11-17-2014, 06:22 AM | #41 | |
Newbie Join Date: Nov 2014 Location: France
| Re: The RCNetwork's Yeti Build! Quote:
I think also make this upgrades in my YETI Last edited by Furious from France; 11-17-2014 at 07:11 AM. | |
11-17-2014, 07:35 AM | #42 |
Moderator Join Date: Jan 2004 Location: chicago
the proline shocks you used up front, are those front or rear originally?
11-17-2014, 07:43 AM | #43 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
11-17-2014, 02:40 PM | #44 | |
Thanks for the kind words on the link mounts. One of my favorite tuning features. If you do swap them make sure you flip the upper shock bushings as Carter mentioned. Quote:
11-17-2014, 03:13 PM | #45 | |
Newbie Join Date: Sep 2014 Location: SLC
I had to mount my shocks on the front side of the arm due to clearance issues... | |
11-17-2014, 03:19 PM | #46 | |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
The comment on the ProSpecs and the clearance to universals was from another post with someone wanting to throw in D8 shocks. From installing the ProSpecs, the clearance looks to be perfect even with flex from the arms. Thanks for checking out the thread. Sent from my iPhone using Tapatalk | |
11-17-2014, 03:21 PM | #47 |
| Re: The RCNetwork's Yeti Build! |
11-17-2014, 03:21 PM | #48 |
11-18-2014, 07:43 AM | #49 |
11-18-2014, 09:55 AM | #50 |
i cant see how running bigger shocks would increase the chance of bending an axle shaft when the entire arm moves. seems to me the chance of bending an axle shaft would be more from the stock a arms flexing like wet noodles and enabling the axle shaft to potentially get in a bind from being bent or twisted beyond the mechanical limit of the the axle shaft.
11-18-2014, 03:40 PM | #51 |
I got in a few more newly released Hot Racing parts. The quality seems to be great and they installed nicely! The Stock plastic front body mount vs the HR aluminum mount. Mounted on perfect with the stock hardware. Sent from my iPhone using Tapatalk |
11-18-2014, 03:44 PM | #52 |
Now for the HR aluminum transfer case! The stock transmission mated to the aluminum transfer case nicely and the fit was perfect. Maybe not a huge durability item, but it sure does look good! Sent from my iPhone using Tapatalk |
11-18-2014, 03:45 PM | #53 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
I agree..wonder how many people will use these in other projects..sorta like an atlas t case
11-19-2014, 12:02 AM | #54 |
The Hot Racing sway bar clamp was next. Bright blue! Sent from my iPhone using Tapatalk |
11-19-2014, 01:33 AM | #55 |
Now time to start on the wheels, foams and tires. Probably one of the items I spent the most time deciding on. First off the wheels - Vanquish Method 101's Wow these look good! Sent from my iPhone using Tapatalk |
11-19-2014, 01:34 AM | #56 |
After some research, the claimed 1" vanquish cans are actually .75". So Carter Fab, here I come for some true 1" cans and hardware: Sent from my iPhone using Tapatalk |
11-19-2014, 01:51 AM | #57 |
Tire choice was easy.......Ottsix Voodoo U4 tires: Of course I couldn't use some cheesy foams, So Crawler InNovations' Deuces Wild closed cell foams are the ticket for my 3s powered Yeti Sent from my iPhone using Tapatalk |
11-19-2014, 01:54 AM | #58 |
The CarterFab 1" cans fit perfectly Then time to bolt up those beautiful Vanquish beadlocks. Ended up venting the tires with a leather punch on 3 equal sides (as recommended by CI) Sent from my iPhone using Tapatalk |
11-19-2014, 06:45 AM | #59 |
Quarry Creeper Join Date: Aug 2014 Location: holland
Rich, van you post a pic of the inside of the wheel? Including the 'extra hardware'. If it's mounted as i think it should be mounted doesn't it collect a lot of dirt and mud? Also very interested in how 'deep' these wheels go over the knuckles. Thnx. |
11-19-2014, 06:53 AM | #60 | |
Quarry Creeper Join Date: Sep 2014 Location: UK
So I've used this setup extensively (I have the 1.250 cans though), and although it does collect some degree of muck, it's easy to wash or brush (after you let it dry) off. As for clearance on the inside, .350 adaptors will clear 1" cans. I have to use .475 for my 1.250 & Method combo, otherwise there's a whole lot of contact going on. | |
The RCNetwork's Yeti Build! - Similar Threads | ||||
How's everyone gonna build their Yeti?? | tcm glx | Axial Yeti | 89 | 10-17-2014 12:17 PM |
Got my YETI!!!! wahoo!!! let the u4 build begin | twilight | Axial Yeti | 0 | 08-28-2014 02:31 PM |
The Abomidable YETI U4RC Build.... | scottanthony | Axial Yeti | 22 | 08-02-2014 03:49 PM |
Yeti Killer: How Would You Build It? | MountainStorm | General Crawlers | 24 | 07-07-2014 09:25 PM |
