11-02-2013, 06:28 PM | #81 |
| Re: wraith no more. starting a new thread
Hobby shop owner gave me a set of 164mm hpi shocks for 15 bucks so I said what the heck. Built a gusset on My cage and mounted them there. Did one test run on wet rocks and am undecided. Also mounted the boggers to relive a little pressure on the 6.0 foams quick vid with the 164mm shockls on board. a year ago as a wraith this thing was tipping over all over the place. both driving and vehicle have seen massive tuning if anyones curious that's a savox 1268 on 6 volts wich is only about 300oz Missing with the camera. Its snowing so no real need it testing on slick rock. Last edited by evan03; 11-03-2013 at 12:42 PM. |
11-10-2013, 07:04 PM | #82 |
Added a few bars and bec mount. Calling this done for now, has desert tan camo paint on it and is weighing in at 1.25lbs. Its just shy of 6.75 ready to crawl Last edited by evan03; 11-10-2013 at 07:07 PM. |
11-10-2013, 10:03 PM | #83 |
Really digging the tan camp or kaki whatever you wanna call it. Brought it inside to pur everything back on anxcthen the wife decided its bedtime. So this is how she sits tukk the weekend. |
11-15-2013, 10:11 PM | #84 |
first real test on the new frame. |
11-23-2013, 01:20 AM | #85 |
Picked up some rc4wd spark shocks Threw some stiffer springs I had been n them These are all metal shocks 110mm. You wouldn't believe how smooth they are. Best shocks if owned so far even compared to gtrs 16oz keystone is just right for articulation and has become what my standerd is. The ball links are so awesome compared to rubber mounted. Would buy a set of pro lines if they were built like this Last edited by evan03; 11-23-2013 at 08:54 AM. |
11-25-2013, 11:10 AM | #86 |
| Re: wraith no more. starting a new thread |
11-25-2013, 11:31 AM | #87 |
11-25-2013, 05:21 PM | #88 |
Good to know. Can you then run the pro line shock body on the axle?. I may run some jato ends on my shocks to increase ride height a little. Also thinking about 80w oil in the rear and 60 front or maybe 80 all around to slow the shocks down a little.. The stock axial purple springs work very well on these shocks I'm now running them on all four corners the red tmax springs were to springy for my liking Last edited by evan03; 11-25-2013 at 05:31 PM. |
11-27-2013, 09:28 PM | #89 |
So lately I've had a little bit of money to blow. Had big plans to get a MMP which is only a 65 amp ESC compared to my huge 150 amp ESC. Would shed a lot of weight and gain castles semi sensored as the call it and tons of program ability. Thought I'd get s rc4wd front axle and VP 3d did cover. Then I finally came to my senses and decided its not broke and is performing better then ever so I got back to my roots a bought a 50 class edge 540. All said and down this plane will cost about 400 bucks and that includes a 100 dollar castle ESC. Here's the wraith crawler checking her out. |
12-14-2013, 10:15 PM | #90 |
So my boggers were pretty warn and I caved to the pit bull band wagon. First impressions are they are to wide for the cl foams, heitgh seems sot on with tunning rings removed. Looks wise they are just to wide. But I pulled this line that I was unable to do with the boggers. Kind of a climb into side hill step down. Couple photos next to the boggers both wearing the same CI foams. Pits have a lot more sidewall action then the boggers. I may It be awhile before I can test them. Looks wise I'm not digging them but I'll let that sludecsince there already showing some improvements in performance Last edited by evan03; 12-14-2013 at 11:23 PM. |
12-16-2013, 05:52 PM | #91 |
I've decided its time to gather some real on bored info. I've picked this up for a air project but have decided to give it a go on the crawler to see what kinda amps and watts I'm pulling while crawling. I love these controllers to death. If it works out I may try a edge 75amp and see if castle can set me up with some kinda drag brake. These controllers may not work for shit on the ground. But the castle 1/5 ESC is an adapted air controller. Well see |
12-23-2013, 11:06 PM | #92 |
Okay so I finally got my first set of bead locks and grabbed some tsls because the pits don't do it for me. And off course since I messed up the order from lockedup Rc I'll be getting the wheels later after Christmas. Lockedup is awesome and helped me figure out my order at about 8 a few nights ago. A teaser with the ring sitting in a tsl. Also have a set of dual stage pro line memory foams on the way. Pitts will continue to be mounted on the axial 8 holes with 6.0 CI foams. Planning to do some head to head tire testing. Had planned on CI foams in the tsls but that wont happen. So well not have a true true tire shootout. I'll picture bomb tsls on the new wheels later so far this tire and wheel combo is making me tingly all over Man what a difrence these rings make on the axial 8 hole bead locks. Lockedup Rc scale bolts really add to the looks. Can't wait for the lockedrc iconic 8l wheels to get here and might order another set of rings for the axial s. And man the tsl's are to die for good photos of the lockedup rings on axial 8 hole beadlocks. pure awesomeness photos of the rings mounted on lockedup rc iconic 8l beadlock wheels in the next week or so Last edited by evan03; 12-25-2013 at 04:08 PM. |
12-26-2013, 06:53 PM | #93 |
| Re: wraith no more. starting a new thread Last edited by evan03; 12-28-2013 at 12:36 AM. |
01-04-2014, 08:06 PM | #94 |
I twisted the drive flange off the short side universal tried welding it and reshaping but it didn't hold up. So I worked on the frame. Starting to feel that its coming together but is slightly heavy coming in at 6.75 as pictured. This framing is starting to fall into place. I like the looks and its over functional and is way lighter then what I was at with the stock wraith frame and its adjustable with a little welding. Center of gravity is low and crawls awesome. Took me almost a full year but I now feel I'm pretty happy with it.. In this photo its sitting at 7lbs with battery on board. I still have some adjustments to do on the front but for now I'll live with it. This photo comes after rewelding and extending the front short side inner shaft. Was about to order a set of universals when I thought of a way to fix Furtwangler dated drive flange. Last edited by evan03; 01-06-2014 at 06:28 PM. |
01-13-2014, 12:08 PM | #95 |
Slow motion rock bouncing https://www.youtube.com/watch?v=F-9S...e_gdata_player Trail run. https://www.youtube.com/watch?v=Ynko...e_gdata_player Slow motion 4 door jeep https://www.youtube.com/watch?v=lpfB...e_gdata_player |
01-17-2014, 06:05 PM | #96 |
Traded into a little firepower. I've got very little into this loaded. Been watching for one for awhile I could never afford one so watched for the right trade Wooops this is a Rc forum Last edited by evan03; 01-17-2014 at 06:20 PM. |
02-11-2014, 11:04 PM | #97 |
FI spool replaced the front hot racing spool that was stripped out.. Last edited by evan03; 02-11-2014 at 11:21 PM. |
03-08-2014, 01:43 PM | #98 |
Okay not that anyone cares but here's my recent updates Cut my resume tsl. The tsl is my favorite tire but even it couldn't survive the knife in the 1:1 world I mod everything and this is no difrent I first practiced on the pits they are now running cut and with memory foams and crawl awesome but I don't like them way to wide I'd rather have two sets of tsls or claws They don't get run very often. But would if they were a difrent tire and to be honest they do awesome. Just not for me. In this photo the short shaft is broken. Made for a shitty few running but it got through. Conditions here are wet. This was the fix. The ear that goes in the spool was about twice twisted off. I left the ear twisted welded it then shaped it. I have literally no money so if my welder might be able to fix it I'll attempt it. And yeah the axle broke on my first weld. The last run Right now there's many reason I'm drawning in debt but anothere was the lift pump went out in my truck and holding to my only mod what brakes I installed a raptor fuel system. The stock lift pump is junk. I need to fan my own pump bracket I feel sick going down the red knowing if I run something over I could yank the fuel system off my truck That's about all that's been going on. Ohhh right now I'm having a beer and still working on finishing the last tsl Last few runs Last edited by evan03; 03-08-2014 at 01:56 PM. |
04-11-2014, 09:40 PM | #99 |
So I've been fighting a short shaft breakage issue finally just replaced it with zond 3/16 rod I tempered and ground a drive flange in. Cut my Pitts again Thisctimecremoved the small center lugs Liked them enough after cutting this time I mounted them on my good wheels The freaking tear up the dirt Got power structure strokes. Awesome shocks but out of the 2 I bought one is leaking grrrrr Off course these are modded for jato ball links fixed mounts suck on crawlers. Been building a pair of 6" paddles in perpetration for sand season Have a body ran it long enough to tear it off in a few minutes That's it. Have another 2100 kV 1/8 motor on the way so I can fly over the rocks and plain out on the sand |
04-23-2014, 10:54 PM | #100 |
Was lucky enough to receive a kms k3 winch direct from kms. Also spent some time talking on the phone and Robert is one great guy Will most like start a new frame around this winch Ran in the sand. Landed a big jump and broke the metal steering Arms max shaft and rod end Cut out some new steering arms Last edited by evan03; 04-23-2014 at 11:06 PM. |
wraith no more. starting a new thread - Similar Threads | ||||
Starting my Wraith build | RallyeX | Axial Wraith | 15 | 06-11-2013 08:00 AM |
Jk COACH OF STARTING OVER THE SCX10 WRAITH | gionata78 | Scale Videos! | 0 | 03-29-2013 03:06 PM |
Wraith Build. Starting the mods !!! | Joe$ | Axial Wraith | 4 | 08-25-2012 04:14 PM |
starting a wraith kit build | yatester | Axial Wraith | 7 | 07-20-2012 05:17 PM |
