Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: SSD Rear Axle
Old 06-01-2015, 01:59 PM   #1
Come and take them!®
Hunter711's Avatar
Default SSD Rear Axle
Yep! It's a good thing. SSD DIAMOND CENTERED REAR AXLE FOR AXIAL WRAITH (GREY)
CNC and tolerance excellent. If you want a great centered pumpkin diff, buy this.
If you already have SLW hubs, this is perfect replacement for AR60 axle.
Hunter711 is offline   Reply With Quote
Old 06-01-2015, 02:03 PM   #2
Default Re: SSD Rear Axle
That's a badass looking axle!
Sh0rtBus is offline   Reply With Quote
Old 06-01-2015, 02:19 PM   #3
What if I don't own a Yeti but I want that axle?
Would you recommend it being worn as a necklace?
svt923 is offline   Reply With Quote
Old 06-01-2015, 02:46 PM   #4
Hunter711's Avatar
My wife wears diamond necklace's around her neck consistently . Sure. Why not. You have been watching to much Penny Dreadful on Showtime.
Old 06-01-2015, 10:05 PM   #5
That thing is sick..... Just bought new v2 housing... Kinda bummed I did now. You bastard
trig n tahoe is offline   Reply With Quote
Old 06-02-2015, 05:27 AM   #6
That is awesome! That's perfect for a trophy truck build!
hawgfanman is offline   Reply With Quote
Old 06-02-2015, 12:54 PM   #7
I'm happy:
JesterSpec is offline   Reply With Quote
Old 06-02-2015, 12:59 PM   #8
Awesome! Thanks for sharing the detailed pictures I've been waiting for someone to so that.
tacocat is offline   Reply With Quote
Old 06-02-2015, 01:53 PM   #9
binaryterror's Avatar
Big bearings on both sides? AWESOME!
binaryterror is offline   Reply With Quote
Old 06-02-2015, 01:55 PM   #10
Looks really good.
Ballistic17 is offline   Reply With Quote
Old 06-02-2015, 04:37 PM   #11
So this kit includes everything but gears?
googs is offline   Reply With Quote
Old 06-02-2015, 06:58 PM   #12
Hunter711's Avatar
You will need 2 ea. 5x11x4mm bearings for axle ends.
2 ea. 10x15x4mm bearings for diff spool.
Or use your old ones from AR60 axle. I'd replace w/new while apart.
Face plate is your diff bearing holder.
Good gears and spool if you don't already have is a nice upgrade, but not necessary.
Old 06-02-2015, 11:33 PM   #13
Originally Posted by JesterSpec View Post
This pic confuses me. It's spose to be same length as the AR60, but this pic doesn't appear that it would be.
Old 06-03-2015, 02:17 AM   #14
SSD
They are the same width. The end caps are missing in the photo and the perspective is playing tricks.
SSD is offline   Reply With Quote
Old 06-03-2015, 02:22 AM   #15
And you would know because? HaHa, I thought that might be, but that pic makes it look a lot shorter.
About to pull the trigger on one. I really hate the design of using these flimsy lockouts. Your design simply makes sense.
Old 06-03-2015, 07:29 AM   #16
Looks like my new axle housing, anyone know if a Yeti specific one is going to be made?
DTB1 is offline   Reply With Quote
Old 06-03-2015, 07:54 AM   #17
This one is Yeti specific....what about it isn't Yeti specific. Its a centered AR60 design, its better than the offset stock piece.
Old 06-03-2015, 07:59 AM   #18
This def. will be on my upgrade list next month. I hope it stays in stock long enough with all the buzz you guys are generating. The hardes choice now will be the color. Looks great thanks for sharing!
ARSone24 is offline   Reply With Quote
Old 06-03-2015, 09:00 AM   #19
.Not saying anything is wrong with this one, but having a rear axle that matched the front width would be nice. SSD already makes lockouts and axles that extend the factory ar-60 to the same width of the front.
Thought everyone knew that the front of the Yeti was wider than the rear, guess not. Ease up next time you try to bust someone's balls a little thought/research goes a long ways.
Old 06-03-2015, 09:15 AM   #20
You realize why its narrower though right from a design and handling aspect? There is an important reason. I use offsets, VP currently, but still keep the rear narrower for that same reason. I'd give you the reason, but maybe you can put some thought/research into it.
Though yes there was some talk in another SSD thread about having the wider widths, front axles, and other options coming down
SSD Rear Axle - Similar Threads
New SSD Wide Axle Kit for Yeti SSD Axial Yeti 28 02-19-2017 08:17 PM
SSD New wraith axle housing Szczerba General Crawlers 180 03-01-2016 08:19 PM
New SSD Narrow Rock Shield Rear Bumper for SCX10 SSD Axial SCX-10 15 06-13-2015 07:01 PM
