03-18-2011, 07:05 AM | #101 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
I am thinking of upgrading to the B1R esc's, so far what I have read of your thread you seem very happy with them. My main questions on them are how long of runtimes are you putting on them before having heat issues if any? And how is the startup on them? Thanks, I am not happy with my current radio and esc setup and am looking to upgrade.
03-18-2011, 10:55 AM | #102 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
03-19-2011, 10:10 PM | #103 |
So I send a PM to Krawlfreak, thinking to buy some new panels for the BJ v4 and Mini.....Then this box full of goodies shows up today!! So I had to take everything out and see just what was up!! Yep, the new panels were in there!! Two sets even!! But then, I noticed Christmas came early!! Looks like I'll be re-building the XR10!! Man she is gonna be smokin' hot with this, the new skins and the new Lunsford Rock Grinder Links!! Check back for the build up, I'll be starting it tomorrow and have a few tricks up my sleve!! |
03-19-2011, 10:42 PM | #104 |
Quarry Creeper Join Date: Feb 2008 Location: Plano. Il
That chassis look's sweet. Interested in those lunsford link's. Are they pre bent or do they come straight and you bend them.
03-19-2011, 11:51 PM | #105 |
03-20-2011, 11:25 PM | #106 |
So, time to start the CF BJ v4.2 Build, first thing I had to do was remove the axles from the old Chassis. Next I moved the electronics over to the new tray. Then I took the 3mm die from my tap kit and carefully worked each hole by hand....that sounded dirty...lol I am still waiting on my new links and skins, so I just wanted to mock up the chassis. I used some Traxxas CF shims to protect the chassis while I was test fitting. Then I had to go do some stuff with my son, but I'll get back to this later...keep checking back!! |
03-21-2011, 09:50 AM | #107 |
Looking good Art!
03-21-2011, 09:53 AM | #108 |
Very nice Art The CF is sexy!
03-21-2011, 09:55 AM | #109 |
Thanks for the reply on the B1R's. I ordered a pair and am ordering my radio soon also, I am goonna pick up some bigger caps for them too just in case. I am looking forward to this new setup, it will not only look much better but hopefully perform much better too. I am currently running an M2 and DX3E.
03-21-2011, 11:37 AM | #110 | |
Like I said, I am running the 45t hand wound pro's on 3s and haven't had an issue. Another thing, keep your wiring clean, make sure the caps are oriented correctly and so forth. The caps come with small insulating sleeves, I recommend putting them on when you wire it up, to prevent any unnecessary contact with the wrong connections, i.e. shorting out. | |
03-21-2011, 01:14 PM | #111 |
I have a CC BEC already and will be running 2s sometimes but mostly 3s. My motors are Br00d 45t LE Doubles, so our setups will be very similar. If I change out my motors I will be going with a 50 or 55t but hopefully these ESC's and some tuning will take care of the punchy startup I am getting w/ the M2. I will be mounting them on the axle with one of my motor mounts I have leftover, hopefully I can only have wires passing thru my chassis, I want as little sprung weight as possible, it already works well w/ all the electronics in the chassis, I am hoping for a noticable improvement. Thanks for the great build thread and thee input, hopefully we will inspire some more people to try these little guys out.
03-21-2011, 01:37 PM | #112 | |
03-21-2011, 01:42 PM | #113 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Those Carbon fiber Sides look a little naked |
03-21-2011, 02:08 PM | #114 |
03-21-2011, 02:37 PM | #115 |
I may have room on the front axle in front of my battery. I made a few motor rings that have a flange for mounting a flat plate, i have my battery on that, i have some smaller 3s packs on order so i can finalize my setup, the 3s packs i already had were a little too long. Once i get all these parts i can redo my upper links as needed and get rid of the allthread. I think all the electronics will be too much to fit on the front axle, but i am going to try that first and if not, i will make a plate to put all them on and mount it on the rear, this will probably be what i end up doing, i would rather just mount all the electronics in one spot, and the rear is probably gonna be the best place for them. |
03-21-2011, 03:03 PM | #116 | |
Definitely need to see pics!! Quote:
03-22-2011, 03:13 PM | #117 |
So I figured I'd post up what is in this rig for all to know:
Stay tuned!! |
03-22-2011, 04:21 PM | #118 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Love that Carbon Fiber! It's gonna be so light and sweet If you're going to make some new body panels just thought I'd let you know that Jeremy has the full body panels now. He sent me a set and they're cut as perfectly as you'd expect from him Can't wait to see some action pics when you finish! |
03-22-2011, 04:37 PM | #119 |
03-22-2011, 04:48 PM | #120 |
