03-05-2014, 02:22 PM | #101 |
Pebble Pounder Join Date: Feb 2014 Location: italy
| Re: AREA 51RC "Project Chaotic "Switch" XR10"
I'm anxious to see the new accessories installed, 2 know them (support electronics and battery) but the third did not know what it is ...
03-05-2014, 11:23 PM | #102 |
Quarry Creeper Join Date: Oct 2011 Location: U.S.A
Gutted everything out of the chassis and rewired everything Decided to smash the electronics so they would all fit on the Electronics tray ...started by removing and soldering together the power leads I finally got the two FX-Rs smashed and rewired .... Everything went fairly smooth. I had previously removed the soldering posts so today I was just basically decasing the esc's and some soldering. I did notice that the signal leads from the Esc are very frail without the casing there to support them. I put a fine tip on my soldering iron and tacked them all in place to eliminate any future issues. I also shortened all the signal wiring and soldered the servo power power and ground wires directly to the b.e.c and ran only the yellow signal wire to the receiver .The results were "smashing" No more rats nest in the chassis.... I'm not sure if I'm happy with the b.e.c placement.. Wanted it under the servo but , it doesn't fit! And finally the all stressful power up... For some reason every time I solder electronics and even though I know I did it properly I always brace for the magical smoke poof!! Everything powered up with no issues..... Last edited by D19er; 03-05-2014 at 11:39 PM. |
03-05-2014, 11:25 PM | #103 |
| Re: AREA 51RC "Project Chaotic "Switch" XR10" |
03-05-2014, 11:30 PM | #104 |
you show me a picture from below? so that 'accessory I did not know is the protection for the servo ...
03-05-2014, 11:33 PM | #105 |
03-10-2014, 05:30 PM | #106 |
AREA 51RC "Project Chaotic "Switch" XR10" - Similar Threads | ||||
...Chaotic Switch........ "The Wicked Tuna" | Chaotic Crawlers | Axial XR10 | 165 | 03-29-2013 05:54 PM |
BADDMANS C1 called 50Cal """XR10 up grade""" | baddman | 1.9 Scale Rigs | 21 | 08-27-2012 11:56 PM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
