Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Del Monte's Double Agent
Old 09-14-2013, 09:45 AM   #161
Default Re: Del Monte's Double Agent
jelous
Jake Ewing is offline   Reply With Quote
Old 09-14-2013, 02:39 PM   #162
Originally Posted by Jake Ewing View Post
jelous
jealous
As always Jake very cool to see the ideas you have become a reality.
Jslick is offline   Reply With Quote
Old 09-15-2013, 03:22 PM   #163
Sweet lookin axles.
stelerzman is offline   Reply With Quote
Old 09-15-2013, 03:47 PM   #164
Might these be a product in the near future?
Whiplashdjs is offline   Reply With Quote
Old 09-15-2013, 04:25 PM   #165
Awesome to see you and Jess again, hope you enjoyed the spicy chilli ketchup chips
Rob
Krawler Konceptz is offline   Reply With Quote
Old 10-30-2013, 10:49 AM   #166
Any word Jake? We'll see in Spain? A greeting
alcana is offline   Reply With Quote
Old 03-01-2014, 05:01 PM   #167
Y-Town Crawlers
Del Monte's Avatar
I've been going back and forth trying to figure out a simple solution to the gear/shaft issues on my new gearbox. I've tried pressed/glued gears that spun free too easily and custom 12t gear shafts made out of weak material.
Here's a cheap solution that I think might work very well.
I picked up a 1/8" hex broach from Mcmaster. I'll still use a combination of steel and aluminum pinion gears, but now I have a much better gear selection, plus I can setup an entire gearset at home in about an hour. What's even cooler is that I can use cut down 1/8" allen wrenches to make gearshafts that are strong, cheap, and fit tightly in broached gears
Del Monte is offline   Reply With Quote
Old 03-01-2014, 05:04 PM   #168
Yeah man! Keep going!
Curcal is offline   Reply With Quote
Old 03-02-2014, 02:33 PM   #169
hello jake, I'm your biggest fan ... your truck is scary but the way you drive makes a difference
murali is offline   Reply With Quote
Old 03-02-2014, 05:15 PM   #170
What are you driving the broach with?
Calderwood is offline   Reply With Quote
Old 03-02-2014, 07:40 PM   #171
A mouse in a hamster wheel?
A Rube Goldberg crawler. Epic and efficient!
Old 03-03-2014, 04:34 PM   #172
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Jake didn't accept the argument that one can not fit a square peg into a round hole.
Good idea. Now I know what a broach is. I had to look it up.
SkaldidDog is offline   Reply With Quote
Old 03-03-2014, 04:42 PM   #173
Really? I'm surprised a master machinist such as yourself had not.
ROWDY RACING is offline   Reply With Quote
Old 03-03-2014, 08:39 PM   #174
Y-Town Crawlers
Del Monte's Avatar
The gear is just pushing on the face of the chuck jaws. I left the jaws open just wide enough for the broach to slip through without making contact. The broach has an 1/8" pilot, so everything lines up straight without a lot of setup work.
Old 03-03-2014, 08:41 PM   #175
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Now THAT is thinking critically with what you have!
Turning down the hex "stock" with the lathe to fit the bearings?
JohnRobHolmes is offline   Reply With Quote
Old 03-03-2014, 08:51 PM   #176
Y-Town Crawlers
Del Monte's Avatar
Yep!
I got 3 gear shafts out of a $.39 allen wrench
Old 03-03-2014, 09:06 PM   #177
Nice work Jake...I'm glad someone asked how you were doing that...I was really wondering as I was looking over your first post about it. That's a pricey little gem of a tool though
ittybitty is offline   Reply With Quote
Old 03-03-2014, 09:23 PM   #178
Y-Town Crawlers
Del Monte's Avatar
Yeah, it sort of offsets the cheap gear shafts
Money for cool tooling is never wasted though.
Old 03-04-2014, 08:22 AM   #179
SkaldidDog's Avatar
Someone's gonna see that pic with the lathe chuck, not read the text, spin their gear up and push the broach through and wonder why they spin when mounted on hex rod.
J
Old 03-04-2014, 08:33 AM   #180
J
Broach would probably snap.
Del Monte's Double Agent - Similar Threads
Del Monte's Secret Agent build Del Monte Axial XR10 527 10-28-2016 11:03 AM
Del Monte's Creationfab sporty Del Monte Axial AX-10 Scorpion 25 05-09-2013 10:23 PM
Del Monte's '07 Falcon Del Monte Tamiya TLT Crawlers 48 07-26-2012 07:19 PM
Del Monte's MRC Del Monte Losi Mini-Rock Crawler 18 04-23-2010 09:24 AM
Del Monte's Banana Tuber Del Monte Tamiya TLT Crawlers 11 07-27-2008 01:43 PM
