02-11-2015, 06:24 PM | #1 |
Newbie Join Date: May 2014 Location: Twin Cities
| help making Spawn go slower Newbie warning … I got a Spawn yesterday as my first RC truck. I’d like to make it go slower for better crawling performance, but don’t see many options from Axial to do so. The 32P spur gears run from 48T to 56T. The 32P pinion gears run from 11T to 17T. Stock is 56T/12T for ratio of 4.66. The only option listed by Axial that would give a higher ratio is to change the 12T pinion to 11T, for ratio of 5.09. This isn’t much of a change. Are there other options? |
02-11-2015, 06:26 PM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: help making Spawn go slower
Swap the ring and pinion in both axial for the under drive set.
02-11-2015, 06:31 PM | #3 |
I wanna be Dave Join Date: Oct 2007 Location: Scumrise, Flooriduh
In addition to underdriving the axles, you can go up to 60t in 32p on the spur. You could also look into a higher turn motor. The higher the turn number the less rpm and more torque they make.
02-11-2015, 06:49 PM | #4 | |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: help making Spawn go slower Quote:
Axial Racing - Axial Heavy Duty Bevel Gear Set - 43T/13T Last edited by Eric0424; 02-11-2015 at 07:31 PM. | |
02-11-2015, 07:07 PM | #5 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
I vote change the motor to something with a higher turn. I have a Robinson 9t 32p pinion. So they are available.
02-11-2015, 07:18 PM | #6 |
I wanna be Dave Join Date: Jul 2013 Location: Minneapolis
I thought stock was 20/56...? EDIT: looked at mine it is 12.....the manual hasn't been updated for the 32p gears then... |
02-11-2015, 07:19 PM | #7 |
RCC Addict Join Date: Apr 2009 Location: LA
55t integy motor off eBay will bring it to a crawl. 45t will give a little speed. 35t is what most of us use.
02-11-2015, 07:36 PM | #8 |
Also read this Gearing vs motor |
02-11-2015, 07:46 PM | #9 |
| Re: help making Spawn go slower The Spawn manual (download from Axial) has the updated 32 pitch gears, the Wraith kit I bought recently still had with the 48 pitch gears. If you're looking at the hard copy included with the Spawn, it may be outdated.
02-11-2015, 07:47 PM | #10 |
| Re: help making Spawn go slower Yeah I was going off the manual that came with it. Maybe its the right part number but labeled wrong. Not sure but I thought it was 20t because of it. lol
02-11-2015, 08:01 PM | #11 | |
Robinson 10 tooth. TowerHobbies.com | Robinson Racing Pinion Gear 32P 10T Robinson 9 tooth. TowerHobbies.com | Robinson Racing Pinion Gear 32P 9T Another option would be to use a 58, 60 or 62 tooth 32 pitch spur gears from Associated (SC10 4x4 spurs). You would need to drill or ream the center hole in the gear to 5mm and use the Associated octagon slipper pads. These larger spurs would also be too big to fit under the Axial gear cover. May be more trouble than you want to go through just to use the GT2 and SC10 4x4 spur gears, but it would give you a lot of spur/pinion options when combined with the Robinson Racing 9 and 10 tooth pinions. | |
02-11-2015, 08:10 PM | #12 |
| Re: help making Spawn go slower A 20 tooth gear sounds like it may have been the transmission top shaft drive gear (20 tooth drive gear). But the 48 pitch pinion is also 20 tooth and the manuals do have a lot of errors in them.
02-11-2015, 08:11 PM | #13 |
RCC Addict Join Date: Aug 2013 Location: Missoula
64t spur fits without the cover. If you want low low gearing.
02-11-2015, 08:16 PM | #14 |
| Re: help making Spawn go slower Yep that was it. I was looking at drive gear which is right above the pinion. |
02-11-2015, 10:13 PM | #15 |
Update: A 62-tooth 32 pitch Associated spur gear (#91094) will not fit under the stock Axial gear cover (#AX80078 ). A 60-tooth Associated spur (#91095) will require trimming of or removing the notch for the drive shaft from the gear cover. It will still have rubbing issues until the gear and/or cover are worn down. A 58-tooth (#91096) may fit without any mods to the gear cover, just need to find one to be sure. The gear cover is 49.2mm ID over the spur gear, the 60-tooth spur is 49.4mm OD, the 62-tooth spur is 50.8mm OD. The 58-tooth should be around 47.5mm OD, but I'll take a real world measurement when I get my hands on one. |
02-12-2015, 04:41 AM | #16 |
RCC Addict Join Date: Feb 2012 Location: UK
Change the motor. Why people are advising UD gears at this stage is beyond me. You should be able to get what you want from motor and Pinion/Spur changes. Personally I would only ever use UD gear in the rear axle to help crawling performance. Gives a slight dig effect and minimizes the rear bouncing when climbing. Leave the front stock but that is for future tweaking. |
02-12-2015, 06:08 AM | #17 |
My recommendation was UD in both axles not a single axle. The UD gears will further lower his speed and increase tork. On addition they are hardened so they are stronger. A bonus should you ever try a sensored brushless such as the 2nd Gen Tekin ROC 412 or the Holmes Hobbies Trailmaster 540 Pro. Then you have the best of both worlds, ultra slow crawling power and blinding speed. Are you running NiMh? Or you running LiPo? How many cells? Last edited by DrDiff952; 02-12-2015 at 06:10 AM. |
02-12-2015, 06:50 AM | #18 |
I understand the theory. It's just not what I would have thought would have been recommend as solution for a simple issue that everyone has with the stock Wraith. Nevermind....I'll shut up. lol
02-12-2015, 07:09 AM | #19 |
Rock Stacker Join Date: Nov 2014 Location: Morgan Hill
Does anyone even have the underdrive gears in stock?
02-12-2015, 07:17 AM | #20 |
I wanna be Dave Join Date: Feb 2013 Location: NW Indiana
Put a 35 turn Holmes hobbies brushed motor in it..that will slow it down plenty.
help making Spawn go slower - Similar Threads | ||||
cc sidewinder way slower in reverse | m1009cucv | Electronics | 3 | 12-10-2012 03:07 PM |
Dual ESC's slower? | Hobine | Electronics | 6 | 04-03-2012 07:53 AM |
My Slower Rebuild Thred | bent | 2.2 Scale Rigs | 33 | 09-29-2008 08:46 PM |
How to creep even slower? | G1050 | Newbie General | 3 | 01-20-2008 07:59 PM |
lower, slower, uhhh go-er | Vitamin_J | Tamiya Clod Buster | 5 | 03-29-2005 10:59 PM |
