04-03-2013, 04:51 AM | #701 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber
cvd´s are done motorplates too |
04-03-2013, 05:04 AM | #702 |
Pebble Pounder Join Date: Nov 2011 Location: Sweden
| Re: a tuber
I am waiting to see everything mounted up. It will be really interesting to see how you are going to place servo, shocks and links to be able to use all that steering:-) |
05-01-2013, 07:10 AM | #703 |
| Re: a tuber
some gear drilling Last edited by EGRESSor; 05-01-2013 at 07:13 AM. |
05-01-2013, 09:06 AM | #704 |
| Re: a tuber
Did you make the collet holder? I assume it is a threaded shaft into your rotary table with the collet taper and lockring thread on it?
05-01-2013, 09:08 AM | #705 |
| Re: a tuber
Those splined cvds are hawt |
05-01-2013, 09:18 AM | #706 |
| Re: a tuber |
05-01-2013, 09:41 AM | #707 |
Rock Stacker Join Date: Sep 2009 Location: Drunk in a ditch
| Re: a tuber |
05-02-2013, 09:29 AM | #708 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: a tuber
I want to see your steering, any one else feel the same. Christian you push the envelope through the slot and out the back of the post box, love your work, BTW your gears look like VP SLW V4 gears |
05-02-2013, 11:38 PM | #709 | |
| Re: a tuber Quote:
the center hole of the rotary table is morse taper too easy to mount and precision centered | |
05-03-2013, 12:01 AM | #710 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: a tuber
OMG, its a piece of art....beautiful art. Ha hang on, there is a imperfection on the drill gears, the center hole is not 100% centered...... I think you should do another set and I will take this set off your hand..... Last edited by Colgout; 05-03-2013 at 12:07 AM. |
05-03-2013, 01:48 PM | #711 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: a tuber |
05-04-2013, 03:18 AM | #712 |
| Re: a tuber
rear shaft w. spool |
05-04-2013, 05:43 AM | #713 |
| Re: a tuber
again work of art.... so it's a 2 pieces with built-in hub and bolt together sandwiches the gear in between? |
05-04-2013, 01:33 PM | #714 |
| Re: a tuber
it´s all glued with Loctite 648 the gear shafts and the rear axle w. motor |
05-04-2013, 05:26 PM | #715 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
| Re: a tuber
Once again very nice work
05-04-2013, 07:50 PM | #716 |
Very sexy! I think ur whole rear axle weighs as much as a stock 540 motor! Can't wait to see the front axle done an with all the shaving, mounting, an steering! |
05-05-2013, 04:41 AM | #717 |
| Re: a tuber
some front axle work servo / battery mounting plates drilled 2 add. holes for another lower link position servo will be right |
05-05-2013, 04:50 AM | #718 |
| Re: a tuber
and the battery mounted |
05-05-2013, 04:55 AM | #719 |
Rock Crawler Join Date: Oct 2007 Location: south of France
| Re: a tuber
A.M.A.Z.I.N.G !!!! a great job you done here the right front tire doesn't rub on the battery ? (need to find something ) and is it some chassis plate in the behind ?? |
05-05-2013, 06:09 AM | #720 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Some true German craftsmanship! send from my HTC One-X |
