Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Exclusive Review Axial Yeti ax90026
Old 06-19-2014, 08:20 AM   #61
Default Re: Exclusive review of the Axial YETI AX90026
Hard or soft BFG's come on this?
ROWDY RACING is offline   Reply With Quote
Old 06-19-2014, 08:37 AM   #62
Agreed, but if the knuckles are the same as the Exo, people won't be able to run a lot of the aftermarket wheels without wide hubs... and then the bitching will begin.
Hacksaw707 is offline   Reply With Quote
Old 06-19-2014, 09:08 AM   #63
RcBros Hobbies
RcBro's Avatar
Judging by the hub design, and vanquishes relationship with Axial. I'm nearly positive VP already has the wheels and other items covered.
RcBro is offline   Reply With Quote
Old 06-19-2014, 09:48 AM   #64
Doesn't look like it will be too easy to add a solid front axle.
2JSC is offline   Reply With Quote
Old 06-19-2014, 10:02 AM   #65
Is the brushless system censored? Looks like it in the pictures
HillbillyCrawler is offline   Reply With Quote
Old 06-19-2014, 10:07 AM   #66
no, it's uncensored or maybe unsensored, excuse my french, lol
totof1965 is offline   Reply With Quote
Old 06-19-2014, 10:36 AM   #67
everyone wondering what wheels may work !!
looks like the hub carriers are the size same as the stock EXO
I've been running both on my IFS (EXO front end) with Vp 2.2 OMF & Method wheels - with on problems,
these wheels have no inner bead lock ring
have 350 hubs on it now & it looks like you could even use 250 hubs if need be. with no clearance problems !!
so is everyone ready for a YETI - T shirt ??
the DMG is offline   Reply With Quote
Old 06-19-2014, 10:48 AM   #68
TSK
Shelf queen
TSK's Avatar
They keep saying 4 pole BL right? It's probably the WP Sidewinder with the 4 pole 3300kv combo.
And thank gotd it takes a honking 5000mah 3s
TSK is offline   Reply With Quote
Old 06-19-2014, 10:52 AM   #69
Every one needs a shirt
FRENCHBLUE72 is offline   Reply With Quote
Old 06-19-2014, 11:07 AM   #70
i was on my way to buy a twin hammers,but now i am waiting for this beast,great pictures though.TH has them on preorder at 430 dollars
Traulus is offline   Reply With Quote
Old 06-19-2014, 11:51 AM   #71
The new wheels on the Yeti look like they have plenty of clearance on the backside like a VP OMF wheel.
Old 06-19-2014, 11:52 AM   #72
John, any pics with the steering at full lock?
Erin is offline   Reply With Quote
Old 06-19-2014, 12:01 PM   #73
rpp does as well
Sent from my SCH-I545 using Tapatalk
DowntownScience is offline   Reply With Quote
Old 06-19-2014, 12:11 PM   #74
Diggin' the new SCX10 II!
badger's Avatar
Here is the next batch of photos, you're going to like these!
The Yeti has a lot of rear travel!
Hi-Res image
Hi-Res image
Hi-Res image
Hi-Res image
Love the sway bar setup!
Hi-Res image
2 Speed transmission locked in 2nd gear with optional upgrade kit to provide shifting from 1st to 2nd.
Hi-Res image
Notice the easy access door to remove the battery? Remove two front body clips, lift body/cage and remove the battery door clip to replace battery.
Hi-Res image
Hi-Res image
Hi-Res image
Impact absorbing front bumper that works like a charm!
Hi-Res image
Aluminum shock bodies come stock.
Hi-Res image
Scale fuel cell that is empty for all your scale storage needs!
Hi-Res image
Attach some fuel line from the fuel cell to the fuel filler on the cage for that awesome scale look.
Hi-Res image
Brandon out did himself with the scale details on this rig with the included exhaust tip!
Hi-Res image
Not quite Clod Talk approved 90* of articulation but it will do.
Hi-Res image
Hi-Res image
My favorite tires, 2.2 BFG Krawler T/A's!
Hi-Res image
With Axial being in SoCal, I think someone has watched to many episodes of border wars with this drug smuggling border crossing inspired easy access door for the receiver in the bottom of the chassis.
Hi-Res image
Nice optional body for the Yeti!
Hi-Res image
Hi-Res image
badger is offline   Reply With Quote
Old 06-19-2014, 12:18 PM   #75
Just pre ordered one!
This thread (with the additional pics - thanks!), made the decision easy.
Now patiently waiting.
tedo is offline   Reply With Quote
Old 06-19-2014, 12:20 PM   #76
That pink looks like the color of some skinny kids baby T.
jmecmore is offline   Reply With Quote
Old 06-19-2014, 12:24 PM   #77
Yessssssssss!!! Axial, it's beautiful!!!!!!
fourxfunk is offline   Reply With Quote
Old 06-19-2014, 12:27 PM   #78
Same here, Im sold, going to pre-order!
Looks like a nice bell crank setup for the steering, I have a spare set of Kyosho RT-5 shocks that hopefully will fit this beauty!
Great job Axial!
G-crawler is offline   Reply With Quote
Old 06-19-2014, 12:30 PM   #79
Im Brandon
Brandon's Avatar
Nice pics Badger. Hey look, a new steering knuckle for 2.2's, also looks like a larger bearing in there?
Brandon is offline   Reply With Quote
Old 06-19-2014, 12:42 PM   #80
I sort of feel I can see some weakness allready. Look at the way the front A-arms is hinged to the sub frame. One major hit in front the front wheel and the hinge bolt will break the mount right off. They should have solved this with solid tie bars from side to side as most others. One other thing is the plastic links. Why on earth didn't they use steel turnbuckles? This looks cheap, and I'll bet there will be an upgrade kit they want us to buy. Looks like they've also stuck with the sloppy plastic ball ends. They just plain SUCK even for slow scalers, imagine how great they will be on a much faster car...
For you haters, look at how Traxxas has done this on their cars. At least it _looks_ far superior compared to this, and I do know the Slash takes some major impacts without problems.
I'm not too impressed really, but we'll see when you guys start beating on them.. :-)
Odd-M is offline   Reply With Quote
Tags
2.2, ax90026, axial, axial yeti, crawler, from skinny kids at axial, koh, minions, nap time, rock racer, scale, shut up nigel, ultra4, yeti
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-yeti/499050-exclusive-review-axial-yeti-ax90026.html
Posted By For Type Date
Axial YETI - Pirate4x4.Com : 4x4 and Off-Road Forum This thread Refback 07-14-2014 02:40 PM
Mini Monster Club Romand • Consulter le sujet - Axial Yeti 1/10 4WD – RTR This thread Refback 07-12-2014 03:06 PM
RCFans̳ - Powered by Discuz! This thread Refback 07-05-2014 03:10 AM
Axial 1/10 Scale Yeti Rock Racer (IFS front/Solid rear) - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 06-23-2014 06:01 PM
RCFans̳ - ңģ̳|RCFans This thread Refback 06-23-2014 07:29 AM
• Thema anzeigen - Axial Yeti - Resteverwertung pur... This thread Refback 06-23-2014 03:54 AM
New Products | Aussie RC This thread Refback 06-22-2014 02:05 PM
clubrcsherbrooke.com - Consulter le sujet - Nouveau Axial Yeti! This thread Refback 06-22-2014 07:38 AM
u4rc.pl • Wyświetl temat - Niedługo nowy model Axiala This thread Refback 06-21-2014 02:31 PM
Axial Yeti - Other makes - Tamiyaclub.com Forums This thread Refback 06-21-2014 02:20 PM
RC-TRIAL.PL :: Zobacz temat - Gara Bogdana This thread Refback 06-21-2014 01:00 PM
RCFans̳ - Powered by Discuz! This thread Refback 06-21-2014 05:11 AM
RC-TRIAL.PL :: Zobacz temat - Gara Bogdana This thread Refback 06-20-2014 01:08 PM
Vintage-RC • Afficher le sujet - Axial Yeti This thread Refback 06-20-2014 12:43 PM
Have you seen the Yeti? This thread Pingback 06-20-2014 05:00 AM
AX90026 YETI™ 1/10th Scale Electric 4WD – RTR - Page 6 - RC News - Modelsport UK Forum - Page 6 This thread Refback 06-19-2014 03:00 PM
Wird der neue EXO ein YETI - RC Car Empfehlungen / Modellvorstellungen - RC-Werkstatt.de - Das Modellbau-Forum für alle Modellbaubereiche This thread Refback 06-19-2014 02:10 PM
Axial Yeti 1/10th Scale Electric 4WD - RTR This thread Refback 06-19-2014 01:59 PM
Vintage-RC • Afficher le sujet - Axial Yeti This thread Refback 06-19-2014 01:32 PM
Exclusive review of the Axial YETI AX90026 - Page 4 - RCCrawler This thread Refback 06-19-2014 01:30 PM
Axial YETI... du lourd en perspective... - Page 4 This thread Refback 06-19-2014 12:45 PM
AX90026 YETI™ 1/10th Scale Electric 4WD – RTR - Page 5 - RC News - Modelsport UK Forum - Page 5 This thread Refback 06-19-2014 09:53 AM
Новая модель от Axial 1/10 Yeti 4WD RTR This thread Refback 06-19-2014 05:59 AM
Axial YETI... du lourd en perspective... - Page 3 This thread Refback 06-19-2014 04:42 AM
Novo "carroço" da Axial! Axial Yeti! : Geral - Luso RC This thread Refback 06-19-2014 02:08 AM
Axial Yeti? (IFS front/Solid rear) - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 06-19-2014 01:33 AM
Exclusive Review Axial Yeti ax90026 - Similar Threads
Axial Yeti vs Twin Hammer MeanTT Vaterra Twin Hammers 85 12-01-2015 05:08 PM
Big Squid RC Yeti Video & Review thisdougsforu Axial Yeti 28 07-14-2014 08:16 PM
Axial Yeti corporatelemon Wisconsin 24 06-22-2014 07:32 PM
Axial Yeti? 2-shot Chit Chat 25 06-17-2014 10:35 AM
The Lowdown on the AXIAL YETI!! RcCrawl 2.2 Scale Rigs 4 06-16-2014 02:04 PM
