07-26-2015, 03:44 AM | #1 |
Newbie Join Date: Feb 2015 Location: Portugal
| Front battery mod-Need help!!
Hi guys! Finnished my Wraith kit a wile ago. Now I want to start to modify it, starting by the battery location. I run my battery in the back, but I want to put it in the froint of the truck, but I have a small problem. From what I've seen, to put the battery up front, you need to chop the interior and the steering column, and my dad doesn't want me to cut anything in the truck. My question is. Is there a way for me to fit a small 3S 2.2 mAh battery pack up front without cuting anything? Thanks |
07-26-2015, 10:17 AM | #2 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Front battery mod-Need help!!
Pull the hood off and see if it fits, if it does then your good to go. If not, your options are pull out interior, pick up a spawn interior or trim your interior without your pops knowing.
07-26-2015, 10:29 AM | #3 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
You always try these...and the method 84yoda said open hood hinges very easy mod without cutting.. Last edited by rustneversleeps; 07-26-2015 at 10:33 AM. |
07-26-2015, 12:28 PM | #4 |
My 2s 5000 mah venoms fits with zero issue. Try sliding it in sideways between the bottom windshield frame crossbar and the crossbar right behind the shock towers. You'll need something for the battery to sit on though, like the delrin tray I got from CKRC. It was only $10-$15 if I remember correctly.
07-26-2015, 01:05 PM | #5 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
3s 2200 will fit np just use velcro strap that come with it.
07-26-2015, 01:26 PM | #6 | |||
I'll try to diferent options of sliding and straping tomorow. By the way, where do you guys suggest I put the ESC and/or receiver? Because I need to make room for the battery Last edited by THX_138; 04-01-2017 at 11:53 PM. Reason: Merge, posts a minute apart | |||
07-26-2015, 02:19 PM | #7 | |
| Re: Front battery mod-Need help!! Quote:
I would just save your money and make it work with wraith interior. Or see if your pops will buy you spawn interior since he doesn't want you cutting up wraith interior. Haha | |
07-26-2015, 02:25 PM | #8 | |
I have my esc right next to tranny, but that won't work for you since your runnin wraith interior. Your options are up front or in back but I don't think stock wires will reach in the back, so put it up front. | |
07-26-2015, 03:42 PM | #9 |
Here's my setup. You can see there's still room to spare even with a 5000mah battery in there. It's hardcase too. HTH
07-26-2015, 04:34 PM | #10 |
Yes, we know most batterys will fit up there but i think with wraith interior there's less room up front. Not sure since i don't have wraith interior in front of me. I'm runnin 3s 5200 soft pack up front, and using stock spawn electronic box too (its longer then wraith electronic box up front). I did have to grind down some of the over hang on the plastic lid/cover for electronic box. |
07-27-2015, 12:12 AM | #11 |
RCC Addict Join Date: Jul 2008 Location: San Diego
If you have a piece of Aluminum you can make one LOWER and cheaper. I made one here are some pictures. Post #2 and #3 SDheavymetal's Wraith |
07-28-2015, 09:36 AM | #12 |
Pebble Pounder Join Date: Jan 2014 Location: NB Canada
| Re: Front battery mod-Need help!! |
07-28-2015, 12:25 PM | #13 |
Pebble Pounder Join Date: Apr 2015 Location: canada
07-28-2015, 12:59 PM | #14 | |
07-29-2015, 10:26 AM | #15 | |
Quarry Creeper Join Date: Feb 2012 Location: Near the IL/WI border
07-29-2015, 11:05 AM | #16 |
| Re: Front battery mod-Need help!! Thanks! I'll try to get some tonight, although its not the exact same configuration anymore. I swapped out/added an AX2 speed transmission and Mamba Max Pro ESC which wouldn't fit up front so it is mounted out back, but the battery and RX are still up front in "Da Tray"
07-30-2015, 05:03 AM | #17 |
07-31-2015, 07:37 AM | #18 |
Rock Stacker Join Date: Oct 2014 Location: UK
Is that a Dinky tray? I like that setup SynisteR6.
08-01-2015, 04:56 AM | #19 |
08-03-2015, 10:54 AM | #20 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
Here's my version: Full wraith interior; just trimmed 3/4" off the back of the steering column. All the running gear is sitting on a Crawler Innovations tray. Esc, rx, bec and 3400mah 3s hard case. Your dad will never see the column. |
Front battery mod-Need help!! - Similar Threads | ||||
Front battery mod help | Tbredon | Vaterra Twin Hammers | 2 | 08-12-2014 03:04 PM |
Battery Mod | clickaus | Axial Wraith | 8 | 05-28-2014 01:11 PM |
Battery Mod Question | md7989 | Redcat Crawlers | 9 | 04-14-2010 09:35 PM |
Simple Single Battery Mod | thunderwagn | Duratrax Cliff Climber | 5 | 01-08-2009 09:10 AM |
EVX one battery mod???? | Hillbillyking | Electronics | 3 | 02-27-2006 11:13 AM |
