03-30-2011, 07:51 AM | #21 |
Sneaking in a little update from work... I forgot to mention a lot. First, RTR on the rig was 5lbs 5oz. It felt too light, so I kept a couple of ounces in each front wheel. Now it sits at 5lbs 9oz. That will be my starting point. T1e links are awesome, but I was catching the fronts with the tires because I run a little narrow. I got some of my Big Ron's Customs SS links from a different project and put an extra bend in them. Now the tire rub is gone and they should slide just as well. For uppers in the front, I used some of Jeffs Rock Links because they have a nice curve that allows for lots of room. And its easy to have this much time when you don't sleep. More after work. Last edited by Harvo; 03-30-2011 at 07:56 AM. |
03-30-2011, 08:01 AM | #22 |
Finally out of accident traffic with the ability to watch the video. Awesome job Harvo Very entertaining and exhibits patience far greater than I have.
03-30-2011, 08:12 AM | #23 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
wow nice video action
03-30-2011, 08:17 AM | #24 |
Rock Stacker Join Date: Dec 2008 Location: CARO
that video is cool i want too watch more lol |
03-30-2011, 08:47 AM | #25 |
Quarry Creeper Join Date: Jan 2011 Location: 801
That video was nuts, great looking rig indeed nice job
03-30-2011, 10:10 AM | #26 |
Awesome video |
03-30-2011, 10:38 AM | #27 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
Great work on the truck and video |
03-30-2011, 03:26 PM | #28 |
Allright... the VP stuff... I went through about 4 blown out bearings in the 8mm variety without breaking a stock gear. I switched to 9mm bearings and got the VP cases for both ends. When I finally did blow a 9mm bearing, the balls were big enough to chip the final two drive gears in the rear axle. That is when I ordered the VP motor plates. Almost everyone on here has these already so you know how nice they are. The axles are very smooth and quiet now. Score 1 for VP. I already had a set of V1 SLW wheels, and I picked up another set used so i could run Eric's knuckle weights. I'm running .600 on each side. I also have the VP Knuckles... (very nice peices) but I kept the stock c-hubs. I don't know why. I also have the VP upper link mount ready to go on after our comp this weekend I'll post up some pictures of that when I get it on. Last edited by Harvo; 03-31-2011 at 03:13 PM. |
03-30-2011, 04:14 PM | #29 |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
The video was cool. The truck is pimp! |
03-30-2011, 04:44 PM | #30 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
Best comp build ever! Great job harvo! |
03-30-2011, 04:58 PM | #31 |
Rock Crawler Join Date: Jan 2009 Location: lenoir, nc
Nice Video and the Truck looks great! see ya in a couple weeks
03-30-2011, 06:06 PM | #32 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
One sweet slide show! I loved it We see you in a few weeks. |
03-30-2011, 06:55 PM | #33 |
Awesome video, and your XR-10 Rock Show is a sexy devil.
03-30-2011, 07:18 PM | #34 |
Thanks guys. I really hope I get the hang of the Rockshow AND the radio by Saturday With all the rain, the first courses will be at the comp. I was on the garage pile tonight and my rear shocks are compressing WAY before the fronts. Not if I lift the front by hand, but if I drive it into a twist it's like the front shocks stiffen up then give when it hits a certain pressure. I'm thinking it's an upper link thing, but unsure yet. |
03-30-2011, 10:58 PM | #35 |
Quarry Creeper Join Date: Feb 2008 Location: Plano. Il
That's an awsome video. That rockshow is making me re-think the whole bodyless thing.
03-31-2011, 06:37 AM | #36 |
Rock Crawler Join Date: Dec 2008 Location: Over at yo mama's house
Dude, that vid is sick. Nice work. If it ever stops raining, we need to get to Monte Lake again before ECC.
03-31-2011, 08:07 AM | #37 |
Newbie Join Date: Dec 2009 Location: albany
| build
Nice build harvo super clean build I just got the t1e rockshow curious on how it performs on the rocks roll overs ect........
03-31-2011, 12:10 PM | #38 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
just saying.. SLW V1 - V6 all have the same inner profile, so as far as clearance goes for knuckles weights there is no difference, only hubs will change the clearance. |
03-31-2011, 01:56 PM | #39 | |
Hmmm... wonder why scott's work and mine have full contact ?? We are both running 475 hubs. I'll get a picture. We have the same hexes too. Puzzling. Thanks for the input Tom. EDIT EDIT EDIT..... I am pretty sure the knuckle weights weren't seated all the way before the set screw was tightened. I fixed that issue and tried another ring on each side. This time they fit... with NO modifications. On one side I had a little rubbing at the top of the weight ring, but I think that may have been due to some bearing play. Now I am fitting .600 on each side with 475 hubs. Last edited by Harvo; 03-31-2011 at 03:11 PM. | |
03-31-2011, 05:33 PM | #40 |
Rock Crawler Join Date: Mar 2006 Location: North Carolina
WOW! Best video yet. Truck looks great, those panels look like they turned out great also. Very nice, very nice! Mike |
