10-13-2012, 10:12 PM | #41 |
Rock Stacker Join Date: Dec 2009 Location: stockport ohio
| Re: AREA 51RC "Project Chaotic "Switch" XR10"
i have been watching your build, and i really like the switch chassis, but with funds kinda low ill just stick with my bjv4 for a while. but something i did a while ago with the stock shocks to limit them is i put the inner springs (i cut them in half ) out of some creeper shocks i had laying around in under the piston and i think for what i drive on it works good. it gives you the droop for sidehills and the clearance when you need it. and that climb was pretty cool to.
10-14-2012, 05:53 AM | #42 |
Quarry Creeper Join Date: Oct 2011 Location: U.S.A
Thanks for the input... The Chaotic "Switch" chassis is definetely a performer... aa far as my suspension setup, im happy with how its workin for me at this current time... Here are a couple of vids showing the rig hard at work...sorry the first video is blurry.. http://static.photobucket.com/player...3_162543-1.mp4 |
10-14-2012, 05:57 AM | #43 |
Here is another tough gate... http://static.photobucket.com/player...013_162400.mp4 |
10-15-2012, 12:15 AM | #44 |
Pebble Pounder Join Date: Apr 2012 Location: Brisbane, Australia
good job man
10-16-2012, 04:49 PM | #45 |
Thanks guys... I've never been to the nats so not sure if that was an impressive gate.?or just a typical gate at the nats in comparison.... I try to practice on climbs that seem impossible... Alot of you boyz have been to the nats... what should i be practicing on so i can play with the big boyz?
10-16-2012, 04:56 PM | #46 |
This is gate 5 course 5. . I use this gate to test suspension tuning...If my shocks are not upto par this gate will let me know by throwing the truck into my fire pit... |
10-17-2012, 03:30 AM | #47 |
I was checkin out these Brood matched Vapors... ayone run these? I want to upgrade my motors.. Team Brood Racing :: Crawler Motors :: Handwound Motors :: Vapor Matched Set |
10-17-2012, 05:50 AM | #48 | |
| Re: AREA 51RC "Project Chaotic "Switch" XR10" Quote:
If your not to concerned about the weight but still want the power you could save a little $$ and get something else from Eddie. Im sure if you PM Eddie he could hook ya up with something good. The endbells and armatures are interchangeable between motors - the 'Vapor' part is the turned down can and some other light weight goodies. | |
10-17-2012, 03:36 PM | #49 |
Thanks for the input Robbob... I'm definetely interseted in the lighter weight as well as performance... What turn motor are you runnin and how is the torque/wheelspeed balance for the internal motor setup you chose?
10-17-2012, 06:16 PM | #50 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
30 turn holmes
10-17-2012, 09:33 PM | #51 |
I like my 45t HH pro.. but seeing a lot of guys in 30-35t motors, I may have to check that out at some point.. Slowride, what size pinion do you use with a 30t HH? |
10-17-2012, 10:22 PM | #52 |
RCC Addict Join Date: Jan 2009 Location: O.C
Looking good man. Don't know anything about the Brood motors so no help there. I have been running Holmes motors for the past three years and love them.
10-18-2012, 05:34 PM | #53 |
Thanks guys.. looks like i have some homework to do... Thanks Paystin...what pinions are you using with them Holmes motors?
10-18-2012, 05:38 PM | #54 |
stock 14 for me
10-18-2012, 05:40 PM | #55 |
30 scued is what i run from hh with a 14 an man o man i like it
10-18-2012, 06:01 PM | #56 |
Thanks slowride... whats your torque, wheelspeed balance like with that setup?
10-18-2012, 06:32 PM | #57 |
these are the best motors i have run so far . they will break shit but it will creep as well as wheelie lol. very good balance is all i can say
10-18-2012, 06:37 PM | #58 |
im not knockin broods but i just sold a pair if that tells you how happy i am the the hh motors . my others are a set of 40 hh an thats what i ran at the natts because i didnt have the 30 turns yet but i did have the broods. eddieo makes good motors but john has been very good to me an i like his stuff
10-18-2012, 08:33 PM | #59 |
I have two sets. Crawlmaster 16t with 14 pinion front and rear. I also run 35t torque masters with 14t pinion for both. I used to run one less tooth pinion in the rear but I actually find I get a little less clod stall with the same tooth pinions. I'm no expert when it comes to this stuff though so maybe someone else can explain that better.
10-18-2012, 08:53 PM | #60 |
when you run 1 esc an a punc or switchs it very comon to see one less tooth in the rear to help with the stall. now that most of us run 2 escs you can do the with the other esc by just bumping it alil to the fron side an it pulls so we now run the same front an rear. i have hard of a few guys still one one less in the rear but for me i run the same
AREA 51RC "Project Chaotic "Switch" XR10" - Similar Threads | ||||
...Chaotic Switch........ "The Wicked Tuna" | Chaotic Crawlers | Axial XR10 | 165 | 03-29-2013 05:54 PM |
BADDMANS C1 called 50Cal """XR10 up grade""" | baddman | 1.9 Scale Rigs | 21 | 08-27-2012 11:56 PM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
