03-13-2013, 06:12 AM | #661 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber
some other parts |
03-13-2013, 09:03 AM | #662 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: a tuber
For anorexic motors I presume. Nice. J |
03-13-2013, 06:17 PM | #663 |
Newbie Join Date: Mar 2012 Location: wilmington
| Re: a tuber
by far my favorite XR10 build ive seen to date. i love the ingenuity youve in-bedded into this project. cant wait to see the day when you can finally call it done. if that ever does happen!!
03-14-2013, 10:16 AM | #664 |
| Re: a tuber
next step need to drill and tap lots holes |
03-14-2013, 10:18 AM | #665 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: a tuber Why do the pics say 2009? |
03-14-2013, 10:21 AM | #666 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: a tuber
Gonna guess his camera's clock is not set to the current date. Later EddieO |
03-14-2013, 01:34 PM | #667 |
| Re: a tuber
another pic i need to add the brush hoods and screws , but it should be nearly the final weight itīs with a 3 segment arm , medium wire , 30t i my use a 5 or 7 seg. one if it fits |
03-14-2013, 03:56 PM | #668 |
Quarry Creeper Join Date: Feb 2009 Location: Warwick
| Re: a tuber
...5-segment cobalt magnets?
03-14-2013, 04:14 PM | #669 |
| Re: a tuber
And people thought they ran custom motors....
03-14-2013, 06:28 PM | #670 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: a tuber
All these killer parts and you cant clean your shocks |
03-15-2013, 01:13 AM | #671 |
| Re: a tuber |
03-15-2013, 12:12 PM | #672 |
Pebble Pounder Join Date: May 2008 Location: Mobile, AL
Those motors are SICK! you my friend have some talent, keep us updated! Jake |
03-15-2013, 02:12 PM | #673 |
| Re: a tuber
Yeah, thats what I'm talking about!! I'll be interested to see how your KV compares with a standard 540 since you got your airgap pretty tight, but have thin back iron and thin magnets. Look back on our previous emails about the magnet layout, I hope you made a few extra cans because the armature is very sensitive to magnet position for smooth startup. I have lots of 7 slot blanks here if you need one, it may need grinding and a new comm to fit inside your hood though. |
03-15-2013, 02:39 PM | #674 | |
| Re: a tuber Quote:
fail the mags were easy to remove , so i tried it with more airgap and ended at .9mm it still feels to strong with a straight slot arm , but not to strong with a 3 slot skewed a 5 or 7 slot skewed should be perfect i will use the checkpoint brushes and hoods , so itīs easy to set it up for comms from 7.5 to 11mm with washers or shortened brush Hoods at last it should be exactly the motor i wanted power/torque like a 30t , small diameter and light weight | |
03-15-2013, 03:15 PM | #675 |
| Re: a tuber
.9mm airgap is certainly workable, you will just have a very high KV and low drag. If you want to use .3mm I have some arms we had tooled up specifically for good startup and drag with as tight as .015mm airgaps
03-16-2013, 03:19 AM | #676 |
| Re: a tuber
are your 7 slot arms skewed ? some progress |
03-16-2013, 07:23 AM | #677 |
| Re: a tuber
The current batch of arms are not skewed, but there are some machining tricks and magnet layout tricks to get startup smooth without the skew on 7 slot.
03-16-2013, 08:43 AM | #678 |
MODERATOR Join Date: Jul 2004 Location: Ohio
| Re: a tuber
Wonderful, Christian. You're the one that's skewed, in a good way. |
03-16-2013, 11:27 AM | #679 |
| Re: a tuber |
03-16-2013, 11:47 AM | #680 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
| Re: a tuber
Man, you are a real customizer! This is work of art.. are they ready for the supercrawl? Really like to see some of thes..
