this truck, I have only ran them on my Twin Hammers before and while the shocks were great, I really dislike that truck so I never got the enjoyment out of them that I was after. I also got a set of 6mm MIP ball ends for my driveshafts from Rick so that I could install my new Wraith version extended chromoly outputs. |
04-21-2014, 12:00 PM | #635 |
04-21-2014, 12:03 PM | #636 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
Dang your really cutting it close gotta say the curries look great under there |
04-21-2014, 12:33 PM | #637 |
04-21-2014, 09:28 PM | #638 |
I got a text from MORE LLC today and he made me aware that Jerry @ The DMG had one of his 3" Ultra4 style bars on hand. So I asked Jerry if I could steal his and have MORE send him a new one Thanks guys! It's hard to get a picture of these things they are so bright! |
04-21-2014, 10:54 PM | #639 |
Next project of the night was the grill. This piece was designed to snap in and not need any hardware. I got lucky on the first shot and it worked. I cranked up the resolution of the printer and wanted to see if it could do some detail. The grill letters are less than a half millimeter thick and pretty fine. The lettering didn't come out super distinct but it was a shot in the dark anyway Good enough and time to move on to the next piece. |
04-22-2014, 07:50 AM | #640 |
I start the CAD for the dash last night and got the first piece done. It will be a multi piece setup when completed. This is the main piece, there will be a front face that will house all the gauges, switches, etc; and finally there will be a column that attaches separately. I hit print and went to bed. The print time was estimated at about 2 hours since I was printing at high detail. The part came out great, I'm very pleased! |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/450136-harleys-%2450-poison-spyder-wraith-budget-build.html | ||||
just bought wraith rtr, now what upgrades? - Pirate4x4.Com : 4x4 and Off-Road Forum | This thread | Refback | 08-05-2013 12:19 PM |
Harley's $50 Poison Spyder Wraith Budget Build - Similar Threads | ||||
Nikka's Poison Spyder Wraith Build | Nikka | Axial Wraith | 69 | 07-02-2016 01:55 PM |
Jeep Poison spyder wraith | allanon1965 | Axial Wraith | 33 | 08-14-2013 11:19 PM |
Poison Spyder Wreckluse Build | Guam_RC | 1.9 Scale Rigs | 39 | 02-26-2013 08:35 AM |
Billet's poison spyder wraith | Billet | Axial Wraith | 6 | 10-06-2011 10:35 PM |
