09-30-2014, 01:01 PM | #41 |
Pebble Pounder Join Date: Jul 2012 Location: USofA
| Re: Genuine factory Axial option parts list
Nice attention to detail from axial on these parts, think the motor plate will be a must have for the high powered motors that the Yeti can accommodate.
10-01-2014, 05:43 AM | #43 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
The machines F1 blocks installed, really fit better than the stock set up and proper angles achieved (using the centered pin bushing). Still hoping for a better pin than the stock screw pins though. |
10-02-2014, 05:48 PM | #44 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
All of these items are in stock in limited quantities at Tower as of a few hours ago. |
10-02-2014, 05:55 PM | #45 |
Come and take them!® Join Date: Oct 2011 Location: Rolling Hill's of Maryland™
Cool. I had preordered these items Monday. Axial Machined Shock Mount Plates Yeti 1 18.99 In Stock Limited Quantities Axial Machined Adjustable Motor Mount Yeti 1 56.99 In Stock Limited Quantities Axial Machined Slipper Plate Yeti (2) 1 18.99 In Stock Limited Quantities Axial Steel Spur Gear 32P 64T Yeti 1 23.59 In Stock Limited Quantities Last edited by Hunter711; 10-02-2014 at 05:58 PM. |
10-03-2014, 06:33 AM | #46 |
Hey Brandon... What is this? Axial Turnbuckle Set Aluminum Yeti (4) - TowerHobbies.com | Axial Turnbuckle Set Aluminum Yeti (4) |
10-03-2014, 09:43 AM | #47 | |
| Re: Genuine factory Axial option parts list Quote:
10-03-2014, 09:07 PM | #48 |
Newbie Join Date: Jul 2014 Location: Australia
Hi guys, Not sure if it's been mentioned here, but the Axial Exo front tower does fit, BUT, it doesn't have any mounting points for the body posts!!!! Waste of cash right there. Grrrrr. |
10-04-2014, 10:46 AM | #49 |
Brandon, can you or anyone else tell us which sway bar is stock in the Yeti? The soft, med, or firm in this set, if its the soft one the others are useless IMO because the stocker is overly firm. I am hoping the stock is firm that would make the set worth buying for the soft and med tuning options. TowerHobbies.com | Axial Rear Sway Bar Soft/Medium/Hard Yeti (3) |
10-04-2014, 12:13 PM | #50 | |
I gave up on trying to find out and ended up filing a slot in the stock bar - so much better, totally forgot Brandon was on here. | |
10-05-2014, 09:02 AM | #51 |
| Re: Genuine factory Axial option parts list Yeah I cannot believe this hasn't been covered. I have a cart full at tower that I plan to pull the trigger on today but I don't want to buy the swaybar set without knowing which ones stock, hell I may do it anyway. |
10-06-2014, 01:47 PM | #52 | |
I posted the Yeti specific shock tower on the first post: AX31170 Machined Front Shock Tower (Hard Anodized) | |
10-06-2014, 01:57 PM | #53 | |
The sway bar set comes with the following: 2.7mm - Soft 3.0mm - Medium 3.2mm - Firm Stock is the softest. I could looking into making some softer bars if the demand is there. | |
10-06-2014, 02:05 PM | #54 |
| Re: Genuine factory Axial option parts list Well shit I gambled and lost, if stock is the softest the others are useless IMO.
10-06-2014, 02:16 PM | #55 | |
The stock swaybar handles the factory power plant really well. Naturally most customers throw more speed at anything that goes fast, so I made stiffer options. I always assumed they would be thrown into the crawler category by some customers (this is RCC afterall). That's why its so easy to remove the swaybar from the rear cage with the pivots. | |
10-06-2014, 02:23 PM | #56 |
I was just hoping stock was the medium so that the option set allowed for tuning in either direction softer or stiffer, its all good.
10-06-2014, 03:14 PM | #57 | |
Until I filed the slot in my stock sway, I would lift a rear tire all the time in any cornering situation. I honestly thought when it was stock it was so large just to handle the torque twist of the chassis, not for handling. When you put a swaybar on an axle, that axle loses traction while the other gains traction. If you have a sway bar on and you go stiffer you lose traction on that axle and gain it at the other. If you go lighter sway you gain traction on that axle and lose it on the other axle. You just got more bars to test filing on! | |
10-06-2014, 08:27 PM | #58 | |
I wanna be Dave Join Date: Sep 2005 Location: *
I do a lot of crawling with speed in between a lot like Ultra 4... I love the stock sway bar setup... Just enough articulation for my style if racing... Now to work out the torque twist lmao... I still say well done!!! Sent from my iPhone using Tapatalk | |
10-07-2014, 12:39 PM | #59 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
So for a newb here, whats the deal with the optional 2 speed transmission? Just curious as I havent seen those optional parts anywhere. Wes |
10-07-2014, 12:46 PM | #60 |
Rock Stacker Join Date: May 2011 Location: WA
| Re: Genuine factory Axial option parts list I've been thinking the same thing. Releasing a new yeti xl and haven't even finished the 2 speed for the yeti.... A little frustrating.
Genuine factory Axial option parts list - Similar Threads | ||||
New Axial Wraith Option Parts | BENDER | Axial Wraith | 32 | 02-01-2012 08:47 PM |
2002 chevy silverado factory Rear steer option ? | general lee | Chit Chat | 13 | 03-12-2011 12:13 PM |
Axial XR10 Genuine Option Parts | Brandon | Axial XR10 | 41 | 12-25-2010 06:06 PM |
New Axial Option Parts from STRC (Shock Bodies, new links, new color!) | teamstrc | Axial AX-10 Scorpion | 70 | 08-05-2008 03:57 PM |
