01-25-2016, 08:52 AM | #141 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
| Re: Bent my first SSD axle today....disappointed
On the axle nuts loosening, The shock & speed is not exactly the problem. The loosening is caused by the forward & reverse slop in the hex. With the pin type hex (even Vanquish) or the new keyed hex, there is too much slop and no way to shim it out. Double nut or locktite help but, I don't think its a cure. The hex needs to be rigidly attached to the axle. Problem is, there is a bearing behind the hex. My new set of SSD axles fit the locker better than ever but, the slop at the hex is a shame. With the slop, We might see these getting rounded out instead of broken pins. CG3 - BadAssRC |
01-25-2016, 06:33 PM | #142 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Bent my first SSD axle today....disappointed Quote:
The better locknuts are also milled on the back/flat surface. My Tekno has a set of them but I havent put any on my crawlers yet. | |
02-02-2016, 10:54 PM | #143 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
My buddy just bent his first set of the new hardened shafts and titanium hexes. shaft bent in the same place and looks like it has a slight twist to it too. tekin pro 4 hd 3500kv on 3s so nothing crazy for power.
02-02-2016, 11:09 PM | #144 |
Any input on what happened when it bent? I'm still going strong, and I was trying to push it, where before I couldn't even roll it on accident. http://youtu.be/vTI-kYWnVnI |
02-03-2016, 08:41 AM | #145 |
Rock Stacker Join Date: Nov 2015 Location: Lubbock
I have both the HD's and stock shafts. Decided to use the stock shafts first and after 2 packs running a PRO4 HD I can say that I haven't bent an axle yet. I jump and bash mine and haven't caught a rear wheel on anything solid but I have flipped and slammed the rear wheels on plenty of jumps. Would running a wide hub cause added stress to the area making it more prone to bend? I'm running 225's and not the stock wide hubs? Last edited by amped up; 02-03-2016 at 09:27 AM. |
02-03-2016, 09:19 AM | #146 |
Wide hubs would surely add more stress.
02-03-2016, 09:28 AM | #147 |
I'm thinking this might be the issue, just can't see the cause being from a manufacturing or material defect.
02-03-2016, 09:42 AM | #148 |
I bent stock shafts quite a bit too.. I know from my primaries testing the HD shafts are stronger. I'd be interested to see where the claim above was bent. Before it was at the pin, revert single time.
02-03-2016, 09:46 AM | #149 |
I didn't have my stock axle long enough to bend the shaft...well until I hit the concrete wall that is. LOL I'd be interested to see the twist as well, that would take quite a bit of torque, figured something else would give before the shaft was able to twist. Last edited by amped up; 02-03-2016 at 09:49 AM. |
02-03-2016, 09:51 AM | #150 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: Bent my first SSD axle today....disappointed |
02-03-2016, 09:18 PM | #151 |
bent section is right at the flat for the hex. and the warped or twisted section is in the middle of the shaft also its a yeti-x not a normal yeti. he is sending me pics cause I didn't take any the other day when we took the car apart. |
04-01-2016, 09:52 PM | #152 |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
08-01-2016, 05:42 AM | #153 |
Quarry Creeper Join Date: Jun 2016 Location: Prague - Czech Republic
Any updates? How HD shafts are holding up? Im looking for solution to my bent shafts. Have Currie centered and already destroyed two pairs. I will definitely go down from 850 hubs to 600 or even shorter. I will use titanium shafts from CREEPERBOB and I will also open rear diff. If all this does not prevent me from bending my shafts I will try my luck with SSD (maybe change rear end completely). |
08-01-2016, 06:59 AM | #154 |
Newbie Join Date: Jan 2016 Location: Manila
Im also on the fence for this and would appreciate any feedback.
08-01-2016, 07:15 AM | #155 |
I am still going strong on the HD shafts from SSD.
08-11-2016, 09:28 PM | #156 |
Rock Stacker Join Date: Apr 2016 Location: Fort McMurray, AB, CAN
I have SSD HD axles and I bent them. I ordered some from CREEPERBOB. If that don't fix my wagon I'm gonna try the Metalconcepts rear diff. The scale TT builder guys are raving about the Metalconcepts parts.
08-12-2016, 12:41 AM | #157 | |
Be careful, you can bend titanium shafts from CREEPERBOB. I have mine prepared together with 2 new pairs of shafts from Vanquish (got one as replacement). I will experiment with those first and if everything goes right I bombproof it by installing Ti shafts. In case it will not work, I can go down to .225 and open rear diff. | |
08-12-2016, 01:05 AM | #158 | |
Rock Stacker Join Date: Jan 2009 Location: simi valley, ca
Sent from my XT1030 using Tapatalk | |
08-12-2016, 03:14 AM | #159 | |
08-12-2016, 08:24 AM | #160 |
The HD shafts are stronger for sure, that being said I'm sure they have limitations. In fact I know they do. I found them. Cartwheel from grass to asphalt. As soon as one of my wheels hit I knew it. Sure enough it bent. Now, it didn't bend as much. And to be honest, it probably should have. I have a solid axle, aluminum wheels, solid foams and a heavy ass truck.. Something will give. I'm ok with it being the axle. |
Bent my first SSD axle today....disappointed - Similar Threads | ||||
New SSD SCX10 axle housings | STANG KILLA SS | Axial SCX-10 | 1394 | 03-10-2023 08:34 AM |
SSD Rear Axle | Hunter711 | Axial Yeti | 152 | 09-09-2019 12:56 PM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
Bent an Axle shaft today | JavelinSST390 | HPI Wheely King | 3 | 08-19-2007 06:30 PM |
